Hi all - I added the pins to a breadboard to program the chip with FTDI Friend instead of a Mini USB adapter
Once I got the wiring set up correctly, it is working just fine to auto-reset, and upload sketches. My issue is this - after the upload completes, the sketch runs as expected. When I disconnect the Friend (thus powering down the board) and then reconnect it, for some reason it goes into reset-after-reset - the sketch will not run. I have an LED on pin 13, which just flashes quickly 2/3 times over and over, just like when reset button is pressed.
There's a lot of pages about the correct wiring, here's one I mainly used:
http://thecustomgeek.com/2011/12/07/get-on-board/
last post at the bottom
OK - dumb question... I'm using the Friend as the power supply to the board when it's plugged in (powered from USB port obviously), and not plugging in the "normal" DC power supply when the board is powered standalone. Do I have to hook up BOTH the Friend AND the DC power supply? I assume this will damage things...
Thank you.
