Giga R1 RTC, NTP and IoT cloud problem
Hi eveyrone,
I have a problem that's been bugging me for a while now. Every now and then I read some fragments of new information but I've been unable to find a solution.
I have a Giga, connected to the arduino IoT cloud with a subsciption. I set the onboard RTC by calling a NTP server and I have an external battery connected to keep it running when power fails. I use a timezone and daylight saving offset, each of +1. Normally this is running fine but two things sem to throw a spanner in the gears.
  1. apparently 24h after boot the cloud automatically syncs the RTC. Great in theory but it puts it back 2 hours. So it disregards my timezone and DST.
  2. When I lose connection to the IoT cloud the same thing happens. I'm still connected to WiFi but the clock jumps back 2 hours.
I'm now calling the NTP every 10 minutes for an update but it might as well be every 1 minutes with these shenanigans.
The full code is massive so I'll post the bits related to the NTP and RTC here and the full code in the next post below.
#include <mbed_mktime.h>
#include <NTPClient.h>
#include <Timezone.h>
//NTP and RTC
WiFiUDP Udp; // A UDP instance to let us send and receive packets over UDP
NTPClient ntpClient(Udp, "europe.pool.ntp.org", 3600, 10000); //3600 for GMT +1 /call update only every 10 seconds
unsigned long lastUpdate = 60 * 60 * 24 * 1000UL; //86400000; //24h
unsigned long printNow{}; // = 0;
bool setRTC = false;
bool updatedYet = true;
TimeChangeRule mySTD = {"CET", Last, Sun, Nov, 2, 0};     // Standard time = GMT +1 hours already accounted for in ntpClient
TimeChangeRule myDST = {"CEST", Last, Sun, Mar, 2, 60};    // Daylight saving time = STD +1 hour
Timezone myTZ(myDST, mySTD);
TimeChangeRule *tcr;
uint8_t status = WL_IDLE_STATUS;
unsigned long checkNTP = 0;
  Serial1.begin(38400);
  while (status != WL_CONNECTED) { // attempt to connect to WiFi network:
    Serial.print("Attempting to connect to: ");
    Serial.println(SSID);
    status = WiFi.begin(SSID, PASS);
    delay(5000);
  initProperties(); // Defined in thingProperties.h
  ArduinoCloud.begin(ArduinoIoTPreferredConnection); // Connect to Arduino IoT Cloud
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  ntpClient.begin();
  ArduinoCloud.update();
  if (millis() - wifiTime >= 1000) { //wifi and cloud status led and RTC
    if (status != WL_CONNECTED) {
      digitalWrite(LEDB, HIGH);
      digitalWrite(LEDR, LOW);
    if (status = WL_CONNECTED) {
      if (!ArduinoCloud.connected()) {
        digitalWrite(LEDR, HIGH);
      if (ArduinoCloud.connected()) {
        digitalWrite(LEDB, LOW);
      if (setRTC == false) {  // Set RTC once on startup
        updateTime();
      if (millis() - lastUpdate >= (60 * 60 * 24 * 1000UL)) {  // reset e-mail notifications every 24hrs
        lastUpdate = millis();
        emailSent = false; //piggyback reset for e-mail notifications
    wifiTime = millis();
  if (millis() - checkNTP >= 60 * 10 * 1000UL) {  //update RTC 10 minutes
    setRTC = false;
    checkNTP = millis();
void updateTime() {
  ntpClient.forceUpdate();
  if (ntpClient.isTimeSet()) {
    unsigned long ntpTime = ntpClient.getEpochTime(); // ntpTime = epoch
    time_t localTime = myTZ.toLocal(ntpTime, &tcr);
    set_time(localTime);
    Serial.println("RTC is set");
    setRTC = true;
full code:
  Sketch generated by the Arduino IoT Cloud Thing "Giga"
  https://create.arduino.cc/cloud/things/1170c289-7b0d-4273-8557-9c30106bd3cc
  Arduino IoT Cloud Variables description
  The following variables are automatically generated and updated when changes are made to the Thing
  float airTempAverage;
  float humidityAverage;
  float pressureAverage;
  Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
  which are called when their values are changed from the Dashboard.
  These functions are generated with the Thing and added at the end of this sketch.
