Functions skipping
I was practicing sketched. I have the following problem
The Program does not execute the functions no error while compiling. Can anybody give me the solutions
The following standard blink LED was taken
// the setup function runs once when you press reset or power the board
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
The above standard sketch working fine with LED blinking seen
Now to practice I have modified as follows
Serial.println(" In Blink Sketch");
void SetLedHigh();
// digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
void SetLedLow();
// digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
void SetLedHigh()
Serial.println("LED is set ON");
void SetLedLow()
Serial.println("LED is set OFF");
digitalWrite(LED_BUILTIN, LOW); // turn the LED on (HIGH is the voltage level)
From the above sketch no compilation errors are seen and LED does not blink. I think it is skipping the function. can any body solve my problem
(deleted)
