Function was not declared in scope
Dear Fellow Arduinists,
Apologies now for this question, I get the feeling I should be able to solve this having looked at many posts on the same subject but I still can't get the sketch to compile.
I'm using an environmental sensor (BMP280) to record pressure and temp data to an SD card, there are also some flashy LED's just because I can. There is a relay controlling a heater circuit which switches things on at a given external temperature. The package will fly on a balloon payload. All this works well.
I then wanted to add a second temperature sensor (TMP36) to record the internal temp of the payload and write that to the SD card, I also thought it would be better to use this sensor to trigger the heater relay. I got the sensor working on it's own and merrily reporting data in the serial monitor.
The problem came when I tried to incorporate the code for the TMP36 into my working sketch. I've tried to track down all of the braces to ensure I have a balanced code but I still get the error message 'getVoltage was not declared in this scope'.
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP280.h>
#include <SD.h>
File myFile;
Adafruit_BMP280 bmp; // I2C
/* Temperature sensor pins connnection
 *  Vin --> 5V Arduino ---Red
 *  Gnd --> Gnd Arduino ---Black
 *  SCK --> A5 Arduino ----Yellow
 *  SDI --> A4 Arduino ----Orange
/* MicroSD Board pins connnection
Connect the 5V pin to the 5V pin on the Arduino
Connect the GND pin to the GND pin on the Arduino
Connect CLK to pin 13
Connect DO to pin 12
Connect DI to pin 11
Connect CS to pin 10
//Test Version!
float pressure;  //BMP280 Variable
float temperature;  //BMP280 Variable
int altimeter;  //BMP280 Variable
const int temperaturePin = 3; //TMP36 Pin Set
unsigned long startMillis;  //Timing variables for LEDS
unsigned long currentMillis; //Timing Variables for LEDS
const unsigned long period = 5000; //the value is a number of milliseconds, LED delay.
 pinMode(8, OUTPUT); //Power to Red LED
 pinMode(7, OUTPUT); //Power to Green LED
 pinMode(6, OUTPUT); //Power to Heat Pad
  bmp.begin();
    Serial.begin(9600); //Begin serial communication at 9600bps
    Serial.println("Adafruit BMP280 Wire Test");
    if (!bmp.begin()) {
    Serial.println(F("Could not find a valid BMP280 sensor, check wiring!"));
    while (1);
    startMillis = millis();  //initial start time
  Serial.print("Initializing SD card...");
   pinMode(10, OUTPUT);
  if (!SD.begin(10)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
 currentMillis = millis();  //get the current "time" (actually the number of milliseconds since the program started)
  if (currentMillis>10000 && currentMillis - startMillis >= period)  //test whether the period has elapsed for LEDS to light.
  digitalWrite(8, HIGH);
  delay(40);
  digitalWrite(8, LOW);
  delay(50);
  delay(40);
  delay(50);
  delay(40);
  delay(50);
  delay(40);
  delay(50);
  delay(40);
  delay(50);
  delay(40);
  delay(50);
  delay(40);
  delay(50);
  delay(40);
  delay(50);
delay(250);
  digitalWrite(7, HIGH);
  delay(40);
  digitalWrite(7, LOW);
  delay(50);
  delay(40);
  delay(50);
  delay(40);
  delay(50);
  delay(40);
  delay(50);
  delay(40);
  delay(50);
  delay(40);
  delay(50);
  delay(40);
  delay(50);
  delay(40);
  delay(50);
  startMillis = currentMillis;  //IMPORTANT to save the start time of the current LED state.
  //Read values from the BMP280 sensor:
  pressure = bmp.readPressure();
  temperature = bmp.readTemperature();
  altimeter = bmp.readAltitude (1002.1195); //1 inch mercury = 33.8639 millibars. Change the "1050.35" to your city current barrometric pressure (https://www.wunderground.com)
   if(temperature>18 ) { //temperature required to switch heat pad on/off
    digitalWrite(6, HIGH);
    digitalWrite(6, LOW);
 //TMP36
  float voltage, degreesC, degreesF;
   voltage = getVoltage(temperaturePin);
  degreesC = (voltage - 0.5) * 100.0;
  degreesF = degreesC * (9.0/5.0) + 32.0;
  Serial.print(voltage);
  Serial.print(degreesC);
  Serial.print("Time: ");
      Serial.print(currentMillis);
      Serial.println((" milliseconds"));
  Serial.print(F("Pressure: "));
    Serial.print(pressure);
    Serial.print(" Pa");
    Serial.print("\t");
    Serial.print(("Temp: "));
    Serial.print(temperature);
    Serial.print(" oC");
  Serial.print("\t");
    Serial.print("Altimeter: ");
    Serial.print(altimeter); // this should be adjusted to your local pressure forecast
    Serial.println(" m");
    delay(500); // 0.5 sec delay (500ms)
    float getVoltage(int pin) //TMP36
   return (analogRead(pin) * 0.004882814);
    myFile = SD.open("hab.txt", FILE_WRITE);
  if (myFile) {
    Serial.print("Writing to test.txt...");
    //myFile.println("New Data"); //Removed to save file space.
    //myFile.print("Pressure: "); //Removed to save file space.
         myFile.print(currentMillis);
myFile.print(",");
     myFile.print(pressure);
      myFile.print(",");
      //myFile.print("   Temperature: "); //Removed to save file space.
       myFile.print(temperature);
       myFile.print(",");
       //myFile.print("  Altimeter: "); //Removed to save file space.
    myFile.println(altimeter);
      //myFile.println(" m"); //Removed to save file space.
    myFile.close();
    Serial.println("done.");
    // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
Thank you in advance, please let me know if you need any further information. I have attached the INO file of my sketch, hope this is the right way to do things.
Best wishes
Phil
Relay_Millis_TMP36.ino (5.6 KB)
Use Ctrl + T to auto-format the source code. The mistake should be apparent. (Hint: there is no such thing as a nested function in C++)
This function is not define correctly.
It must be outside of other code.
Hi Larryd and Coding Badly,
Thanks so much, all working nicely! Appreciate you hlp chaps.
Have a nice weekend.
Phil
You too!
