I have a few 433 FSK buttons that I am trying to imitate.
I attached an image of the signal.
Could I transmit the same signal using a CC1101 transceiver?
I managed to get it to work using:
but the signals do not look the same....any Idea?
thanks
thanks
Its not clear what question you are asking.
Why are you concerned that signals dont look the same if it is working ?
One idea is to read and follow the directions in the "How to use this forum" post.
Bamanio:
And case your wondering, that picture is only a short term average of the frequency spread of the signal. You cannot tell what data encoding is going on. The picture could simply be an FM type audio tone for instance, or some form of encrypted data.
The CC1101 may be able to produce a picture that looks the same, but the data format\protocol could be completly different.
I understand that I did not supply enough info but I don't know which info to give.
The button signal code is not changing, same every time.
I am getting a decimal signal code with a cheap 433 ASK receiver and RCSwitch but after looking in the RTL-SDR and info from the seller I Figured it's FSK button.
How can I supply more data to get an answer?
thanks
Again, consider reading the "How to use this forum" post, at the top of every forum section.
Bamanio:
Cant' work out what you mean by that, sorry.
