GameBoy Advance Button Reader Library
Hello everyone,
Here is a library that I originally made for a Raspberry Pi Pico, but it should work on any 3.3v logic Arduino too.
How it works:
You will need a GBA cable (obviously) and you will also need to figure out the pinout of that cable with a multimeter.
It works by using a feature the Gameboy Advance has called Multiboot. With this you can load a small ROM directly into the memory of the GBA. You can even unplug the cable and the rom will continue to play. Of course, you won't be able to read the buttons if you do this but it's cool nonetheless.
I did need to use Claude to make the ROM for me, so if you want to change it, go right ahead.
I am powering my Pico from the Gameboy itself, but I would advise you use an external power supply for your board.
Word of caution, if you do use the power from the Gameboy, make sure you have a way to disconnect the VCC (from the Gameboy) when you are using your computer to upload the code as well as run the diagnostic example. You run the risk of damaging your GBA if you don't.
Have fun and please share your projects here for everyone to see!
Library:
GBAButtons.zip (11.3 MB)
Also hosted on Dropbox:
I DID IT!
GBA to NES/SNES controller!
Forgot to link the code. This code does not use my library; In fact, I made the library after this code.
gba_nes_controller.zip (48.3 KB)
Nice work getting the GBA working as an NES/SNES controller. Using Multiboot to read the buttons is a clever trick. Thanks for sharing the code.
