I am trying to simulate gear changes on a motorcycle (that I am displaying on an LCD). For some reason, periodically the RPM calculation goes haywire (becomes very large). It is probably due to my misunderstanding on specifying the correct type of variable to use here.
Does anyone have any suggestions on what/why I may be seeing. I am posting my code, and some of the output over time...
//Global Variables...
float RPM;
int Gear;
long MPH;
This calculates the RPM of the engine for a specific Gear using linear interpolation between two points
This assumes that we "Shift UP" at around 8000 Rpm (arbitrary #)
Based on the Gear ratio's from Suzuki Madura manual...
May want to speed this up by attempting to use integer math.??
and not brake the calculation into several parts.... [b](DONE)[/b]
This has some glitches in it, must be due to overflow's or
some error in variable types.
Broke the calculation into two parts to see where error is occuring... still not making sense to me...
void GetGearRPM(int MPH)
unsigned long Part1,Part2;
static long LastRPM;
if (MPH>=0 && MPH <= 45) {
Gear=1;
Part1=MPH*8000; //break into two parts to see what the error is?????
Part2 = Part1/45;
RPM = Part2 + 45;
} else if (MPH >= 46 && MPH <= 64) {
Gear=2;
Part1=(MPH-46)*2400;
Part2 = Part1/18;
RPM = Part2 + 64;
} else if (MPH >= 65 && MPH <= 82) {
Gear=3;
Part1=(MPH-65)*1700;
Part2 = Part1/17;
RPM = Part2 + 62;
} else if (MPH >= 83 && MPH <= 100) {
Gear=4;
Part1=(MPH-83)*1500;
Part2 = Part1/17;
RPM = Part2 + 100;
} else if (MPH >= 101 && MPH <= 122) {
Gear=5;
Part1=(MPH-101)*1450;
Part2 = Part1/21;
RPM = Part2 + 122;
} else if (MPH >= 123 && MPH < 151) {
Gear=6;
Part1=(MPH-123)*1550;
Part2 = Part1/28;
RPM = Part2 + 151;
} //end if
Serial.print("MPH=");
Serial.print(MPH);
Serial.print(" Gear[");
Serial.print(Gear);
Serial.print("]\t\tPart1=");
Serial.print(Part1);
Serial.print("\tPart2=");
Serial.print(Part2);
Serial.print("\tRPM=");
Serial.print(RPM);
if (RPM > 40000000) {
RPM = LastRPM;
Serial.print(" ERROR in RPM Calculation");
LastRPM = RPM;
Serial.print("--------------------\n\n");
} //end sub
The results I"m seeing....
Starting Large Font Demo Mode
Revision: V11-04/03/14
Showing Menu 1Speeding Up...
MPH=0 Gear[1] Part1=0 Part2=0 RPM=45.00--------------------MPH=1 Gear[1] Part1=8000 Part2=177 RPM=222.00--------------------
MPH=2 Gear[1] Part1=16000 Part2=355 RPM=400.00--------------------
MPH=3 Gear[1] Part1=24000 Part2=533 RPM=578.00--------------------
MPH=4 Gear[1] Part1=32000 Part2=711 RPM=756.00--------------------
MPH=5 Gear[1] Part1=4294941760 Part2=95443150 RPM=95443192.00 ERROR in RPM Calculation--------------------
MPH=6 Gear[1] Part1=4294949760 Part2=95443328 RPM=95443376.00 ERROR in RPM Calculation--------------------
MPH=7 Gear[1] Part1=4294957760 Part2=95443505 RPM=95443552.00 ERROR in RPM Calculation--------------------
MPH=8 Gear[1] Part1=4294965760 Part2=95443683 RPM=95443728.00 ERROR in RPM Calculation--------------------
MPH=9 Gear[1] Part1=6464 Part2=143 RPM=188.00--------------------
MPH=10 Gear[1] Part1=14464 Part2=321 RPM=366.00--------------------
MPH=11 Gear[1] Part1=22464 Part2=499 RPM=544.00--------------------
MPH=12 Gear[1] Part1=30464 Part2=676 RPM=721.00--------------------
MPH=13 Gear[1] Part1=4294940224 Part2=95443116 RPM=95443160.00 ERROR in RPM Calculation--------------------
MPH=14 Gear[1] Part1=4294948224 Part2=95443293 RPM=95443336.00 ERROR in RPM Calculation--------------------
MPH=15 Gear[1] Part1=4294956224 Part2=95443471 RPM=95443520.00 ERROR in RPM Calculation--------------------
