Get reading from Torque Transducer Sensor
Hello,
I am trying to get some reading from torque sensor by using Arduino. The torque sensor I am using has 6 outputs as shown below with attachments or you can find it in the datasheet as well. would somebody help me in that?
The data sheet of the torque transducer ![ here
Thanks
outputs.JPG](Home - FUTEK Advanced Sensor Technology)
Treek:
Hello,
The data sheet of the torque transducer [ here
Thanks
[/quote]
How do you have it wired? Two pins are input, not output (excitation 10 volts).
Paul](http://www.futek.com/files/pdf/Product%20Drawings/trs300.pdf)
I used pins 1 and 2 for the power (Arduino 5V), and pins 4 and 5 for the signal (I used digital input pin in Arduino for signals). Actually, my code is to measure the difference between two signals, and depend on the signals, I increment or decrement the counter, and if the signals are the same I set the count to zero.
this is my code
int I=12;
int Q=13;
volatile int num;
int num=0;
digitalWrite(s,LOW);
digitalWrite(r,HIGH);
//attachInterrupt(0 , handleEncoder, CHANGE);
Serial.println(num);
delay(10);
//void handleEncoder()
  if(digitalRead(I)> digitalRead(Q))
    num--;
   if (digitalRead(I) < digitalRead(Q))
   num++;
   if (digitalRead(I) == digitalRead(Q))
    num=0;
The problem is that I got the same signal for both signals even when I rotate the torque transducer. I thought maybe my wirings are wrong. Also, I am not sure of pin 6 where it should be connected
Do you have any source for the theory of operation of the device? The web site was no help there.
Paul
It is probably a strain gauge, which means you need a strain gauge amplifier. Obviously, the manufacturer wants you to buy the electronics to go with the sensor.
jremington:
Thanks for the info. Makes perfect sense, now.
The OP needs to Google "rotational strain gauge" and study all the results. Looks like the system uses a Wheatstone bridge and a DC amplifier, as you indicated. Just connecting to an Arduino cannot work in any way.
Paul
Thanks for your info :slight_smile:
