I'm new programming in arduino, and I'm trying to make a program that generates a thousand random words and then
print them in serial, how could generate a thousand random words ?.
Regards.
Regards.
Sabths:
Hi,I'm new programming in arduino, and I'm trying to make a program that generates a thousand random words and then
print them in serial, how could generate a thousand random words ?.Regards.
Do they need to be real (ie from a dictionary) words, or random selections of letters?
There may be some details online of the algorithm used in the game Elite to generate random words
You may need more memory, especially if there are more than 1000 words to choose from...
And, that's a LOT of "typing" to create that list within your code!
I assume these are real words that you can find in the dictionary, not just random letters and made-up "words"? You can't "generate" real words without also generating lots of garbage.
It's easier if you want to generate garbage-nonsense "words". The [u]ASCII[/u] characters are from a=97 to z=122 (decimal), so all you have to do is generate random length strings (within whatever length constraints you want) of random chars between 97 and 122.
You can use an array of strings (one word per string) (or a [u]vector[/u] of strings).
Then, you can randomly select the array pointer (which is a "number").
If you want to make it impossible to select the same word twice, there are algorithms for "random selection without replacement". I forgot how these algorithms work, but one way to do it is to delete the word from the array (or vector), shifting-up everything below it and updating the number of items in the array.
AWOL:
You made me squirm there. I was all hands up in the air, back at school going 'Please Miss I know that I know that' ![]()
A small bit of research and memory prodding and it all comes back to me - Francis Spufford wrote the book “Backroom Boys” which describes the development of the Elite game.
[quote author=Mr Spufford]
They could encode all the information on a particular solar system in a relatively short row of digits. That number, it occurred to them, wouldn’t have to be stored if it were an iteration in a Fibonacci sequence – or a Fibonacci-like sequence, anyway. All you would need would be a starting point, a rule for doing the iterations, and a mechanism for extracting the information from the number.[/quote]
I remember reading that book some 25 years ago - great stuff. Thanks for bringing that all back to me.
