GIGA R1 attachInterrupt crashes the board
Hey folks. I'm working on a project which involves using two water flow sensors. i have interfaced it using the GIGA R1 board. I'm not very much familiar with the interrupts so i just added a pre-existing flow sensor code into my main code which looks like this:
//Libraries
  #include <Wire.h>
  #include <WiFi.h>
  #include <math.h>
  #include "Variables.h"
  #include "PinAssign.h"
  #include "MyConstants.h"
  #include "ExternalFlash.h"
  #include "thingProperties.h"
// Interrupt Service Routines
  void flow1ISR() {
     flow1++;
   void flow2ISR() {
     flow2++;
 void select_channel(uint8_t channel){
  Wire.beginTransmission(PCA9548A);
  Wire.write(1 << channel);
  Wire.endTransmission();
 int count;
void setup(){
  Wire.begin();
  //WiFi connection
    WiFi.begin(SSID, PASS);
      Serial.print(".");
    Serial.println("");
    Serial.println("WiFi connected");
    Serial.println("IP address: ");
  //Arduino cloud setup
    // Defined in thingProperties.h
    initProperties();
    // Connect to Arduino IoT Cloud
    ArduinoCloud.begin(ArduinoIoTPreferredConnection);
      The following function allows you to obtain more information
      related to the state of network and IoT Cloud connection and errors
      the higher number the more granular information you’ll get.
      The default is 0 (only errors).
      Maximum is 4
    setDebugMessageLevel(2);
    ArduinoCloud.printDebugInfo();
    // Wait for a successful connection to Arduino IoT Cloud
    Serial.print("Waiting for Arduino IoT Cloud connection...");
    while (!ArduinoCloud.connected()) {
      ArduinoCloud.update();
      Serial.print(".");
    Serial.println("");
    Serial.println("Connected to Arduino IoT Cloud");
  //Enable USB-A port
    pinMode(PA_15, OUTPUT);
    //Connect GIGA to USB port
    digitalWrite(PA_15,HIGH);
    msd.connect();
     Serial.print("Connecting to port...");
    while(!msd.connect()){
      Serial.print(".");
    Serial.println("");
  //Float pins
    pinMode(top1,INPUT); //Float 1 top
    pinMode(bottom1,INPUT); //Float 1 bottom
    pinMode(top2,INPUT); //Float 2 top
    pinMode(bottom2,INPUT); //Float 2 bottom
    Serial.println("Float pins initiated\n");
  //Flow Sensor pins
    pinMode(FLOW_SENSOR_1, INPUT_PULLUP);
    pinMode(FLOW_SENSOR_2, INPUT_PULLUP);
    // Attach the interrupts
    attachInterrupt(digitalPinToInterrupt(FLOW_SENSOR_1), flow1ISR, RISING);
    attachInterrupt(digitalPinToInterrupt(FLOW_SENSOR_2), flow2ISR, RISING);
 //Valve relays
    pinMode(t1d,OUTPUT);
    digitalWrite(t1d,LOW);
    pinMode(t2d,OUTPUT);
    digitalWrite(t2d,LOW);
    // pinMode(t1r,OUTPUT);
    // pinMode(t2r,OUTPUT);
    pinMode(dt1,OUTPUT);
    digitalWrite(dt1,LOW);
    pinMode(dt2,OUTPUT);
    digitalWrite(dt2,LOW);
    // pinMode(rt1,OUTPUT);
    // pinMode(rt2,OUTPUT);
    Serial.println("Valve relays defined\n");
  //12V Relays
    // pinMode(h1,OUTPUT);
    // pinMode(h2,OUTPUT);
    //Serial.println("Heater relays defined\n");
    //delay(1000);
  //Pump Relays
    pinMode(dsp,OUTPUT);
    digitalWrite(dsp,LOW);
    pinMode(drp,OUTPUT);
    digitalWrite(drp,LOW);
    // pinMode(rsp,OUTPUT);
    // pinMode(rrp,OUTPUT);
    pinMode(dpc1,OUTPUT);
    digitalWrite(dpc1,LOW);
    pinMode(dpc2,OUTPUT);
    digitalWrite(dpc2,LOW);
    Serial.println("Pump relays defined\n");
  //Fan Relays
    //pinMode(rf,OUTPUT);
    pinMode(df,OUTPUT);
    pinMode(fcu,OUTPUT);
    Serial.println("Fan relays defined\n");
    digitalWrite(df,LOW);
    digitalWrite(fcu,LOW);
  //Mount Cruzer-Blade
    Serial.println("Mounting Cruzer Blade (16GB)...\n");
    int err =  usb.mount(&msd);
    if (err) {
      Serial.print("Error mounting Cruzer Blade ");
      Serial.println(err);
      while (1);
  if(digitalRead(bottom1) == HIGH){
    lowTrig1 = true;
    tank1_active = true;
    Serial.println("Default float 1");
  else {
    // Read the value of lowTrig1 from the file
    FILE *f = fopen("/usb/lowTrig1.txt", "r");
    if (f) {
      char buffer[10];
      fgets(buffer, sizeof(buffer), f);
      fclose(f);
