Getting a line to reference array values instead of counting up
Hello. Hopefully what I'm trying to accomplish is clear. Basically, I am trying to modify this code to work with a Pro Micro for PWM control. The pins on the Pro Micro (ATMega32u4 Chipset) are not all PWM. The code by default, uses a ++ to count the pins linearly, but I want to be able to assign pins manually.
So originally its set as, uint8_t curLightsPins = 2, so it sets a starting value, in the case 2, and would count up each pin using kLightsPin(curLightPin++), to assign each button to pins 2, pin 3, etc.
I modified the code so instead of a value that counts +1, it uses a static array of assigned values corresponding with PWM available pins, with an array uint8_t curLightPin [] {6,3,9,5};
Below is the relevant segment of code I am trying to modify, and the link for the git source code is available here: https://github.com/teejusb/fsr/blob/master/fsr.ino
// EXPERIMENTAL. Used to turn on the lights feature. Note, this might conflict
// some existing sensor pins so if you see some weird behavior it might be
// because of this. Uncomment the following line to enable the feature.
#define ENABLE_LIGHTS
// We don't want to use digital pins 0 and 1 as they're needed for Serial
// communication so we start curLightPin from 2.
// Automatically incremented when creating a new SensorState.
**#if defined(ENABLE_LIGHTS)**
**uint8_t curLightPin [] {6,3,9,5};**
#endif
// The class that actually evaluates a sensor and actually triggers the button
// press or release event. If there are multiple sensors added to a
// SensorState, they will all be evaluated first before triggering the event.
class SensorState {
 public:
  SensorState()
      : num_sensors_(0),
        **kLightsPin(curLightPin [0]),**
**        #endif**
**        buttonNum(curButtonNum++)** {
    for (size_t i = 0; i < kMaxSharedSensors; ++i) {
      sensor_ids_[i] = 0;
      individual_states_[i] = SensorState::OFF;
      pinMode(kLightsPin, OUTPUT);
    #endif
  void Init() {
    if (initialized_) {
      return;
    buttonNum = curButtonNum++;
    initialized_ = true;
  // Adds a new sensor to share this state with. If we try adding a sensor that
  // we don't have space for, it's essentially dropped.
  void AddSensor(uint8_t sensor_id) {
    if (num_sensors_ < kMaxSharedSensors) {
      sensor_ids_[num_sensors_++] = sensor_id;
  // Evaluates a single sensor as part of the shared state.
  void EvaluateSensor(uint8_t sensor_id,
                      int16_t cur_value,
                      int16_t user_threshold) {
    if (!initialized_) {
      return;
    size_t sensor_index = GetIndexForSensor(sensor_id);
    // The sensor we're evaluating is not part of this shared state.
    // This should not happen.
    if (sensor_index == SIZE_MAX) {
      return;
    // If we're above the threshold, turn the individual sensor on.
    if (cur_value >= user_threshold + kPaddingWidth) {
      individual_states_[sensor_index] = SensorState::ON;
    // If we're below the threshold, turn the individual sensor off.
    if (cur_value < user_threshold - kPaddingWidth) {
      individual_states_[sensor_index] = SensorState::OFF;
    // If we evaluated all the sensors this state applies to, only then
    // should we determine if we want to send a press/release event.
    bool all_evaluated = (sensor_index == num_sensors_ - 1);
    if (all_evaluated) {
      switch (combined_state_) {
        case SensorState::OFF:
            // If ANY of the sensors triggered, then we trigger a button press.
            bool turn_on = false;
            for (size_t i = 0; i < num_sensors_; ++i) {
              if (individual_states_[i] == SensorState::ON) {
                turn_on = true;
            if (turn_on) {
              ButtonPress(buttonNum);
              combined_state_ = SensorState::ON;
                analogWrite(kLightsPin, 255);
              #endif
        case SensorState::ON:
            // ALL of the sensors must be off to trigger a release.
            // i.e. If any of them are ON we do not release.
            bool turn_off = true;
                turn_off = false;
            if (turn_off) {
              **ButtonRelease(buttonNum);**
**              combined_state_ = SensorState::OFF;**
**              #if defined(ENABLE_LIGHTS)**
**                analogWrite(kLightsPin, 35); //This was originally digitalWrite, but we need analogWrite for brightness control for the LEDS**
              #endif
  // Given a sensor_id, returns the index in the sensor_ids_ array.
  // Returns SIZE_MAX if not found.
  size_t GetIndexForSensor(uint8_t sensor_id) {
      if (sensor_ids_[i] == sensor_id) {
        return i;
    return SIZE_MAX;
 private:
  // Ensures that Init() has been called at exactly once on this SensorState.
  bool initialized_;
  // The collection of sensors shared with this state.
  uint8_t sensor_ids_[kMaxSharedSensors];
  // The number of sensors this state combines with.
  size_t num_sensors_;
  // Used to determine the state of each individual sensor, as well as
  // the aggregated state.
  enum State { OFF, ON };
  // The evaluated state for each individual sensor.
  State individual_states_[kMaxSharedSensors];
  // The aggregated state.
  State combined_state_ = SensorState::OFF;
  // One-tailed width size to create a window around user_threshold to
  // mitigate fluctuations by noise.
  // TODO(teejusb): Make this a user controllable variable.
  const int16_t kPaddingWidth = 1;
  // The light pin this state corresponds to.
    const uint8_t kLightsPin;
  #endif
  // The button number this state corresponds to.
  // Set once in Init().
  uint8_t buttonNum;
I did search tutorials and did my best to Google search, but I cannot find a specific guide for this type of array implementation. I apologize if this is a very beginner question or comes off as "please write my code for me", I'm trying my best. Thank you for any possible assistance.
TL;DR I wan kLightsPin to reference the array values instead of just counting +1 for each assigned pin.
Edit: Ignore the asterisks in the code, I tried bolding it but I didn't realize bolding on the forum post doesn't work when it's also put in as code.
Welcome to the forum
Why not put the pin numbers that you want to access in an array and access them via an index value ?
I was not aware I could do that. I am very new to programming, so please feel free to treat me like I know nothing. I am trying to search for guides but search engines today are awful with giving relevant result, so I don't mind if you just want to link a guide for me to figure it out.
Here is an example of pin numbers in an array. Note that the pin numbers can be in any order that suits you
const byte ledPins[] = { 5, 3, 6, 9 };
const byte LED_COUNT = sizeof(ledPins) / sizeof(ledPins[0]);  //calculate the number of LEDs
    for (int p = 0; p < LED_COUNT; p++)
        pinMode(ledPins[p], OUTPUT);
        analogWrite(ledPins[p], random(256));
Let us know if you have any queries
Tremendous thank you, it is now working as intended. I was able to use the example as a guide for how to implement it. So I took
uint8_t Z = 0;
And so now Z counts +1 and becomes the integer value for pin positions.
kLightsPin(curLightPin [Z++] ),
And my lights are now all PWM controlled. Again thank you very much for posting a useful template for me.
I am glad that it was helpful. Good luck with your project going forward
