Getting HTTP:408 request timeout error with arduino+sim900 gsm module
I want to send sensors' data to mysql, I am using TCP/IP method to post the data on the web server using Arduino+SIM900 GSM module.
I am using AT commands. I am getting an error as HTTP/1.1 408 REQUEST TIMEOUT Date: Thu. 19 May 2016 06:53:52 GMT after 60 seconds when SEND OK has appeared.
(I am using TMFT terminal software).
Here are my AT Commands-
at
at+cipshut
at+cipmux=0
at+cgatt=1
at+cstt="airtelgprs.com","",""
at+ciicr
at+cifsr
at+cipsprt=1
at+cipstart="tcp","0.0.0.0","8080" //my server address and port
at+cipsend
//after prompt has appeared
POST /conn.php?id_dev=NO&frame_number=1&sensor=temp&value=20 HTTP/1.1
Host: 0.0.0.0:8080 //my server add.
Connection: keep-alive
(ctrl +Z)
Reply from arduino is SEND OK and after sometime i am getting this timeout error.
:disappointed_relieved:
thank you in advance.
(ctrl +Z)
It's silly to POST when all the data is in the request. Use GET, instead.
thank you for your reply sir,
I also used GET, still it is showing the same timeout error.