      lowTrig1 = (buffer[0] == '1') ? 1 : 0;
      prevLowTrig1 = lowTrig1;
      Serial.println("Reading lowTrig1 from Cruzer Blade");
    // Read the value of lowTrig2 from the file
    FILE *g = fopen("/usb/lowTrig2.txt", "r");
    if (g) {
      char buffer[10];
      fgets(buffer, sizeof(buffer), g);
      fclose(g);
      lowTrig2 = (buffer[0] == '1') ? 1 : 0;
      prevLowTrig2 = lowTrig2;
      Serial.println("Reading lowTrig2 from Cruzer Blade");
  // // Configure the interrupt pins
  //   pinMode(FLOW_SENSOR_1, INPUT_PULLUP);
  //   pinMode(FLOW_SENSOR_2, INPUT_PULLUP);
    previousTime = millis();
 //SHT connection
    //Precision setting
      Precision = PRECISION_HIGH;
      Heater = NO_HEATER;
    // Initialize first sensor
      select_channel(SENSOR1_CHANNEL);
      Serial.println("Initializing first ES13511 sensor\n");
      ES135xx_probe();
    // Initialize second sensor
      select_channel(SENSOR2_CHANNEL);
      Serial.println("Initializing second ES13511 sensor\n");
      ES135xx_probe();
 //Temp sensor
    // Start up the library
      sensors.begin();
void loop(){
  //On-board timer
  currentTime   = millis();
  if(WiFi.status() == WL_CONNECTED){
    if(currentTime - lastupdate >= updateInterval){
      Serial.println("\nCloud Update");
      lastupdate = currentTime;
  if(!testswitch){
    if(power_Switch){
      Serial.println("\nSystem ON");
      if(power){
        digitalWrite (df,HIGH);
        digitalWrite (fcu,HIGH);
        digitalWrite(dsp, LOW);
        Serial.println("Fans ON");
        serial_Monitor = "SYSTEM ON";
        printonce = true;
        power = false;
      onFanswitchChange();
      FloatSensorReading();
      SensorReadings();
      Dehumidification();
      Cooling();
      onResetChange();
    else if (!power_Switch){
    onPowerSwitchChange();
    SensorReadings();
  else{
    onTestSwitchChange();
    SensorReadings();
Sensor reading function:
void SensorReadings(){
  //SHT reading
  extern float ES135xx_Temp;
  extern float ES135xx_Hum;
  //Storage room sensor
  ES135xx_read_T_H();
  storage_hum = ES135xx_Hum;
  storage_temp = ES135xx_Temp;
  Serial.print("Storage Temp = " + String(ES135xx_Temp) + " C " + " Storage RH = " + String(ES135xx_Hum) + "% | ");
  storage_Humidity = storage_hum;
  storage_Temperature = storage_temp;
  // Utility sensor
  ES135xx_read_T_H();
  utility_hum = ES135xx_Hum;
  utility_temp = ES135xx_Temp;
  Serial.println("Utility Temp = " + String(ES135xx_Temp) + " C " + " Utility RH = " + String(ES135xx_Hum) + "%");
  //DS18B20
    // call sensors.requestTemperatures() to issue a global temperature and Requests to all devices on the bus
    sensors.requestTemperatures();
    Temp_tank2 = sensors.getTempCByIndex(1);// Why "byIndex"? You can have more than one DS18B20 on the same bus. 0 refers to the first IC on the wire
    Temp_tank1 = sensors.getTempCByIndex(0);// Why "byIndex"? You can have more than one DS18B20 on the same bus. 1 refers to the second IC on the wire
    //Calibration
    /*float rawTempC = sensors.getTempCByIndex(0);
    float calibratedTempC = rawTempC + CALIBRATION_OFFSET;
    if(rawTempC == -127.00)
      Serial.println("Error: Could not read temperature data");
      Serial.print("Temperature: ");
      Serial.println(calibratedTempC);
    Serial.println("Temperature 1: " + String(Temp_tank1) + " C " + "| Temperature 2: " + String(Temp_tank2) + " C");
  //Flow Sensor
    // Disable the interrupts
    detachInterrupt(digitalPinToInterrupt(FLOW_SENSOR_1));
    detachInterrupt(digitalPinToInterrupt(FLOW_SENSOR_2));
    // Calculate the flow rate in L/min and apply the calibration factor
    float flowRate1 = (flow1 / 7.5) * CALIBRATION_FACTOR_1;
    float flowRate2 = (flow2 / 7.5) * CALIBRATION_FACTOR_2;
    // Print the calibrated flow rates
    Serial.print("Calibrated flow rate sensor 1: ");
    Serial.print(flowRate1);
    Serial.println(" L/min");
    Serial.print("Calibrated flow rate sensor 2: ");
    Serial.print(flowRate2);
    // Reset the pulse counters
    flow1 = 0;
    flow2 = 0;
    // Reattach the interrupts