#include "arduino_secrets.h"
#include "thingProperties.h"
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
#include <SPI.h>
#include <Wire.h>
#include <SHT31.h>
#include <DHT.h>
#include <Bme280.h>
#include <WiFi.h>
#include <WiFiUdp.h>
#include <I2C_eeprom.h>
#include <EMailSender.h>
#include <MultiMap.h>
//for updating desired settings during transition between values
typedef void (*TransitionCallback)(float);
#define DEBUG 1
#if DEBUG == 1
#define outputDebug(x); Serial.print(x);
#define outputDebugln(x); Serial.println(x);
#else
#endif
//EEPROM
#define eepromLength 32768
I2C_eeprom EEPROM(0x50, eepromLength);
#define desiredTemp 70 //EEPROM address for settings configurable by user
#define desiredHumi 71
#define dayTemperature 64
#define nightTemperature 65
//TFT screen
#define TFT_CS        10
#define TFT_RST       9 // Or set to -1 and connect to Arduino RESET pin
#define TFT_DC        8
#define TFT_MOSI      7  // Data out --- SDA pin on TFT
#define TFT_SCLK      6  // Clock out --- SCL pin on TFT
Adafruit_ST7789 myScreen = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
//sensors
#define DHT22_PIN 11
#define DHT22_PIN_2 12
#define DHTTYPE DHT22
#define ThermistorPin A11
#define Thermistor2Pin A10
DHT dht1(DHT22_PIN, DHTTYPE);
DHT dht2(DHT22_PIN_2, DHTTYPE);
SHT31 sht1(0x44);
SHT31 sht2(0x45);
Bme280TwoWire bme1;
Bme280TwoWire bme2;
int Vo, Vo2;
float R1 = 10000;
float logR2, logR3, R2, R3;
float c1 = 1.009249522e-03, c2 = 2.378405444e-04, c3 = 2.019202697e-07;
float temp1, temp2, temp3, temp4, temp5, temp6, hum1, hum2, hum3, hum4, hum5, hum6, pres1, pres2, waterTemp1, waterTemp2, waterTemp_1, waterTemp_2;
//averages for main menu/dashboard
float waterTempAverage;
bool updateDisplay;
//Variables for auto scroll
unsigned long previousMillis;
unsigned long previousMillis2;
unsigned long readTime;
//menu variables
#define ROOT_MENU_CNT 4
#define SUB_MENU1_CNT 1
#define SUB_MENU2_CNT 8
#define SUB_MENU3_CNT 6
#define SUB_MENU4_CNT 5
//setup the emum with all the menu pages options
enum pageType {ROOT_MENU, SUB_MENU1, SUB_MENU2, SUB_MENU3, SUB_MENU4, SUB_MENU3_ITEM1, SUB_MENU3_ITEM2, SUB_MENU3_ITEM3, SUB_MENU3_ITEM4, SUB_MENU3_ITEM5, SUB_MENU4_ITEM1, SUB_MENU4_ITEM2, SUB_MENU4_ITEM3, SUB_MENU4_ITEM4, SUB_MENU4_ITEM5, SCREEN_SAVER};
enum pageType currPage = ROOT_MENU;
enum pageType prevPage = SUB_MENU4_ITEM1;
//screen names for sub pages
char *subPage3Items[] = {"LIGHTS", "RAIN", "BACKWALL DRIP", "FOGGER", "AIR PUMP"};
char *subPage4Items[] = {"SET TEMPERATURE", "SET HUMIDITY", "SET LAND TEMPERATURE", "SET RAINSTORM", "RESET CRASH COUNTER"};
//selected item pointer for the root menu
uint8_t root_Pos = 1;
uint8_t rel_Pos = 1;  // selected item pointers for the relay menu
//selected item pointers for the sub menu's
uint8_t sub_Pos_3 = 1; //for menu 3
uint8_t sub_Pos_3_1 = 1; //for menu 3 sub item light timer
uint8_t sub_Pos_3_2 = 1; //for menu 3 sub item rain timers
uint8_t sub_Pos_3_3 = 1; //for menu 3 sub item drip timer
uint8_t sub_Pos_3_4 = 1; //for menu 3 sub item fogger
uint8_t sub_Pos_3_5 = 1; //for menu 3 sub item air ump
uint8_t numberOfTimers = 5; //for menu 3
uint8_t sub_Pos_4 = 1; //for menu 4
uint8_t sub_Pos_4_1 = 1; //set temperature
uint8_t sub_Pos_4_2 = 1; //set humidity
uint8_t sub_Pos_4_3 = 1; //set land temperature
uint8_t sub_Pos_4_4 = 1; //set rainstorm
uint8_t sub_Pos_4_5 = 1; //re-sync clock time
//maybe use something like sub_Pos_[x]_[y] ?
