Garbled LCD screen
Hey,
I am building an alarm clock that brews coffee. Before when I had the code partially completed, the LCD screen displayed very well. Now that I added the function of debouncing two more buttons, moving a servo and showing the time using an RTC, the LCD shows all garbled text. I have attached an image of what it displays. I suspect that it is a coding issue because I uploaded the example sketch and it worked. can someone please look at my code and see whats wrong. Thank you soososos much for the help.
LCD_Coffee_Settings_Menu.ino (6.18 KB)
Sorry, haven't looked at the code (yet) - it is inconvenient when posted as an attachment.
Can you post it in a "code" box (the "scroll" icon above the Post Reply window) ?
Here's the question - do you have a copy saved of the "last working" code? That would be the thing to work from- and if you do not, then you have learned a very important lesson. :grinning:
Unfortunetly no i don't have a copy of my last working code. Haha yes it is a very important lesson learned. I have put my code below and im very sorry since it is very messy.
#include <Wire.h>
#include "RTClib.h"
#include <LiquidCrystal.h>
#include <Servo.h>
RTC_DS1307 RTC;
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
boolean coffeeLastButton = LOW;
boolean coffeeCurrentButton = LOW;
int coffeeMenu = 0;
int selectionButtonOne = 0; //INSERT PIN NUMBER HERE
boolean selectionButtonOneLast = LOW; //Used for debouncing
boolean selectionButtonOneCurrent = LOW; //Used for debouncing
int selectionButtonTwo = 0;//INSERT PIN NUMBER HERE
boolean selectionButtonTwoLast = LOW; //Used for debouncing
boolean selectionButtonTwoCurrent = LOW; //Used for debouncing
int alarmHour = 0;
int alarmMin = 0;
int coffeeChoice = 0;
Servo FREservo;
Servo COLservo;
void setup(){
  FREservo.attach(8);/*INSERT PIN NUMBER HERE*/
  COLservo.attach(9);/*INSERT PIN NUMBER HERE*/
  FREservo.write(0);
  COLservo.write(0);
  pinMode(6, INPUT_PULLUP);
  pinMode(selectionButtonOne, INPUT_PULLUP);
  pinMode(selectionButtonTwo, INPUT_PULLUP);
  Wire.begin();
  RTC.begin();
  lcd.begin(16, 2);
   if (! RTC.isrunning()) {
     //lcd.setCursor(0, 0);
   Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
   RTC.adjust(DateTime(__DATE__, __TIME__));
boolean menudebounce(boolean coffeeLast){   //This section debounces the Menu button
  boolean coffeeCurrent = digitalRead(6);
  if (coffeeLast != coffeeCurrent){
   delay(5);
  return coffeeCurrent;
boolean buttonOnedebounce(boolean OneLast){   //This section debounces the SelectionOne button
  boolean OneCurrent = digitalRead(selectionButtonOne);
  if (OneLast != OneCurrent){
   delay(5);
  return OneCurrent;
boolean buttonTwodebounce(boolean TwoLast){   //This section debounces the SelectionOne button
  boolean TwoCurrent = digitalRead(selectionButtonTwo);
  if (TwoLast != TwoCurrent){
   delay(5);
  return TwoCurrent;
void loop(){
  coffeeCurrentButton = menudebounce(coffeeLastButton);
  selectionButtonOneCurrent = buttonOnedebounce(selectionButtonOneLast);
  selectionButtonTwoCurrent = buttonTwodebounce(selectionButtonTwoLast);
  if(coffeeLastButton == LOW && coffeeCurrentButton == HIGH){
    coffeeMenu = coffeeMenu++;
    coffeeLastButton = HIGH;
   coffeeLastButton = coffeeCurrentButton;
  if(selectionButtonOneLast == LOW && selectionButtonOneCurrent == HIGH){
    selectionButtonOne = !selectionButtonOne;
    selectionButtonOneLast = HIGH;
  selectionButtonOneLast = selectionButtonOneCurrent;
   if(selectionButtonTwoLast == LOW && selectionButtonTwoCurrent == HIGH){
    selectionButtonTwo = !selectionButtonTwo;
    selectionButtonTwoLast = HIGH;
  selectionButtonTwoLast = selectionButtonTwoCurrent;
      if(coffeeMenu == 3){ //Limits Menu button to values 0, 1, 2
    coffeeMenu = 0;
  Serial.println(coffeeMenu);
  if(coffeeMenu == 2){
    lcd.print (alarmHour);
    lcd.print (":");
    lcd.print (alarmMin);
  if(alarmHour == 24){
    alarmHour = 0;
  if(alarmMin == 60){
    alarmMin = 0;
  while(coffeeMenu == 2){
    if(selectionButtonOne = HIGH){
      alarmHour++;
    if(selectionButtonTwo = HIGH){
      alarmMin++;
 DateTime now = RTC.now();
  DateTime future (now.unixtime() + alarmHour * 3600 + alarmMin * 60);
  if(now.unixtime() == future.unixtime()){           //This section says when now timestamp == to alarm timestamp make an action happen
   if(coffeeMenu == 1 && coffeeChoice == 0){
   lcd.print("Coffee Settings");
   lcd.setCursor(0, 2);
   lcd.print("FRE         COL");
   else{
   lcd.print("                ");
   lcd.print("                ");
   while(coffeeMenu == 1 && coffeeChoice == 0){
     if(selectionButtonOne == HIGH){
       coffeeChoice = 1;
     if(selectionButtonTwo == HIGH){
       coffeeChoice = 2;
   if(coffeeChoice = 1){
     FREservo.write(180);
     if(coffeeMenu == 1){
   lcd.print("FRE<--      COL");
   else{
   lcd.print("                ");
   lcd.print("                ");
