I have the Arduino Nano 33 IOT w/Headers. How can I get it to output my gyroscope data in X, Y, Z not just tilting left or right X degrees?
Check Out this Guide
I have used that, but it will not output X, Y, Z coordinates. It just says tilt left 30 degrees, or tilt up 50 degrees.
could you share the code please use <code/> tag ,It make us easier to look upon the code,
Check this out it will Provide raw data of x,y,z
#include <Arduino_LSM6DS3.h>
float x, y, z;
int plusThreshold = 30, minusThreshold = -30;
while (!Serial);
Serial.println("Started");
if (!IMU.begin()) {
Serial.println("Failed to initialize IMU!");
while (1);
Serial.print("Gyroscope sample rate = ");
Serial.print(IMU.gyroscopeSampleRate());
Serial.println(" Hz");
Serial.println("Gyroscope in degrees/second");
if (IMU.gyroscopeAvailable()) {
IMU.readGyroscope(x, y, z);
Serial.print(x);
Serial.print('\t');
Serial.print(y);
Serial.print('\t');
Serial.println(z);