//joystick pins
#define xPin A0
#define yPin A1
#define kPin A2
#define Neutral 0
#define Press 1
#define Up 2
#define Down 3
#define Right 4
#define Left 5
#define highSwitchPoint 860 // mid position is around 700. top is 1023 and bottom is 0; //if its 1432 instead of 1023, like with the temperature calculation this changes.
#define lowSwitchPoint 350 // 860 about halfway between 700 and 1023 and 350 mid between 0 and 700
//relay block(s)
#define numberOfModules 1
//relay state array
#if numberOfModules == 2
#define numberOfRelays 16
unsigned int relay[numberOfRelays] = {23, 25, 27, 29, 31, 33, 35, 37, 46, 47, 48, 49, 50, 51, 52, 53};
#else
#define numberOfRelays 8
unsigned int relay[numberOfRelays] = {23, 25, 27, 29, 31, 33, 35, 37};
#endif
//NTP and RTC
//climate control variables
#define pwmPin_1 2
#define pwmPin_2 3
#define pwmPin_3 4
#define pwmPin_4 5
unsigned int minAirTemp, maxAirTemp, minHumidity, maxHumidity, dayWaterTemp, nightWaterTemp;
float airTemp, humidity, mappedTemp, mappedHumidity;
unsigned int waterTemp, airHigh, airLow, humidityHigh, humidityLow;
float humidityVariation = 1, temperatureVariation = 1, daytimeTempVariation = 1, daytimeHumVariation = 1;
const unsigned int hysteresis = 50; //equals x/10 degrees C or x/10 % RH
unsigned long sequenceInterval[] {2000, 2000, 30000, 90000, 90000}; //credit noiasca  https://forum.arduino.cc/index.php?topic=666044
static byte startup;
bool hold = false;
unsigned long startMillis = 0;
unsigned long intervalMark, startDelay;
unsigned long lightOn;
const unsigned int pollInterval = 10000; //10 seconds check time for climateControl
float pwmVal1, pwmVal2, mappedVal, computedVal;
unsigned int pwm1Speed, pwm2Speed;
bool climateControlPause = false;
unsigned long pauseStart = 0;
unsigned long lastAirUpdateTime = 0, lastHumUpdateTime = 0;
uint8_t airStep = 0, humStep = 0;
float oldAirTemp = 230; //starting values for the transition function
float oldHumidity = 750;
float desiredAirTemp = 230; //let it be the same at the start so there is no transition trigger as soon as the board boots up
float desiredHumidity = 750;
float airStartVal, airEndVal, humStartVal, humEndVal;
bool airTransition = false, humTransition = false;
unsigned long fanPauseTime = 30000; //x minute(s) pause after sprinklers have been used
unsigned long resetDelay = 90000;
bool noRain = false;
bool rainyDay = false;
float humModifier, tempModifier, weatherVariation;
bool humidityMonitoring = true;
uint8_t rainCounter = 0;
float rainCalculationFactor = 0.8; //used to be 1 for thunderstorms. want something more mundane
float currentReading = 0, previousReading = 0;
unsigned long previousPoint = 0;
enum ccState {CASE0, CASE1, CASE2, CASE3, CASE4, CASE5, CASE6, CASE7, CASE8, CASE9, CASE10, CASE11, CASE12};
enum ccState climateState = CASE0;
enum ccState previousClimateState = CASE5;
//set time function
enum ChangeTimeState {CHANGING_HOUR, CHANGING_MINUTE, SAVING_COMPLETE};
//time switching variables
unsigned int currentHour = 0;
unsigned int currentMinute = 0;
unsigned int currentTime = 0;
unsigned long wifiTime = 0;
unsigned long checkSettings = 0;
unsigned long checkTime = 200;
unsigned long adjustmentTime = 400;
unsigned long screenTime = 600;
unsigned int multipliedTime = 0;
bool dayTime = false;
#define numberOfTimers 16
unsigned long countdown[numberOfTimers];
bool timerActive[numberOfTimers] = {false};
bool hasNotRunYet[numberOfTimers] = {true};
//multiMap settings
float input[11] = {1, 10, 20, 30, 40, 50, 60, 70, 80, 90, 100}; //fanspeed
float output[11] = {1, 7, 15, 28, 43, 59, 77, 100, 140, 191, 255};
//updateStatistic variables
#define totalReadings 14
const unsigned int maxCount = 120;
float airDeviation = 5.0; //degress C
float humidityDeviation = 20.0; //% RH
float reading[totalReadings];
float sensorValue[totalReadings];
unsigned int sensor[totalReadings];
bool sensorFault[totalReadings];
char msg[10];
//for alarm e-mails
EMailSender emailSend(SECRET_EMAIL, SECRET_GMAIL_PASS);
