I have written a code that loads different applications from the sketch
#include <LiquidCrystal.h>
// Arduino pins number
const int SW_pin = 2; // digital pin connected to switch output
const int X_pin = 0; // analog pin connected to X output
const int Y_pin = 1; // analog pin connected to Y output
const int LCD_RS = 7;
const int LCD_Enable = 8;
const int LCD_D4 = 9;
const int LCD_D5 = 10;
const int LCD_D6 = 11;
const int LCD_D7 = 12;
LiquidCrystal lcd(LCD_RS, LCD_Enable, LCD_D4, LCD_D5, LCD_D6, LCD_D7);
// Basic vars
int none = 0;
String Apps[3] = {"App select","Credits","Test your brain"};
int CurrentApp = 0;
int Yaxis = 1;
int Xaxis = 1;
int HiCh = 0;
int button;
int JXaxis;
int JYaxis;
void AppSelect() { // APPSELECT
lcd.setCursor(0,0);
lcd.print("App select menu");
lcd.setCursor(0,1);
lcd.print(Apps[HiCh]);
if (button == 0) {
SelectApp();
if (JYaxis <= 2) {
if (HiCh != 0) {
HiCh = HiCh - 1;
lcd.clear();
lcd.setCursor(0,1);
delay(300);
if (JYaxis >= 7) {
if (HiCh != 1) {
HiCh = HiCh + 1;
lcd.clear();
lcd.setCursor(0,1);
delay(300);
void Credits() { // CREDITS
Serial.print("- Credits app loading \n");
lcd.clear();
lcd.setCursor(9,0);
lcd.print("Credits");
lcd.setCursor(0,1);
lcd.print("Made by Alexandre Bergeron");
Serial.print("- Credits app loaded \n");
delay(1300);
lcd.scrollDisplayLeft();
delay(600);
delay(600);
delay(600);
delay(600);
delay(600);
delay(600);
delay(600);
delay(600);
delay(600);
delay(600);
delay(600);
delay(1500);
CurrentApp = 0;
lcd.clear();
void BrainTest() { // BRAINTEST
lcd.setCursor(0,0);
lcd.print("Are you ready?");
lcd.setCursor(0,1);
lcd.print("Yes No");
void setup() { // SETUP
Serial.print("[2J");
Serial.print(" Serial Monitor opened \n \n");
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
Serial.print("- App selector menu \n");
pinMode(SW_pin, INPUT);
digitalWrite(SW_pin, HIGH);
void SelectApp() { // SELECTAPP
switch (HiCh) {
case (0):
CurrentApp = 0;
AppSelect();
case (1):
CurrentApp = 1;
Credits();
case (2):
CurrentApp = 2;
BrainTest();
default:
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Error");
Serial.print("- App loading error \n");
void loop() { // LOOP
button = digitalRead(SW_pin);
int JYaxis = analogRead(Y_pin) / 128;
int JXaxis = analogRead(X_pin) / 128;
if (CurrentApp == 0) {
lcd.setCursor(0,0);
lcd.setCursor(0,1);
if (button == 0) {
SelectApp();
if (JYaxis >= 7) {
if (HiCh != 0) {
HiCh = HiCh - 1;
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
delay(300);
if (JYaxis <= 2) {
if (HiCh != 2) {
HiCh = HiCh + 1;
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
delay(300);
My custom error message pup up to my lcd when I try to load BrainTest
Any help please?
