Function Freezes Code??? :o
Hello. I recently got the Tea5767 radio module, along with the library. I was originally going to have it where if you press a button it goes up a station frequency by 0.1, and another button for down. Then I realized that would take forever to tune in to a station. I am trying to make an auto scan feature, that moves up the frequency by 0.1 automatically. How could I program that? Thanks in advance! :slight_smile: :slight_smile: :slight_smile:
Oh, and by the way here is the code I have currently:
#include <TEA5767Radio.h>
#include <Wire.h>
TEA5767Radio radio = TEA5767Radio();
int y = 0;
int x = 0;
int fr = 88.2;
int up = 1;
x = fr + up;
  delay(5);
  fr = x;
y = up + 1 ;
  delay(5);
  y = up;
  delay(5);
  radio.setFrequency(fr);
  Serial.print("FR= ");
  Serial.print(fr);
     delay(4000);
Aha! I have tested using this code:
#include <Wire.h>
int y = 0;
int x = 0;
long fr = 88.2;
int up = 1;
Wire.begin();
Serial.print("Hi");
  Serial.print(fr);
      x = fr + up;
  delay(5);
  fr = x;
     delay(10);
When I remove radio.setFrequency(fr); the code works as normal. However, when I keep it in the code, it is almost as if the "loop" does not loop. 'fr' is printed ONCE on the serial monitor, and does not repeat... However, that one line of code is crucial. Why is it stopping my entire loop function?
Hello. I have the TEA5767 library. Whenever I call this function
radio.setFrequency()
My entire sketch seems to stop in its tracks. For instance, if I print "1" to the Serial monitor, then have the function, then print "2," I will get 1 on the Serial Monitor but not 2, or anything beyond 2!
Can someone tell me WHY this is happening??? I really need your help!!! And if you can, I need it quickly!
Do you actually have a radio connected to your arduino?
Can you talk to it with any of the other library functions?
Most likely cause is improper connection....
Here is my library: Arduino Playground - TEA5767Radio Library
Here is my full code:
#include <Wire.h>
int y = 0;
int x = 0;
long fr = 88.2;
int up = 5;
Wire.begin();
Serial.print("Hi");
  Serial.print(fr);
      x = fr + up;
  delay(5);
  fr = x;
     delay(10);
Yes, the radio module is plugged in to the Arduino.
Thanks for the help so far! :slight_smile:
long fr = 88.2;
Well, that code definitely needs the auto-format run across it.
I2C can be frozen indefinietly if there's a problem with the data line. Without pullups, the Arduino will wait "forever" for an acknowledgement from the slave, which never comes.
  1. Which Arduino?
  2. Which pins on that Arduino are you using for I2C?
  3. Which radio module? It may not have pullups.
MorganS:
  1. Which Arduino?
  1. Arduino Uno
  2. A4 and A5 for SDA and SCL, (Or maybe the other way around, I don't have the board in front of me) 5V to VCC, GND to GND.
  3. TEA5767 full Geekfun Module: https://www.amazon.com/gp/product/B014QZM53Y/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
What kind of Pullups do you mean? What do you mean by 'auto-format?'
Thanks!
Auto-format is on the Tools menu in the Arduino IDE. If it looks like it scrambled your code, then your code is wrong. It's a very good formatter (older ones could scramble correct code.)
@stupid-questions, do not cross-post. Threads merged.
Oh... Wow... Sorry! I just thought this was a seperate-ish error from the other more general post, and deserved its own thread. Will not happen again! :wink:
Ok. I did the Auto Format on my code. Here is the new code:
#include <Wire.h>
int y = 0;
int x = 0;
long fr = 88.2;
int up = 5;
  Wire.begin();
  Serial.print("Hi");
  Serial.print(fr);
  x = fr + up;
  delay(5);
  fr = x;
  delay(10);
If I run this code, is it more likely to work?? Does Auto Format perfect the functionality of the code? If not, what do I do next to make this code NOT freeze up?
That makes the code more readable, thanks.
I believe the problem may be in the connections. Specifically SDA. Does it have a pullup resistor anywhere in the system? That is, a resistor of about 4.7K (double or half this value is OK) connecting SDA to +5V. Also add an equivalent resistor to SCL.
That Amazon link doesn't show a schematic. Looking at the pictures of the PCB, it doesn't appear to have pullups.
MorganS:
Please everybody note. The radio IS working. This code works:
// TEA5767 Example
#include <Wire.h>
  Wire.begin();
  radio.setFrequency(93.0); // pick your own frequency
  Serial.print("Done");
The radio easily and quickly tunes into the station, as long as there is something broadcasted on it. HOWEVER. "Done" is not printed on the Serial Monitor. The radio keeps playing and playing, and "Done" is nowhere to be found on the monitor.
At least that is what I THINK stupid-questions is trying to say... Right?
WesleyRTech:
// TEA5767 Example
#include <Wire.h>
  Wire.begin();
Wow! You read my mind WesleyRTech, that code does work! I thought that was clear, but I suppose not. So yeah, THAT code works, its just that DONE isn't printed on the Serial Monitor.
Sorry to resurrect such an old post, but this issue has come back to haunt me.
Delta_G:
Here's the code from the setFrequency function. All it does is make some writes using the Wire library. So if it is locking up there then there must be some issue with the I2C comms.
Ok, so there is a problem with the I2C comms. What could that problem be? What would you suggest to repair the comms? I heard "pullup resistors" mentioned before, could that solve the problem?
Everyone has been a great help so far!
(Please note. The module is working. The frequency gets set. However, the program does not continue afterwards!)
Pullup resistors always help, until the total resistance of all the pullups gets too low, with many in parallel. 4.7K is about the best. Anything from about 2K to 10K should be good.
See Gammon Forum : Electronics : Microprocessors : I2C - Two-Wire Peripheral Interface - for Arduino for more information on I2C.
MorganS:
But could the lack of pullup resistors be directly the cause of the problem? Like they are nice to have but are they the direct cause?
Delta_G:
Do any of the functions in Wire block waiting for a response or acknowledgement?
Wire.endTransmission() will block if the SDA is held low. It seems especially bad on the Due.
