Frustration with Nano (v.3.0) USB Serial Connections
Hello!
I'm new to the arduino world and this is my first post, so i apologize for any missteps! Anyway..
I've read other threads regarding difficulties connecting the nano via USB but in my reading none seem to be similar to mine.
When I first started using the sainsmart nano v.3.0 (http://www.amazon.com/gp/product/B00761NDHI/ref=oh_details_o05_s00_i02?ie=UTF8&psc=1) the USB serial port would not show up on the Arduino IDE, so I installed the FTDI drivers and it worked for a month or so ( I'm using a macbook pro running OS X 10.9.2). Then, seemingly randomly it would stop working again. I reinstalled the FTDI drivers and it worked for a day or so then wouldn't show up again. I must've done this 2 or 3 times and now the nano is not recognized at all. My Uno connects just fine however, and has done so throughout my issues with the nano. Only bluetooth ports show up when the nano is connected, even through the lights blink indicating it is on. Any help/suggestions would be greatly appreciated because at this point my nano is useless :confused:
The following link describes a similar problem:
Connecting Arduino Nano via USB [MAC] - Installation & Troubleshooting - Arduino Forum
no help here, not a clue about Macintosh, except that are juicer than Red Delicious but not as shinny.
however, I see to recall someone saying they use wireless to connect and upload sketches. if that is an option, it could eliminate the need for a direct connection.
Are you using the D2XX or the VCP drivers? I've had more luck with the VCP drivers on FTDI but not a heck of a lot more. I had to stop the Macs CPU from sleeping (energy saver), spin down the HD was okay (but I never do that either). I think the sleep was unloading the drivers for the FTDI chip.
Eventually I stopped buying any Arduino that used FTDI chips for the USB interface. That solved it.
I suspect it has a lot to do with the fact those drivers are years out of date. Running old version drivers on the latest OS probably isn't the best way to ensure a trouble free connection.
I have one Arduino with FTDI that works just fine, but refuses to show up in the IDE. I program it via the ICSP header and an Omega MP programmer board.
Aruduino nano v3 will not work with OSX 10.9.3
very close to a solution here - but does not work for me: Arduino in OS X 10.9 Mavericks - Serial Port Issues - Installation & Troubleshooting - Arduino Forum
have given up and moved to linux for development. works great.
Some of the Nano clones appearing (on eBay/etc) use a non-FTDI USB/Serial chip, so no amount of fiddling with the FTDI driver will cause them to work. For example, this one: http://www.ebay.com/itm/Mini-USB-Nano-V3-0-ATmega328-5V-16M-Micro-controller-CH340G-board-For-Arduino-/131227868823?pt=LH_DefaultDomain_0&hash=item1e8dca5e97 apparently has a CH340G chip, which doesn't even have a Mac Driver that anyone has found :frowning: (other vendors may not be so forthcoming on which chip they use.)
This one claims to use a PL2303 chip, which is widely cloned, and some of them are being de-supported by Prolific (the original chip vendor.) This one doesn't say, but clearly has yet-another chip: http://www.ebay.com/itm/Arduino-Compatible-Nano-V3-0-ATmega328-5V-Micro-controller-Board-Mini-USB-/331178319577?pt=LH_DefaultDomain_0&hash=item4d1bc41ed9
On the one hand - Yeah! non-exact clones with reduced cost of materials!
On the other hand... People are getting boards that they can't get to work. Boo!
osx driver:
http://www.wch.cn/downloads.php?name=pro&proid=178
you are supposed to do this first(allow unsigned drivers).
sudo nvram boot-args="kext-dev-mode=1"
My $3.19 Nano clones (with the CH340G USB chip) work perfectly on OSX 10.9.4.
I followed the instructions above, which amount to two more installation steps than installing drivers for the more expensive FTDI chips.
1. Install the driver package from
2. Run command line instruction in "Terminal"
3. Restart
The Nano's then appear in the port menu as
"dev/tty.wchusbseiral1411310"
D
My Nano clone works with my mac running Yosemite 10.10.1. I am using HL-340 / CH-340 / CH-341 drivers from...
https://www.mac-usb-serial.com/
The drivers cost a few bucks but they were signed. Fewer security concerns.
charliesixpack:
I find "signed by some random guy with a code signing certificate" having "fewer security concerns" than the official drivers direct from the chip manufacturer kind of amusing.
charliesixpack:
I would go for the manufacturers drivers which are free. They are also built into Linux.
Tried all solutions the forums including v2.3 Apple signed driver CH34x install.kg and nothing worked.
Tried charliesixpack solution and problem instantly fixed. Worth paying for the driver as I had wasted hours trying to get this to work. Running El Capitan 10.11.2 on iMac.
And if you dont want to pay here's a direct link to the drivers for free.... Click on me! and they are the only thing that got my clone arduino board working! So thank you for pointing a newbie in the right direction folks!
I'm working with a Seeduino Nano v3 on OSX 10.11.4, the CH43x driver fixed the problem for me.
Thank you
Daniel2:
3. Restart
D
OMG i install it and my macbook restart restart and restart when i connect adruino uno to my macbook . It only run when i disconnect Uno . How i fix it . OMG
