function for servo movement
when I use the direct servo functions in the loop, all right, see below:
#include <Servo.h>
Servo direcao;
direcao.attach(3);
direcao.write(90);
delay(4000);
direcao.write(120);
delay(4000);
direcao.write(90);
delay(4000);
direcao.write(60);
delay(4000);
direcao.write(90);
delay(4000);
but if I put in a function (below) does not work, what's wrong?
#include <Servo.h>
Servo direcao;
void move(){
direcao.write(90);
delay(2000);
direcao.write(120);
delay(2000);
direcao.write(90);
delay(2000);
direcao.write(60);
delay(2000);
direcao.write(90);
delay(2000);}
direcao.attach(3);
void move();
Explain what you are trying to get the servo to do.
only to move between the angles 60 - 90 - 120 degrees ....
This
  void move();
should be
     move();
When you put void before the function name it tells the compiler that you are defining a new function.
...R
thank you very much
Actually it is not a new function definition, its a function prototype, telling the compiler
that there is somewhere a function called move, not defining it nor calling it.
A function definition looks like:
void foo ()
A function prototype looks like:
void foo () ;
A function call looks like:
  foo () ;
Function calls always have to be inside another function definition, prototypes are normally at
top level but can be locally scoped (ie inside a function definition)
MarkT:
Thanks Mark.
That explains why the compiler did not complain - I had been wondering about that.
...R
Erase void, before move(),
When you write void move();, compiler thinks that you declare sth to move() function. In other words, void is the declaring command of a function as @MarkT's Reply #5 (and Reply #3). To use the function, you just write the function name with brackets in loop. In your code, program takes move() function as blank. That's why compiler sees no problem. It is a logic error.
So compiler does its job :slight_smile:
Regards.
eXXonWaldez:
In other words, void is the declaring command of a function.
I guess you missed @MarkT's Reply #5 (and Reply #3).
...R
Robin2:
...R
Noted and corrected, did not notice, sorry
