Hi everyone
I am trying to send a text , picture and video separately by using an Arduino Mega 2560. the server is my PC with a Filezilla server. using the following code which I found in the Arduino site I am trying to download or upload files.
But in the first step when I tried to send a text file with 1 kB length, I just could to see an empty text file in server.
Would you explain me how can I solve this problem?
sincerely
#include <SD.h>
#include <SPI.h>
#include <WiFi.h>
// comment out next line to write to SD from FTP server
#define FTPWRITE
// this must be unique
byte mac[] = {0x78, 0xC4, 0xE, 0x01, 0x9C, 0xE3};
// change to your network settings
IPAddress ip ###########
IPAddress gateway#########
IPAddress subnet############
char ssid[]= "########";
char pass[]= "########";
// change to your server
IPAddress server(########);
WiFiClient client;
WiFiClient dclient;
char outBuf[128];
char outCount;
// change fileName to your file (8.3 format!)
char fileName[13] = "TEXT3.TXT";
pinMode(10,OUTPUT);
digitalWrite(10,HIGH);
if(SD.begin(4) == 0)
Serial.println(F("SD init fail"));
WiFi.begin(ssid,pass);
delay(2000);
Serial.println(F("Ready. Press f or r"));
byte inChar;
inChar = Serial.read();
if(inChar == 'f')
if(doFTP()) Serial.println(F("FTP OK"));
else Serial.println(F("FTP FAIL"));
if(inChar == 'r')
readSD();
File fh;
byte doFTP()
#ifdef FTPWRITE
fh = SD.open(fileName,FILE_READ);
Serial.println(fh);
//fh = SD.open("Text3.txt",FILE_READ);
#else
SD.remove(fileName);
fh = SD.open(fileName,FILE_WRITE);
#endif
if(!fh)
Serial.println(F("SD open fail"));
return 0;
#ifndef FTPWRITE
if(!fh.seek(0))
Serial.println(F("Rewind fail"));
fh.close();
return 0;
#endif
Serial.println(F("SD opened"));
if (client.connect(server,21)) {
Serial.println(F("Command connected"));
else {
fh.close();
Serial.println(F("Command connection failed"));
return 0;
if(!eRcv()) return 0;
client.println(F("USER #####"));
client.println(F("PASS #######"));
client.println(F("SYST"));
client.println(F("PASV"));
char *tStr = strtok(outBuf,"(,");
int array_pasv[6];
for ( int i = 0; i < 6; i++) {
tStr = strtok(NULL,"(,");
array_pasv[i] = atoi(tStr);
if(tStr == NULL)
Serial.println(F("Bad PASV Answer"));
unsigned int hiPort,loPort;
hiPort = array_pasv[4] << 8;
loPort = array_pasv[5] & 255;
Serial.print(F("Data port: "));
hiPort = hiPort | loPort;
Serial.println(hiPort);
if (dclient.connect(server,hiPort)) {
Serial.println(F("Data connected"));
else {
Serial.println(F("Data connection failed"));
client.stop();
fh.close();
return 0;
#ifdef FTPWRITE
client.print(F("STOR "));
client.println(fileName);
#else
client.print(F("RETR "));
#endif
if(!eRcv())
dclient.stop();
return 0;
#ifdef FTPWRITE
Serial.println(F("Writing"));
//_______________________________________________________________________________________________________________________________________________________________________
byte clientBuf[64];
int clientCount = 0;
while(fh.available())
clientBuf[clientCount] = fh.read();
clientCount++;
if(clientCount > 63)
dclient.write(clientBuf,64);
clientCount = 0;
if(clientCount > 0) dclient.write(clientBuf,clientCount);
#else
while(dclient.connected())
while(dclient.available())
char c = dclient.read();
fh.write(c);
Serial.write(c);
#endif
dclient.stop();
Serial.println(F("Data disconnected"));
client.println(F("QUIT"));
client.stop();
Serial.println(F("Command disconnected"));
fh.close();
Serial.println(F("SD closed"));
return 1;
byte eRcv()
byte respCode;
byte thisByte;
while(!client.available()) delay(1);
respCode = client.peek();
outCount = 0;
while(client.available())
thisByte = client.read();
Serial.write(thisByte);
if(outCount < 127)
outBuf[outCount] = thisByte;
outCount++;
outBuf[outCount] = 0;
if(respCode >= '4')
efail();
return 0;
return 1;
void efail()
byte thisByte = 0;
client.stop();
fh.close();
void readSD()
if(!fh)
return;
Serial.write(fh.read());
fh.close();
