hii.
I am trying to change in Arduino Uno the PWM frequency in pin 3 to 2HZ and I don't know what is the correct command which does that which resemble this conversation in the next command line:
TCCR2B = TCCR2B & B11111000 | B00000001; // for PWM frequency of 31372.55 Hz
thank you
Impossible.
The minimum PWM frequency for pin 3 Arduino Uno - 30 Hz
For 2 Hz use software PWM.
.... about 61
If you take the phase correct PWM, you can have a frequency about 30 Hz.
It is a lowest possible value, as far I know
@shirazhill note, 2Hz is possible only with 16 bit timer. UNO has only one such, the Timer1 and corresponding pins are D9 and D10. pin D3 lowest possible PWM frequence is ~30Hz.
I used some 270 Ohm load resistor I think. Note that that tops the load of and I2C LCD and a NEO6-M GPS.
Here's the code I got from helpers:
//1Hz 90% dutycycle
pinMode(9, OUTPUT); // Set digital pin 9 (D9) to an output
TCCR1A = _BV(COM1A1) | _BV(COM1A0) | _BV(WGM11); // Enable the PWM output OC1A on digital pins 9 and invert output
TCCR1B = _BV(WGM13) | _BV(WGM12) | _BV(CS12); // Set fast PWM and prescaler of 256 on timer 1
ICR1 = 62499; // Set the PWM frequency to 1Hz: 16MHz/(256 * 1Hz) - 1 = 62499
OCR1A = 6249; // Set the duty-cycle to 10%: 62499 / 10 = 6249
pinMode(10, OUTPUT); // 1 Hz pulse output on digital pin 9 (D9)
pinMode(13, OUTPUT); digitalWrite(13, LOW);// Make board LED go off
delay(10);//allow pwm timers to start
for 2 Hz
ICR1 = 31249;
