GIGA R1 I2C Slave: 500ms SCL Stretching during Address ACK after a Repeated Start
Hi everyone,
I am using an Arduino GIGA R1 (Mbed-based) as an I2C Slave to emulate a touch IC (Address 0x01). I've encountered a severe performance bottleneck where the GIGA stretches the SCL line for exactly 500ms during a specific communication sequence.
The Context: The host (an automotive head unit) uses a Repeated Start (Sr) to transition from a Write operation to a Read operation without sending a STOP bit.
The Evidence (Logic Analyzer Capture): I have attached a screenshot which clearly shows the "crime scene":
  1. Phase 1 (Write): The GIGA responds normally to Setup Write to [0x01] and receives the data byte 0x04 successfully.
  2. Phase 2 (The Transition): Instead of a STOP bit, the host issues a Repeated Start (SDA goes LOW while SCL is HIGH).
  3. Phase 3 (The Failure): The host immediately sends the Setup Read to [0x01] address.
  4. The Bug: Right after the 8th bit of the Read address, the GIGA pulls SCL LOW for ~500ms before finally releasing it and providing an ACK.
Observations:
  • This happens consistently on both reserved (0x01) and standard (0x11) addresses.
  • The 500ms delay feels like a hard-coded Bus Timeout or a recovery mechanism within the ArduinoCore-mbed layer.
  • My code is minimal (empty onReceive and onRequest handlers), yet the hardware/OS level latency remains.
My Questions:
  1. Is the Mbed OS I2C Slave driver known to have issues handling a "Receiver to Transmitter" role switch during a Repeated Start?
  2. Is there a way to increase the priority of the I2C interrupt or bypass the EventQueue to ensure the onRequest buffer is filled faster?
  3. Where can I find the 500ms timeout constant in the core files to confirm if this is a driver-level reset?
This latency makes the GIGA unusable for any high-speed I2C emulation where the host expects a response within microseconds, not half a second. Any insights or workarounds would be greatly appreciated.
Thanks!
Just off the top of my head, isn't there a configurable clock speed? See if this helps
"I tried setClock(), but it made things worse. As you can see :
the GIGA now returns NAK for every single address frame from the host. It seems the Mbed I2C implementation is very sensitive to timing configurations in Slave mode.
I suspect the 500ms stretching is a 'bus recovery' timeout triggered by the core. Does anyone know how to safely bypass the Mbed abstraction and disable the I2C_TIMEOUTR on the GIGA R1 to stop this forced SCL pulling?"
HI @zoneyourcalm . Could this git issue be what you're seeing? STM32 I2CSlave race condition causing timeouts · Issue #15498 · ARMmbed/mbed-os · GitHub
The associated PR fix has been applied to ARMs mbed-os repo but Arduino have not applied it to theirs.
