Hi everyone.
i want to make a differential robot that will draw any shape on the ground. I have 2 stepper motors and esp32.
Now i want that this robot should work on gcode, just like 2d plotters. I feed gcode and robot draws the shape.
How can i do that?
I went through the marlin firmware, marlin arm firmware and grbl. But these firmware are so complex, and i think they will be very hard to edit as well. Furthermore, i could not see any option of differential drive configuration in them.
Should i write my own gcode interpreter and then add the diff drive functionality in it?
Please give some examples of G-code that you will be using. Yes, you will likely need to write an interpreter. What will send your G-code to the robot processor?
Hello robofuntastic
Welcome to the worldbest Arduino forum ever.
I think you are not alone with your project idea.
Take a search engine of your choice and ask the WWW for 'robot +plotter' to collect some data to be sorted out to get the needed information.
this is the example gcode i found https://github.com/Makeblock-official/XY-Plotter-2.0/blob/master/demo/Makeblock-pencil%20G-code%20examples.cnc
and my robot will have to utilise this kind of gcode for movements
Ok, look at the G-code and see what the distance increment is being used for X and for Y movements. That is the goal for your mechanical design. Can you, or have you done that?
i have not done that yet. I wanted to get some idea before starting work on it.
Should i write my own gcode interpreter code?
Probably will need that to begin testing your design!