bool emailSent = false;
//Bluetooth = HC-05 ID and pass = APC / 3511
#define btState 13
bool BTconnected = false;
bool relayState[8];
const byte numChars = 32;
char receivedChars[numChars];
char tempChars[numChars];  // temporary array for use when parsing
unsigned int eepromAddress = 0;
unsigned int newSetting = 0;
bool newData = false;
bool dataToParse = false;
bool timeToSet = false;
uint8_t relayNumber = 0;
//                                                  SETUP
  //screen
  myScreen.init(240, 320);
  myScreen.fillScreen(ST77XX_BLACK);
  Serial.println("TFT Initialized");
  myScreen.setRotation(1);
  myScreen.setCursor(0, 0);
  myScreen.setTextSize(3);
  myScreen.setTextWrap(false);
  myScreen.setTextColor(ST77XX_GREEN);
  myScreen.println("Arne's");
  myScreen.println("Paludarium");
  myScreen.println("Controller");
  myScreen.println("0.9.7.6");
  myScreen.println();
  myScreen.println("Connecting . . .");
  myScreen.setTextSize(2);
    delay(5000);
  //joystick
  pinMode(xPin, INPUT);
  pinMode(yPin, INPUT);
  pinMode(kPin, INPUT_PULLUP);
  //Bluetooth state
  pinMode(btState, INPUT);
  //assign relay pins as output
  for (int i = 0; i < numberOfRelays; i++) {
  pinMode(relay[i], OUTPUT); }
  // Initialize countdown array
  for (int i = 0; i < numberOfTimers; i++) {
    countdown[i] = 0;
  //variable fans
  pinMode(pwmPin_1, OUTPUT);
  pinMode(pwmPin_2, OUTPUT);
  pinMode(pwmPin_3, OUTPUT);
  pinMode(pwmPin_4, OUTPUT);
  //LED indicators
  pinMode(LEDR, OUTPUT);
  pinMode(LEDB, OUTPUT);
  //sensors
  Wire.begin();
  dht1.begin();
  dht2.begin();
  sht1.begin();
  sht2.begin();
  bme1.begin(Bme280TwoWireAddress::Primary);
  bme2.begin(Bme280TwoWireAddress::Secondary);
  ntpClient.begin();
  //crash counter
  int crashCounter = EEPROM.readByte(100);
  EEPROM.writeByte(100, crashCounter + 1);
//                                                  MAIN LOOP
        updateTime();
  if (millis() - checkSettings >= 60000) {  //check settings every minute
    climateSettings();
    checkSettings = millis();
  if (millis() - adjustmentTime >= 1000) {  //climateChange() adjust fan speeds every second
    climateChange();
    adjustmentTime = millis();
  if (millis() - screenTime >= 100) { //don't run continuously. Fuzz in checkJoystick() readings will never be coninuous 0
    autoGoBackToHomePage();
    screenSaver();
    activateScreen();
    screenTime = millis();
  if (millis() - checkTime >= 900) {  //run automatedswitching every x seconds
    automatedSwitching();
    checkTime = millis();
  if (millis() - readTime >= 2000) {  //poll all sensors every 2 seconds
    updateStatistics();
    updateBluetooth();
    if (currPage == ROOT_MENU) {
      printAverages();
      printRelays();
    if (currPage == SUB_MENU1) {
      printStatistics();
    readTime = millis();
  if (millis() - printNow >= 60000 && currPage != SCREEN_SAVER) {  //print time on screen every minute
    printTime();
    printNow = millis();
  if (millis() - startMillis >= pollInterval && !climateControlPause) {  //run climateControll every x seconds, except in a pause
    climateControl();
    startMillis = millis();
    setRTC = false;
  if (digitalRead(relay[0])) {  //adjust climateControl for day and night
    dayTime = true;
  } else if (!digitalRead(relay[0])) {
    dayTime = false;
  checkJoystick();
  navigationFunctioner();
  changePage();
  fanPause();
  makeItRain();
  bluetooth();
  if (newData == true) { //receiving bluetooth data
    strcpy(tempChars, receivedChars); // this temporary copy is necessary to protect the original data because strtok() used in parseData() replaces the commas with \0
    if (dataToParse) {
      parseData();
    if (timeToSet) {
      setTime();
      switchRelay();
    newData = false;
//                                                  CHECK PAGE
void changePage() {
  if (currPage != prevPage){
    switch (currPage){
      case ROOT_MENU:     page_RootMenu(); break;
      case SUB_MENU1:     page_SubMenu1(); break;
