Hi all,
I'm reading a NAU7802 24-bit ADC (I2C, addr 0x2A) over the GIGA R1 M7's hardware Wire (SDA=20/SCL=21, 400kHz). A plain address-only I2C scan (Wire.beginTransmission(addr); Wire.endTransmission();) reliably detects the chip. But actual register reads using the common two-step pattern:
Wire.beginTransmission(0x2A);
Wire.write(regAddress);
Wire.endTransmission(); // full STOP
Wire.requestFrom(0x2A, 1);
...were unreliable — intermittently returning stale/zero data, even though the device itself was confirmed alive and healthy (verified with an independent multimeter/analog check, and by re-testing the exact same physical device with a different read pattern below).
Switching to a repeated start fixed it completely and has been 100% reliable since:
Wire.endTransmission(false); // repeated start, no STOP
This perhaps also explains why a popular Arduino library ( Sparkfun) for this chip (which uses the endTransmission() + separate requestFrom() pattern, i.e. STOP then new START) gave us unreliable readings on GIGA R1 specifically, while our own minimal register-level code with endTransmission(false) works reliably.
Questions:
- Is there a known timing issue with GIGA R1's mbed-based
Wire/TwoWireimplementation not honoring the I2C bus-free-time (t_BUF) between a STOP and the next START closely enough, causing this kind of intermittent failure? - Is this specific to GIGA R1 (STM32H747, mbed core), or would this also affect classic AVR-based boards (Uno/Mega) using the same
endTransmission()-then-requestFrom()pattern? - Is
endTransmission(false)(repeated start) simply the recommended practice on GIGA R1 for any register-read I2C device, regardless of library?
Any insight into the root cause (or confirmation this is a known GIGA R1/mbed core quirk) would be much appreciated — happy to share more logs/test code if useful.
Board: Arduino GIGA R1 WiFi (M7 core)
Framework: Arduino-mbed core via PlatformIO
