I have a program created where the button after each click moves certain actions. I'm using switch method. All works great except Rotate(). If I call the function directly in the loop function, it works just fine. It just doesn't work in the switch method under the case. Any Ideas? Thanks. Here is the code:
#define PIN_COUNT 10
#define UPDATE_DURATION 30
int states[PIN_COUNT];
int current_pin = 0;
int dir = 1;
int update_count = 0;
int ledPins[PIN_COUNT] = {0,1,2,3,4,5,6,7,8,9};
int switchPin = 13; // choose the input pin (for a pushbutton)
int val; // variable for reading the pin status
int val2; // variable for reading the delayed status
int buttonState; // variable to hold the button state
int Mode = 0; // What mode is the light in?
boolean modeChanged = false;
const int NUM_MODES = 14;
/* RGB */
const int RED_PIN = 10;
const int GREEN_PIN = 11;
const int BLUE_PIN = 12;
int DISPLAY_TIME = 100;
/* RGB */
int index;
for(index = 0; index <= 9; index++)
pinMode(ledPins[index],OUTPUT);
// ledPins[index] is replaced by the value in the array.
// For example, ledPins[0] is 2
pinMode(switchPin, INPUT); // Set the switch pin as input
buttonState = digitalRead(switchPin); // read the initial state
/* RGB */
pinMode(RED_PIN, OUTPUT);
pinMode(GREEN_PIN, OUTPUT);
pinMode(BLUE_PIN, OUTPUT);
/* RGB */
for ( int i = 0; i < PIN_COUNT; i++ ) {
pinMode(ledPins[i], OUTPUT);
states[i] = 0;
/* RGB */
void mainColors()
// Off (all LEDs off):
digitalWrite(RED_PIN, LOW);
digitalWrite(GREEN_PIN, LOW);
digitalWrite(BLUE_PIN, LOW);
// Red (turn just the red LED on):
digitalWrite(RED_PIN, HIGH);
// Green (turn just the green LED on):
digitalWrite(GREEN_PIN, HIGH);
// Blue (turn just the blue LED on):
digitalWrite(BLUE_PIN, HIGH);
// Yellow (turn red and green on):
// Cyan (turn green and blue on):
// Purple (turn red and blue on):
// White (turn all the LEDs on):
/* RGB */
void Decade()
int index;
int delayTime = 100; // milliseconds to pause between LEDs
val = digitalRead(switchPin); // read input value and store it in val
delay(10); // 10 milliseconds is a good amount of time
val2 = digitalRead(switchPin); // read the input again to check for bounces
if (val == val2) { // make sure we got 2 consistant readings!
if (val != buttonState) { // the button state has changed!
if (val == LOW) { // check if the button is pressed
Mode++;
if (Mode >= NUM_MODES) {
Mode = 0;
modeChanged = true;
buttonState = val; // save the new state in our variable
if (modeChanged) {
// Now do whatever the lightMode indicates
switch(Mode) {
case 0:
digitalWrite(ledPins[index], LOW);
case 1:
digitalWrite(ledPins[0], HIGH);
case 2:
digitalWrite(ledPins[1], HIGH);
case 3:
digitalWrite(ledPins[2], HIGH);
case 4:
digitalWrite(ledPins[3], HIGH);
case 5:
digitalWrite(ledPins[4], HIGH);
case 6:
digitalWrite(ledPins[5], HIGH);
case 7:
digitalWrite(ledPins[6], HIGH);
case 8:
digitalWrite(ledPins[7], HIGH);
case 9:
digitalWrite(ledPins[8], HIGH);
case 10:
digitalWrite(ledPins[9], HIGH);
case 11:
Rotate();
case 12:
case 13:
Decade(); // RUNTIME!!
void updatePins() {
analogWrite(ledPins[i], states[i]);
delay(6);
void decay() {
states[i] = (19*states[i]/20);
void Rotate(){
decay();
states[current_pin] = 255 * update_count / UPDATE_DURATION;
updatePins();
update_count++;
if ( update_count > UPDATE_DURATION ) {
update_count = 0;
current_pin += dir;
if ( current_pin == 0 ) {
dir = 1;
/* else if ( current_pin == (PIN_COUNT-1) ) {
dir = -1;