  //Cloud Variables
    utility_Humidity = utility_hum;
    utility_Temperature = utility_temp;
    tank1_Temp = Temp_tank1;
    tank2_Temp = Temp_tank2;
    flowSensor_Dsupply = flowRate1;
    flowSensor_Dreturn = flowRate2
void FloatSensorReading () {
    // if(!check && digitalRead(top1) == LOW && digitalRead(bottom1) == HIGH){
    //     lowTrig1 = true;
    //     tank1_active = true;
    if(!check &&  digitalRead(top1) == HIGH){
        tank1_active = false;
        lowTrig1 = false;
        Serial.println("Warning, weak desiccant in tank 1. Checking tank 2");
        serial_Monitor = "Warning!, weak desiccant in tank 1";
        digitalWrite(drp, LOW);
        digitalWrite(t1d, LOW);
        digitalWrite(dt1, LOW);
        if(digitalRead(top2) == LOW){
            tank2_active = true;
            lowTrig2 = true;
            printonce = true;
            pumpdelaytime = currentTime;
            drpdelaytime = currentTime;
            serial_Monitor="Tank 2 active";
            Serial.println("Assigning tank 2");
        else if(digitalRead(top2) == HIGH){
            tank2_active = false;
            lowTrig2 = false;
            Serial.println("Weak desiccant in tank 2...Turning off dehumidifier");
            serial_Monitor = "Weak desiccant in tank 2. Turning off dehumidifier";
            add_salt = true;
            dehumidifier_status = false;
        check = true;
        Serial.println("Switching complete");
    else if(check && digitalRead(top2) == HIGH && digitalRead(bottom2) == LOW){
        lowTrig2 = false;
        serial_Monitor = "Warning, weak desiccant in tank 2.";
        add_salt = true;
  // If the value of lowTrig1 and lowTrig2 has changed, write it to the file
  if (lowTrig1 != prevLowTrig1) {
    FILE *f = fopen("/usb/lowTrig1.txt", "w");
    if (f) {
      fprintf(f, "%d", lowTrig1);
      fclose(f);
      Serial.println("Updating float 1 position...");
      serial_Monitor = "Updating float 1 position";
  if (lowTrig2 != prevLowTrig2) {
    FILE *g = fopen("/usb/lowTrig2.txt", "w");
    if (g) {
      fprintf(g, "%d", lowTrig2);
      fclose(g);
      Serial.println("Updating float 2 position...");
      serial_Monitor = "Updating float 2 position";
  Serial.println("Float status 1: " + String(lowTrig1) + ", Float status 2: " + String(lowTrig2));
  if(lowTrig1){
    Serial.print("Tank 1: ACTIVE | ");
  else if (!lowTrig1){
    Serial.print("Tank 1: INACTIVE | ");
  if(lowTrig2){
    Serial.println("Tank 2: ACTIVE");
  else if(!lowTrig2){
    Serial.println("Tank 2: INACTIVE");
the board crashes (red light blinking) at the 'attachInterrupts' in the void setup function right after initializing the pins. I tried removing it from the setup, but it just crashes when it encounters it in the loop (void sensor reading function). The code works perfectly fine as a standalone. I can't figure out how to solve this.
any help would be appreciated. Thanks
Just to clarify. i have declared flow1 and flow2 as extern volatile int in Variables.h header file and i have also initialized volatile int flow1 = 0; and volatile int flow2 = 0; in a seperate .ino file
Found this useful thread : Arduino Giga R1 crashes with attach interrupt · Issue #789 · arduino/ArduinoCore-mbed · GitHub
Hi @Heinrich222 , the Giga allows a maximum of 16 interrupts at the same time, and the coexistence is based on STM32 peculiar way of handling them (like, PA_0 will share the interrupt with PB_0 , PC_0 and so on). If you instantiate 2 interrupts on the same line the board will "crash" (report it as invaliud).
To associate pin name and pin number you can use this table ArduinoCore-mbed/variants/GIGA/variant.cpp at main · arduino/ArduinoCore-mbed · GitHub
Turns out the Dpin 4 caused the issue. The pin description for Dpin 4 and the Dpin 8 which is used for my USB flash drive connected to my GIGA are PJ_8 and PB_8 respectively. Apparently pins with same description share the same interrupt? not entirely sure but it worked when i assigned a different pin which didn't match the pin definition of the pins already in use.