      case SUB_MENU2:     page_SubMenu2(); break;
      case SUB_MENU3:     page_SubMenu3(); break;
      case SUB_MENU4:     page_SubMenu4(); break;
      //sub menu 3
      case SUB_MENU3_ITEM1:     page_SubMenu3_Item(0); break;
      case SUB_MENU3_ITEM2:     page_SubMenu3_Item(1); break;
      case SUB_MENU3_ITEM3:     page_SubMenu3_Item(2); break;
      case SUB_MENU3_ITEM4:     page_SubMenu3_Item(3); break;
      case SUB_MENU3_ITEM5:     page_SubMenu3_Item(4); break;
      //sub menu 4
      case SUB_MENU4_ITEM1:     page_SubMenu4_Item(0); break;
      case SUB_MENU4_ITEM2:     page_SubMenu4_Item(1); break;
      case SUB_MENU4_ITEM3:     page_SubMenu4_Item(2); break;
      case SUB_MENU4_ITEM4:     page_SubMenu4_Item(3); break;
      case SUB_MENU4_ITEM5:     page_SubMenu4_Item(4); break;
      case SCREEN_SAVER:        page_ScreenSaver();    break;
    //update first time
    updateDisplay = true;
    prevPage = currPage;
//                                                  CHECK JOYSTICK POSITION
int checkJoystick() {
  int joystickXPin = analogRead(xPin);
  int joystickYPin = analogRead(yPin);
  int joystickSW = analogRead(kPin);
  /* inverted:
  if (joystickXPin < lowSwitchPoint)  return Right;
  if (joystickXPin > highSwitchPoint) return Left;
  if (joystickYPin < lowSwitchPoint)  return Down;
  if (joystickYPin > highSwitchPoint) return Up;
  if (joystickXPin > highSwitchPoint) return Right;
  if (joystickXPin < lowSwitchPoint)  return Left;
  if (joystickYPin > highSwitchPoint) return Down;
  if (joystickYPin < lowSwitchPoint)  return Up;
  if (!joystickSW) return Press;
  return Neutral;
//                                                  CHECK SYSTEM STATS
void updateStatistics() {
  sht1.read();
  sht2.read();
  reading[0] = dht1.readTemperature();
  reading[1] = dht2.readTemperature();
  reading[2] = sht1.getTemperature();
  reading[3] = sht2.getTemperature();
  reading[4] = bme1.getTemperature();
  reading[5] = bme2.getTemperature();
  reading[6] = dht1.readHumidity();
  reading[7] = dht2.readHumidity();
  reading[8] = sht1.getHumidity();
  reading[9] = sht2.getHumidity();
  reading[10] = bme1.getHumidity();
  reading[11] = bme2.getHumidity();
  reading[12] = bme1.getPressure() / 100;
  reading[13] = bme2.getPressure() / 100;
  // Check sensor readings and update sensor status
  for (int i = 0; i < totalReadings; i++) {
    if (!isnan(reading[i])) {
      sensorValue[i] = reading[i];
      sensor[i] = 0; //reset NAN counter
      if (sensor [i] < maxCount) { //if NAN counter +
        sensor[i]++;
    if (sensor[i] == maxCount) { //if x consecutive readings fail, trigger the alarm
      alarm(i, " DEFECT.");
      emailSent = false;
  temp1 = sensorValue[0];
  temp2 = sensorValue[1];
  temp3 = sensorValue[2];
  temp4 = sensorValue[3];
  temp5 = sensorValue[4];
  temp6 = sensorValue[5];
  hum1 = sensorValue[6];
  hum2 = sensorValue[7];
  hum3 = sensorValue[8];
  hum4 = sensorValue[9];
  hum5 = sensorValue[10];
  hum6 = sensorValue[11];
  pres1 = sensorValue[12];
  pres2 = sensorValue[13];
  airTempAverage = (temp1 + temp2 + temp3 + temp4 + temp5 + temp6) / 6;
  humidityAverage = (hum1 + hum2 + hum3 + hum4 + hum5 + hum6) / 6;
  pressureAverage = (pres1 + pres2) / 2;
  // Check for significant deviations in sensor readings
  for (int i = 0; i < 5; i++) { //1-6 is temperature
    sensorFault[i] = false;
    if ((sensorValue[i] > airTempAverage + airDeviation) || (sensorValue[i] < airTempAverage - airDeviation)) {
      alarm(i, " Deviation.");
      sensorFault[i] = true;
  for (int i = 6; i < 12; i++) {  //7-12 is humidity
    if ((sensorValue[i] > humidityAverage + humidityDeviation) || (sensorValue[i] < humidityAverage - humidityDeviation)) {
  //read water temperature1
  Vo = analogRead(ThermistorPin);
  R2 = R1 * (1558 / (float)Vo - 1.0); //4.96 (actual voltage on pin) / 3.26 (internal 3.3 ref voltage) * 1024 = 1561.1 I don't really understand why I need this conversion but it works.
