Getting Jaycar MS 6147 Power switch working with Uno
Has anyone had success getting the Jaycar MS6147 Remote Controlled 3 Outlet Mains Controller working with Arduino Uno? The remote control is labelled Powertech Random Code transmitter and says it works at 433.92 MHz. The mains outlets work fine with the supplied remote but I have had no success either sending codes with Jaycar ZW3100 transmitter or the receiving codes with the ZW3102 receiver. I am using the RCSwitch.h library but none of the examples I have tried work. I am presuming the power outlets are of the ‘Intertechno’ type as they are self-learning receivers without dip switches. I have identified lots of semi-relevant links but none totally solve the problem.
Looks like I had (at least a partial) solution all along. It was “Minimal_433MHz_Controller_for_MS6148” which was on my hard disk but apparently no longer available at https://www.jaycar.com.au/RTCpowerpointtimer
It is.
https://assets.contentstack.io/v3/assets/blt7eae2e8ef79b5522/blt609334492ee834e1/67aed14ec9c106aaf4437c9c/RTC-Power-Point-Timer.zip?branch=prod
Keeping it here for posterity ;)
RTC-Power-Point-Timer.zip (494.6 KB)
