getBytes() not working
I just can't get this to work. My sketch seems to hang when I call this. Here is my code:
#include <Bridge.h>
#include <YunClient.h>
#include <FileIO.h>
YunClient Radio;
byte radioIP[] = { 192, 168, 0, 32 };
#define radioPort 4000
String readString;
String YunIP;
  while (!Serial);
  Serial.println("Started....");
  // Bridge startup
  pinMode(13, OUTPUT);
  digitalWrite(13, LOW);
  Bridge.begin();
  // File I/O startup
  while (!FileSystem.begin());
  digitalWrite(13, HIGH);
  // get the latest IP address of the Yun
  File dataFile = FileSystem.open("/graham/ip.txt", FILE_READ);
  if (dataFile) {
    while (dataFile.available()) {
      readString = dataFile.readString();
      YunIP = readString;
    dataFile.close();
    Serial.println(YunIP);
    // convert IP's to byte arrays
    YunIP.getBytes(radioIP, 4);
  int ret = Radio.connect(radioIP,radioPort);
  Serial.println(ret);
  Serial.println("Listening...");
    delay(50);
The serial monitor:
Started....
192.168.0.32
If I remove the getBytes() call I get:
Started....
192.168.0.32
0
Listening...
Any ideas??
  while (!Serial);
  byte radioIP[4];
  String YunIP = "192.168.000.032";
  for (int i = 0; i < 4; i++) {
    radioIP[i] = (byte) YunIP.substring(i * 4, i * 4 + 3).toInt();
    Serial.println(radioIP[i]);
  delay(2000);
"/graham/ip.txt" format should be "192.168.000.032"
  while (!Serial);
  int commaIndex[4];
  commaIndex[0] = -1;
  byte radioIP[4];
  String YunIP = "192.168.0.32";
  for (int i = 1; i < 4; i++) {
    commaIndex[i] = YunIP.indexOf('.', commaIndex[i - 1] + 1);
    radioIP[i - 1] = (byte) YunIP.substring(commaIndex[i - 1] + 1, commaIndex[i]).toInt();
    //Serial.println(commaIndex[i])
  radioIP[3] = (byte) YunIP.substring(commaIndex[3] + 1).toInt();
    Serial.println( radioIP[i]);
  delay(2000);
"/graham/ip.txt" format should be "192.168.0.32"
