Getting faster scan time for bluetooth using nano esp32
Hi. I'm working on a project using Nano ESP32s that will turn on LEDs if they get within a certain range of another device with the same name. I am using the bluetooths RSSI as a way to determine their proximity to each other, and I'm using a kalman filter to smooth out some of the noise in that signal. This method does work fairly well for getting the distance pretty close, but the shortest scantime being 1 second is way too slow. I'm working in distances of at most a foot, so a lot of movement can happen in 1 second. Is there any way to scan faster?
  Bluetooth Proximity
  This example scans for Bluetooth® Low Energy peripherals with a specific name, and then turns on LEDs if within a certain range
  The circuit:
  - Arduino Nano ESP32
  SimpleKalmanFilter(e_mea, e_est, q);
  e_mea: Measurement Uncertainty
  e_est: Estimation Uncertainty
  q: Process Noise
#include <BLEDevice.h>
#include <BLEUtils.h>
#include <BLEScan.h>
#include <BLEAdvertisedDevice.h>
#include <SimpleKalmanFilter.h>
int scanTime = 1; //In seconds
BLEScan* pBLEScan;
const int CUTOFF = -42;   // signal strength limit (closer to 0 the closer the devices have to be)
bool flip = true;
const int led = 9;              // the PWM pin the LED is attached to
int brightness = 0;             // how bright the LED is
int fadeAmount = 5;             // how many points to fade the LED by
unsigned long ledTimePrev = 0;  // will store last time pin 9 was update
const long ledInterval = 30;    // interval at which to fade led
bool inRange = false;
SimpleKalmanFilter bleFilter(4, 4, .1);
const long SERIAL_REFRESH_TIME = 1;
long refreshTime;
class MyAdvertisedDeviceCallbacks: public BLEAdvertisedDeviceCallbacks {
    void onResult(BLEAdvertisedDevice advertisedDevice) {
      // Serial.printf("Advertised Device: %s \n", advertisedDevice.toString().c_str());
      String strName;
      strName = advertisedDevice.getName().c_str();
      if ( strName == "SS13" ) {
        float signal = advertisedDevice.getRSSI();
        float estimatedSignal = bleFilter.updateEstimate(signal);
        if (millis() > refreshTime) {
          refreshTime = millis() + SERIAL_REFRESH_TIME;
        if (estimatedSignal > CUTOFF) {                  // device is in range
          inRange = true;
        } else {                                        // device is out of range
          inRange = false;
  Serial.println("Scanning...");
  pinMode(LED_RED, OUTPUT);
  if (flip) {
    brightness = 255;
  BLEDevice::init("SS13");
  BLEDevice::startAdvertising();
  pBLEScan = BLEDevice::getScan(); //create new scan
  pBLEScan->setAdvertisedDeviceCallbacks(new MyAdvertisedDeviceCallbacks());
  pBLEScan->setActiveScan(true); //active scan uses more power, but get results faster
  pBLEScan->setInterval(100);
  pBLEScan->setWindow(99);  // less or equal setInterval value
  BLEScanResults foundDevices = pBLEScan->start(scanTime, false);
  fadeLED(LED_RED);
  pBLEScan->clearResults();   // delete results fromBLEScan buffer to release memory
void fadeLED(int l) {
  if (currentMillis - ledTimePrev >= ledInterval) {
    // save the last time you blinked the LED
    ledTimePrev = currentMillis;
    if (flip) {
      if (inRange && brightness > 0) {        // if in range and less than max, increase
        brightness = brightness - fadeAmount;
      } else if (!inRange && brightness < 255) {  // if out of range and greater than 0, decrease
        brightness = brightness + fadeAmount;
      if (inRange && brightness < 255) {        // if in range and less than max, increase
      } else if (!inRange && brightness > 0) {  // ir out of range and greater than 0, decrease
    // set brightness
    analogWrite(l, brightness);
Since Bluetooth is a documented standard communication method, is there anything in the standard relating to scantimes?
I don't know. I've never worked with bluetooth before. And I have tried searching the forums here, and just googled in general, and haven't found an answer yet.
Well, consider what the other devices will do when scanned too often. It will be unusable until the faster scans stop. So what ever the other device is doing will be interrupted time after time.
The other devices are all running the same code. There's no bluetooth connection, just looking to see if there is a device with the same name, and what is its distance if so. There shouldn't be any interrupting.
All other Bluetooth devices will be listening and looking for their address, won’t they?
Looking for a name, not an address. The code works, so I don't know what you're trying to get at here. All I want to know is can it be done faster? Or is there a better approach?
You can't go lower than 1s like that.
But did you ever try continuous scanning, it supposed to be non blocking.
Also, NimBLE might work better.
Thanks for the suggestions. I hadn't realized the scanning wasn't continuous, but I'm looking into NimBLE.
