I know what some of the people think about AI but, i had AI summarize what i did to get this running. i hope this helps
Title:
UNO Q App Lab + Modbus TCP + qModMaster working example for reading A0, A1, A2 over network
I wanted to share a working setup because I struggled quite a bit getting this running, and I did not find a complete example.
My goal was to use an Arduino UNO Q running App Lab as a Modbus TCP server so that qModMaster could read the first 3 analog inputs over the network.
What I wanted in the end was:
A0, A1, A2 read on the UNO Q
values converted to mV
exposed as Modbus registers
readable from qModMaster over Ethernet/Wi-Fi
For example:
A few important things I learned:
On UNO Q App Lab, I had to use Arduino_RouterBridge.h in the sketch, not Bridge.h. Arduino’s UNO Q App Lab examples use RouterBridge for the sketch/Python communication.
My Python app would immediately crash until I added python/requirements.txt with pymodbus==3.8.1. App Lab uses python/main.py as the entry point and python/requirements.txt for Python dependencies.
I also had to expose the Modbus TCP port in app.yaml using ports: [1502]. In my case app.yaml was view-only in the App Lab editor, so I had to SSH into the board and edit the file there. Arduino documents that App Lab apps live on the board and that SSH access is supported.
qModMaster could connect after that, but Function 03/04 initially gave illegal data address. The fix was changing the PyModbus datastore blocks to start at address 1 instead of 0, then mapping the first 3 channels there. That resolved the addressing issue in my setup.
Below is the working setup I ended with.
App structure
app.yaml
python/
main.py
requirements.txt
sketch/
sketch.ino
sketch.yaml
pymodbus==3.8.1
python/main.py
import traceback
from threading import Thread, Lock
from arduino.app_utils import App, Bridge
print("main.py starting")
try:
import pymodbus
print("pymodbus version:", getattr(pymodbus, "__version__", "unknown"))
from pymodbus.server import StartTcpServer
from pymodbus.datastore import (
ModbusSequentialDataBlock,
ModbusSlaveContext,
ModbusServerContext,
except Exception:
print("PyModbus import failed:")
print(traceback.format_exc())
raise
MODBUS_PORT = 1502
# IMPORTANT:
# In this working setup, using address 1 fixed qModMaster "illegal data address"
# for FC03/FC04 reads.
hr_block = ModbusSequentialDataBlock(1, [0, 0, 0])
ir_block = ModbusSequentialDataBlock(1, [0, 0, 0])
store = ModbusSlaveContext(
hr=hr_block,
ir=ir_block,
context = ModbusServerContext(slaves=store, single=True)
lock = Lock()
def raw_to_mv(raw: int) -> int:
raw = max(0, min(16383, int(raw)))
return int(round(raw * 3300 / 16383))
def update_channel(index: int, raw_value: int):
mv = raw_to_mv(raw_value)
# index 0 -> register 1
# index 1 -> register 2
# index 2 -> register 3
reg_addr = index + 1
with lock:
hr_block.setValues(reg_addr, [mv])
ir_block.setValues(reg_addr, [mv])
print(f"A{index}: raw={raw_value} -> {mv} mV (reg {reg_addr})")
def ai0_value_callback(raw_value: int):
update_channel(0, raw_value)
def ai1_value_callback(raw_value: int):
update_channel(1, raw_value)
def ai2_value_callback(raw_value: int):
update_channel(2, raw_value)
Bridge.provide("ai0_value", ai0_value_callback)
Bridge.provide("ai1_value", ai1_value_callback)
Bridge.provide("ai2_value", ai2_value_callback)
def modbus_server_thread():
try:
print(f"Starting Modbus TCP server on 0.0.0.0:{MODBUS_PORT}")
print("FC03/FC04 registers 0..2 map to A0..A2 in mV")
StartTcpServer(
context=context,
address=("0.0.0.0", MODBUS_PORT),
except Exception:
print("Modbus server thread crashed:")
raise
Thread(target=modbus_server_thread, daemon=True).start()
print("Calling App.run()")
App.run()
sketch/sketch.ino
#include <Arduino_RouterBridge.h>
Bridge.begin();
analogReadResolution(14);
int a0 = analogRead(A0);
int a1 = analogRead(A1);
int a2 = analogRead(A2);
Bridge.call("ai0_value", a0);
Bridge.call("ai1_value", a1);
Bridge.call("ai2_value", a2);
delay(100);
app.yaml
In my case, App Lab showed this file as view-only in the UI, so I had to edit it on the board over SSH.
The important part was:
ports: [1502]
My file ended up looking like this:
name: Corvac Chiller Pressure
icon: 😀
ports: [1502]
bricks: []
qModMaster settings
These are the settings that worked for me:
Function 04 Read Input Registers should also work since I mirrored the values into input registers too.
Register mapping
This is how the final mapping worked:
Register 0 = A0 in mV
Register 1 = A1 in mV
Register 2 = A2 in mV
So if A0 is 1.513 V, qModMaster shows about:
1513
Problems I hit and fixes
Problem 1
#include <Bridge.h> failed with:
fatal error: Bridge.h: No such file or directory
Fix
Use:
Problem 2
Python app started for about 1 second and stopped.
Fix
Create:
with:
pymodbus==3.8.1
Problem 3
qModMaster would not connect.
Fix
Expose the port in app.yaml:
ports: [1502]
Problem 4
qModMaster connected, but FC03/FC04 returned:
Fix
Change the PyModbus data blocks to start at address 1:
That was the piece that finally made the registers readable.
Final result
This now lets me feed 0–3.3 VDC into A0, A1, and A2 on the UNO Q and read those 3 analog inputs over the network from qModMaster as Modbus registers in mV.
Hopefully this saves someone else some time.