  logR2 = log(R2);
  waterTemp_1 = (1.0 / (c1 + c2 * logR2 + c3 * logR2 * logR2 * logR2));
  waterTemp1 = waterTemp_1 - 273.15; // to Celsius
  //read water temperature2
  Vo2 = analogRead(Thermistor2Pin);
  R3 = R1 * (1558 / (float)Vo2 - 1.0);
  logR3 = log(R3);
  waterTemp_2 = (1.0 / (c1 + c2 * logR3 + c3 * logR3 * logR3 * logR3));
  waterTemp2 = waterTemp_2 - 273.15;
  //WaterTemp Average
  waterTempAverage = (waterTemp1 + waterTemp2) / 2;
void alarm(int x, char *msg) {
  outputDebug("Sensor reading ");
  outputDebug(x);
  outputDebugln(msg);
  String sensorName;
  if (x = 0 || 6) { sensorName = "DHT22-1. "; }
  if (x = 1 || 7) { sensorName = "DHT22-2. "; }
  if (x = 2 || 8) { sensorName = "SHT31-1. "; }
  if (x = 3 || 9) { sensorName = "SHT31-2. "; }
  if (x = 4 || 10 || 12) { sensorName = "BME280-1. "; }
  if (x = 5 || 11 || 13) { sensorName = "BME280-2. "; }
  String emailMessage = "Malfunction in sensor ";
  emailMessage += sensorName;
  emailMessage += String(msg);
  if (!emailSent) {
    EMailSender::EMailMessage message;
    message.subject = "APC alarm";
    message.message = emailMessage;
    EMailSender::Response resp = emailSend.send("arnekolman@gmail.com", message);
    outputDebugln("Sending status: ");
    outputDebugln(resp.status);
    outputDebugln(resp.code);
    outputDebugln(resp.desc);
    emailSent = true;
//                                                     BLUETOOTH
void bluetooth() {
  static boolean recvInProgress = false;
  static byte ndx = 0;
  char startMarker = '<';
  char endMarker = '>';
  char rc;
  if (Serial1.available() > 0 && newData == false) {
    rc = Serial1.read();
    if (recvInProgress == true) {
      if (rc != endMarker) {
        receivedChars[ndx] = rc;
        ndx++;
        if (ndx >= 4) {
          dataToParse = true;
        if (ndx >= 9) {
          dataToParse = false; //bypass the parse function
          timeToSet = true;    //go to setTime function instead
        if (ndx >= numChars) {
          ndx = numChars - 1;
        receivedChars[ndx] = '\0';  // terminate the string
        ndx = 0;
        newData = true;
    else if (rc == startMarker) {
      recvInProgress = true;
void parseData() {  // split the data into its parts
  char* strtokIndx;  // this is used by strtok() as an index
  strtokIndx = strtok(tempChars, ",");  // get the first part
  eepromAddress = atoi(strtokIndx); // convert this part to an integer
  strtokIndx = strtok(NULL, ",");  // this continues where the previous call left off
  newSetting = atoi(strtokIndx);
  EEPROM.writeByte(eepromAddress, newSetting);
  outputDebug("EEPROM address ");
  outputDebugln(eepromAddress);
  outputDebug("New value ");
  outputDebugln(newSetting);
void setTime() {  // split the data into its parts
  unsigned int Hour, Minute, Day, Mon, Year;
  Hour = atoi(strtokIndx);
  Minute = atoi(strtokIndx);
  Day = atoi(strtokIndx);
  Mon = atoi(strtokIndx);
  Year = atoi(strtokIndx); //sends 4 digit year
  tm t;
  t.tm_sec = (0);
  t.tm_min = (Minute);
  t.tm_hour = (Hour);
  t.tm_mday = (Day);
  t.tm_mon = (Mon-1);      //jan = 0. receiving jan = 1 count
  t.tm_year = (Year-1900); // year since 1900. receiving 202x
  set_time(mktime(&t));    // set RTC clock
  timeToSet = false;
  outputDebug("Time manually set to: ");
  outputDebug(Hour);
  outputDebug(":");
  outputDebug(Minute);