   if(coffeeChoice = 2){           //if the coffee choice is Columbian then print the screen indicating the choice and drop in the coffee grounds using the servo
     COLservo.write(180);
   lcd.print("FRE      -->COL");
   else{
   lcd.print("                ");
   lcd.print("                ");
   while(coffeeChoice > 0){             //This section says if a coffe is chosen make sure that the buttons do nothing
   if(coffeeMenu == 0){
    lcd.print(now.day(), DEC);
    lcd.print('/');
    lcd.print(now.month(), DEC);
    lcd.print('/');
    lcd.print(now.year(), DEC);
    lcd.print(' ');
    lcd.setCursor(0, 1);
     if (now.hour()<10)
    lcd.print('0');
    lcd.print(now.hour(), DEC);
    lcd.print(':');
     if (now.minute()<10)
    lcd.print('0');
    lcd.print(now.minute(), DEC);
    lcd.print(':');
    if (now.second()<10)
    lcd.print('0');
    lcd.print(now.second(), DEC);
/*    lcd.setCursor(0, 3);
   int dayofweek = now.dayOfWeek();
   switch(dayofweek){
     case 1:
     lcd.print("Monday");
     case 2:
     lcd.print("Tuesday");
     case 3:
     lcd.print("Wednesday");
     case 4:
     lcd.print("Thursday");
     case 5:
     lcd.print("Friday");
     case 6:
     lcd.print("Saturday");
     case 0:
     lcd.print("Sunday");
else{
   lcd.print("                ");
   lcd.print("                ");
Plus, I am doing this as a school project so everything is at school and I will only be able to test tomorrow.
How are you powering the servo?
Try just disconnecting it and see if it works better. You normally need a seprate supply for a servo due to the noise it generates.
O the servos weren't even connected. i didn't even have the first and second selection button connected either
Can someone please help me. I would love to have this working by tomorrow.
But what have you connected? Disconnect everything. If that doesn't work, start to comment out everything that's new/not needed for the LCD until it works again.
And we all like to finish everything tomorrow! ::slight_smile:
I have the RTC and the LCD connected, thats it. I unplugged the RTC and it still continued the same way. Tomorrow in class I will try to comment out every thing that is new.
Hey, I just found one problem. Unfortunately, another problem has arose. I realised that I had attached one of my servos to a pin that was connected to the LCD. Now the garbled text is gone but my menu button doesn't change the menu on the LCD.
I added a serial.println for coffeemenu and now I see that pressing the button doesn't change the value of coffeemenu
I've just finished similar project. I call it WonderClock. It's an alarm clock with the capability to activate two external loads.
With regards to the garbled display on your LCD, I had a similar issue. Mine was cause by wrong subscript.
Here is a code snippet that will definitely garble LCD display:
char aMyArray[3] = {"Element1","Element2","Element3"};
int nSubscript = 0;
nSubscript--;
lcd.print(aMyArray[nSubscript]);
What happened here is that the nSubscript variable became -1 after the nSubscript-- operation. The only valid values that variable nSubscript can have is 0, 1 and 2. Below and above this, it will be out of bounds and Arduino tells us so in a cryptic way which is, garbled display.
So, what was the cause at your end?
Plus, I know that this is a software issue because I changed it to pin 13 and now when I press the button the onboard LED goes on and off I have attached my modified code.
#include <Wire.h>
#include "RTClib.h"
#include <Servo.h>
RTC_DS1307 RTC;
int coffeeMenu = 0;
int selectionButtonOne = 2; //INSERT PIN NUMBER HERE
int selectionButtonTwo = 4;//INSERT PIN NUMBER HERE
int alarmHour = 0;
int alarmMin = 0;
Servo FREservo;
Servo COLservo;
void setup(){
  FREservo.attach(3);/*INSERT PIN NUMBER HERE*/
  COLservo.attach(5);/*INSERT PIN NUMBER HERE*/
  FREservo.write(0);
  COLservo.write(0);
  pinMode(13, INPUT_PULLUP);
  Wire.begin();
  RTC.begin();
  lcd.begin(16, 2);
  boolean coffeeCurrent = digitalRead(13);
   delay(5);
   delay(5);
  return OneCurrent;
   delay(5);
  return TwoCurrent;
void loop(){
    coffeeMenu = 0;
    lcd.print (":");
    alarmHour = 0;
  if(alarmMin == 60){
    alarmMin = 0;
      alarmHour++;
      alarmMin++;
   else{
   lcd.print("                ");
   lcd.print("                ");
       coffeeChoice = 1;
       coffeeChoice = 2;
   else{
   lcd.print("                ");
   lcd.print("                ");
   else{
   lcd.print("                ");
   lcd.print("                ");
    lcd.print('/');
    lcd.print('/');
    lcd.print(' ');
     if (now.hour()<10)
    lcd.print('0');
    lcd.print(':');
    lcd.print('0');
    lcd.print(':');
    lcd.print('0');
   switch(dayofweek){
     case 1:
     case 2:
     case 3:
     case 4:
     case 5:
     case 6:
     case 0:
else{
   lcd.print("                ");
   lcd.print("                ");
I even attached the two selection buttons and those also aren't showing results
