This code was functioning somehow two days ago, but not any more.
I want to receive char c = toupper(Serial.read()); from Serial input and pass the correct command to the TF-luna sensor. If I write "1", then arduino Nano should pass byte message110[] = {0x5A, 0x06, 0x03, 0x0A, 0x00, 0x00}; to the sensor.
Now, when I write "1" or "T", nothing happens with the sensor output. It should be changing the frequency, but isnt.
Thanks for the help.
#include <SoftwareSerial.h> //header file of software serial port
SoftwareSerial Serial1(3, 2); //define software serial port name as Serial1 and define pin2 as RX and pin3
/* For Arduinoboards with multiple serial ports like DUEboard, interpret above two pieces of code and
directly use Serial1 serial port*/
int dist; //actual distance measurements of LiDAR
int strength; //signal strength of LiDAR
float temprature;
int check; //save check value
int i;
int uart[9]; //save data measured by LiDARss
const int HEADER = 0x59; //frame0 header of data package
byte message00[] = {0x5A, 0x06, 0x03, 0x00, 0x00, 0x00};//00
byte message110[] = {0x5A, 0x06, 0x03, 0x0A, 0x00, 0x00};//10hz
byte message120[] = {0x5A, 0x06, 0x03, 0x14, 0x00, 0x00};//20hz
byte message130[] = {0x5A, 0x06, 0x03, 0x1E, 0x00, 0x00};//30hz
byte message160[] = {0x5A, 0x06, 0x03, 0x3C, 0x00, 0x00};//60hz
byte message1100[] = {0x5A, 0x06, 0x03, 0x64, 0x00, 0x00};//100hz
byte message1200[] = {0x5A, 0x06, 0x03, 0xC8, 0x00, 0x00};//200hz
byte messageTrigger[] = {0x5A, 0x04, 0x04, 0x00};// triggermode
byte messagePower[] = {0x5A, 0x06, 0x35, 0x0A, 0x00, 0x00}; // powersave and 10hz
byte messageSave[] = {0x5A, 0x04, 0x11, 0x00}; // Save
Serial.begin(115200); //set bit rate of serial port connecting Arduino with computer
Serial1.begin(115200); //set bit rate of serial port connecting LiDAR with Arduino
if (Serial1.available()) { //check if serial port has data input
if (Serial1.read() == HEADER) { //assess data package frame header 0x59
uart[0] = HEADER;
uart[1] = HEADER;
for (i = 2; i < 9; i++) { //save data in array
uart[i] = Serial1.read();
check = uart[0] + uart[1] + uart[2] + uart[3] + uart[4] + uart[5] + uart[6] + uart[7];
if (uart[8] == (check & 0xff)) { //verify the received data as per protocol
dist = uart[2] + uart[3] * 256; //calculate distance value
Serial.print("dist = ");
Serial.println(dist); //output measure distance value of LiDAR
if (Serial.available()>0){
if ( c == '0'){Serial1.write(message00, sizeof(message00));}
if ( c =='1'){Serial1.write(message110, sizeof(message110));}
if ( c == '2'){Serial1.write(message120, sizeof(message120));}
if ( c == '3'){Serial1.write(message130, sizeof(message130));}
if ( c == '6'){Serial1.write(message160, sizeof(message160));}
if ( c == '7'){Serial1.write(message1100, sizeof(message1100));}
if ( c == '8'){Serial1.write(message1200, sizeof(message1200));}
if ( c == 'T'){Serial1.write(messageTrigger, sizeof(messageTrigger));}
if ( c == 'P'){Serial1.write(messagePower, sizeof(messagePower));}
if ( c == 'S'){Serial1.write(messageSave, sizeof(messageSave));}