  outputDebug("  date: ");
  outputDebug(Day);
  outputDebug("-");
  outputDebug(Mon);
  outputDebug("-");
  outputDebugln(Year);
void switchRelay() {
  relayNumber = atoi(receivedChars);
  digitalWrite(relay[relayNumber], !digitalRead(relay[relayNumber]));
  outputDebug("Switching relay ");
  outputDebugln(relayNumber);
void updateBluetooth() {
  if (digitalRead(btState) == HIGH) {
    BTconnected = true;
  relayState[i] = digitalRead(relay[i]); }
  if (BTconnected) {
    //outputDebugln("Bluetooth Connected");
    Serial1.print("t1:"); Serial1.println(temp1, 1);
    Serial1.print("t2:"); Serial1.println(temp2, 1);
    Serial1.print("t3:"); Serial1.println(temp3, 1);
    Serial1.print("t4:"); Serial1.println(temp4, 1);
    Serial1.print("t5:"); Serial1.println(temp5, 1);
    Serial1.print("t6:"); Serial1.println(temp6, 1);
    Serial1.print("h1:"); Serial1.println(hum1, 1);
    Serial1.print("h2:"); Serial1.println(hum2, 1);
    Serial1.print("h3:"); Serial1.println(hum3, 1);
    Serial1.print("h4:"); Serial1.println(hum4, 1);
    Serial1.print("h5:"); Serial1.println(hum5, 1);
    Serial1.print("h6:"); Serial1.println(hum6, 1);
    Serial1.print("ata:"); Serial1.println(airTempAverage, 1);
    Serial1.print("ha:");  Serial1.println(humidityAverage, 1);
    Serial1.print("pa:");  Serial1.println(pressureAverage, 1);
    Serial1.print("wta:"); Serial1.println(waterTempAverage, 1);
    Serial1.print("r0:"); Serial1.println(relayState[0]);
    Serial1.print("r1:"); Serial1.println(relayState[1]);
    Serial1.print("r2:"); Serial1.println(relayState[2]);
    Serial1.print("r3:"); Serial1.println(relayState[3]);
    Serial1.print("r4:"); Serial1.println(relayState[4]);
    Serial1.print("r5:"); Serial1.println(relayState[5]);
    Serial1.print("r6:"); Serial1.println(relayState[6]);
    Serial1.print("r7:"); Serial1.println(relayState[7]);
    Serial1.print("desT:"); Serial1.println(EEPROM.readByte(desiredTemp)); //value stored in EEPROM address
    Serial1.print("desH:"); Serial1.println(EEPROM.readByte(desiredHumi));
    Serial1.print("dT:");   Serial1.println(EEPROM.readByte(dayTemperature));
    Serial1.print("nT:");   Serial1.println(EEPROM.readByte(nightTemperature));
    Serial1.print("EEdesT:"); Serial1.println(desiredTemp); // EEPROM address to read or write
    Serial1.print("EEdesH:"); Serial1.println(desiredHumi);
    Serial1.print("EEdT:");   Serial1.println(dayTemperature);
    Serial1.print("EEnT:");   Serial1.println(nightTemperature);
    Serial1.print("clock:");  Serial1.println(99);
    Serial1.print("LTON:");   Serial1.println(0);
    Serial1.print("LTOF:");   Serial1.println(2);
//                                                  PAGE - ROOT MENU
void page_RootMenu() {
  //clear screen
  //print title
  myScreen.println(F("MAIN MENU"));
  myScreen.drawLine(0, 15, 320, 15, ST77XX_GREEN);
  myScreen.drawLine(0, 16, 320, 16, ST77XX_GREEN);
  myScreen.drawLine(0, 17, 320, 17, ST77XX_GREEN);
  //print framework
  myScreen.setTextSize(1);
  myScreen.setCursor(10, 30);
  myScreen.print(F("Average"));
  myScreen.setCursor(10, 40);
  myScreen.print(F("Temperature"));
  myScreen.setCursor(100, 30);
  myScreen.setCursor(100, 40);
  myScreen.print(F("Humidity"));
  myScreen.setCursor(180, 30);
  myScreen.setCursor(180, 40);
  myScreen.print(F("Pressure"));
  myScreen.setCursor(200, 80);