MPH=16 Gear[1] Part1=4294964224 Part2=95443649 RPM=95443696.00 ERROR in RPM Calculation--------------------
MPH=17 Gear[1] Part1=4928 Part2=109 RPM=154.00--------------------
MPH=18 Gear[1] Part1=12928 Part2=287 RPM=332.00--------------------
MPH=19 Gear[1] Part1=20928 Part2=465 RPM=510.00--------------------
MPH=20 Gear[1] Part1=28928 Part2=642 RPM=687.00--------------------
MPH=21 Gear[1] Part1=4294938688 Part2=95443081 RPM=95443128.00 ERROR in RPM Calculation--------------------
MPH=22 Gear[1] Part1=4294946688 Part2=95443259 RPM=95443304.00 ERROR in RPM Calculation--------------------
MPH=23 Gear[1] Part1=4294954688 Part2=95443437 RPM=95443480.00 ERROR in RPM Calculation--------------------
MPH=24 Gear[1] Part1=4294962688 Part2=95443615 RPM=95443664.00 ERROR in RPM Calculation--------------------
MPH=25 Gear[1] Part1=3392 Part2=75 RPM=120.00--------------------
MPH=26 Gear[1] Part1=11392 Part2=253 RPM=298.00--------------------
MPH=27 Gear[1] Part1=19392 Part2=430 RPM=475.00--------------------
MPH=28 Gear[1] Part1=27392 Part2=608 RPM=653.00--------------------
MPH=29 Gear[1] Part1=4294937152 Part2=95443047 RPM=95443088.00 ERROR in RPM Calculation--------------------
MPH=30 Gear[1] Part1=4294945152 Part2=95443225 RPM=95443272.00 ERROR in RPM Calculation--------------------
MPH=31 Gear[1] Part1=4294953152 Part2=95443403 RPM=95443448.00 ERROR in RPM Calculation--------------------
MPH=32 Gear[1] Part1=4294961152 Part2=95443581 RPM=95443624.00 ERROR in RPM Calculation--------------------
MPH=33 Gear[1] Part1=1856 Part2=41 RPM=86.00--------------------
MPH=34 Gear[1] Part1=9856 Part2=219 RPM=264.00--------------------
MPH=35 Gear[1] Part1=17856 Part2=396 RPM=441.00--------------------
MPH=36 Gear[1] Part1=25856 Part2=574 RPM=619.00--------------------
MPH=37 Gear[1] Part1=4294935616 Part2=95443013 RPM=95443056.00 ERROR in RPM Calculation--------------------
MPH=38 Gear[1] Part1=4294943616 Part2=95443191 RPM=95443232.00 ERROR in RPM Calculation--------------------
MPH=39 Gear[1] Part1=4294951616 Part2=95443369 RPM=95443416.00 ERROR in RPM Calculation--------------------
MPH=40 Gear[1] Part1=4294959616 Part2=95443547 RPM=95443592.00 ERROR in RPM Calculation--------------------
MPH=41 Gear[1] Part1=320 Part2=7 RPM=52.00--------------------
MPH=42 Gear[1] Part1=8320 Part2=184 RPM=229.00--------------------
MPH=43 Gear[1] Part1=16320 Part2=362 RPM=407.00--------------------
MPH=44 Gear[1] Part1=24320 Part2=540 RPM=585.00--------------------
MPH=45 Gear[1] Part1=32320 Part2=718 RPM=763.00--------------------
MPH=46 Gear[2] Part1=0 Part2=0 RPM=64.00--------------------
MPH=47 Gear[2] Part1=2400 Part2=133 RPM=197.00--------------------
MPH=48 Gear[2] Part1=4800 Part2=266 RPM=330.00--------------------
MPH=49 Gear[2] Part1=7200 Part2=400 RPM=464.00--------------------
MPH=50 Gear[2] Part1=9600 Part2=533 RPM=597.00--------------------
MPH=51 Gear[2] Part1=12000 Part2=666 RPM=730.00--------------------
MPH=52 Gear[2] Part1=14400 Part2=800 RPM=864.00--------------------
MPH=53 Gear[2] Part1=16800 Part2=933 RPM=997.00--------------------
MPH=54 Gear[2] Part1=19200 Part2=1066 RPM=1130.00--------------------
MPH=55 Gear[2] Part1=21600 Part2=1200 RPM=1264.00--------------------
MPH=56 Gear[2] Part1=24000 Part2=1333 RPM=1397.00--------------------
MPH=57 Gear[2] Part1=26400 Part2=1466 RPM=1530.00--------------------
MPH=58 Gear[2] Part1=28800 Part2=1600 RPM=1664.00--------------------
MPH=59 Gear[2] Part1=31200 Part2=1733 RPM=1797.00--------------------