  myScreen.print(F("PWM1"));
  myScreen.setCursor(185, 100);
  myScreen.print(F("STATE"));
  myScreen.setCursor(220, 120);
  myScreen.print(F("RC"));
  myScreen.setCursor(10, 200); myScreen.print(F("lights"));
  myScreen.setCursor(50, 220); myScreen.print(F("ventilation"));
  myScreen.setCursor(90, 200); myScreen.print(F("sprinklers"));
  myScreen.setCursor(130, 220); myScreen.print(F("irrigation"));
  myScreen.setCursor(170, 200); myScreen.print(F("fogger"));
  myScreen.setCursor(210, 220); myScreen.print(F("land heat"));
  myScreen.setCursor(250, 200); myScreen.print(F("window heat"));
  myScreen.setCursor(290, 220); myScreen.print(F("airpump"));
  printTime();
  //rest in handled in navigationFunctioner();
void page_ScreenSaver() {
  //clear screen
  updateDisplay = false;
//                                              PRINT AVERAGE STATS
void printAverages() {
  myScreen.setTextColor(ST77XX_WHITE, ST77XX_BLACK);
  //framework is created in ROOT_MENU
  //update readings on timer from updateStatistics()
  myScreen.setCursor(10, 50);
  printOutOfBounds(airTempAverage, true);
  myScreen.setCursor(100, 50);
  printOutOfBounds(humidityAverage, false);
  myScreen.setCursor(180, 50);
  myScreen.print(pressureAverage, 1);
  myScreen.print(F(" hPa"));
  //print target values
  if (!airTransition) { //if there is a transition use the callback to print those values
    myScreen.setTextColor(ST77XX_GREEN, ST77XX_BLACK);
    myScreen.setCursor(10, 70);
    myScreen.print((desiredAirTemp / 10), 1);
    myScreen.print("\367 ");
  if (!humTransition) {
    myScreen.setCursor(100, 70);
    myScreen.print((desiredHumidity / 10), 1);
    myScreen.print("% ");
  //print PWM speed
  if (pwm1Speed <= 100) { //the mapped value can spike to negative read over 458628%
    myScreen.setCursor(255, 80);
    myScreen.print(pwm1Speed);
    myScreen.print(F("%  "));
  //print climateState
  myScreen.setCursor(255, 100);
  myScreen.print(climateState);
  myScreen.print(" ");
  //print rainCounter
  myScreen.setCursor(255, 120);
  myScreen.print(rainCounter);
//                                              PRINT RELAY STATES
void printRelays() {
  if (digitalRead(relay[0]) == LOW)
  { myScreen.setTextColor(ST77XX_RED, ST77XX_BLACK); }
  else { myScreen.setTextColor(ST77XX_GREEN, ST77XX_BLACK); }
    myScreen.setCursor(10, 180); myScreen.print(F("R0"));
  if (digitalRead(relay[1]) == LOW)
    myScreen.setCursor(50, 180); myScreen.print(F("R1"));
  if (digitalRead(relay[2]) == LOW)
    myScreen.setCursor(90, 180); myScreen.print(F("R2"));
  if (digitalRead(relay[3]) == LOW)
    myScreen.setCursor(130, 180); myScreen.print(F("R3"));
  if (digitalRead(relay[4]) == LOW)
    myScreen.setCursor(170, 180); myScreen.print(F("R4"));
  if (digitalRead(relay[5]) == LOW)
    myScreen.setCursor(210, 180); myScreen.print(F("R5"));
  if (digitalRead(relay[6]) == LOW)
    myScreen.setCursor(250, 180); myScreen.print(F("R6"));
  if (digitalRead(relay[7]) == LOW)
    myScreen.setCursor(290, 180); myScreen.print(F("R7"));
//                                              PRINT TIME
void printTime() {
  myScreen.setCursor(210, 0);;
  myScreen.print(getLocalTime());
void printDigits(int digits) {
  //this void function is really useful; it adds a "0" to the beginning of the number, so that 5 minutes is displayed as "00:05:00", rather than "00:5 :00"
  if (digits < 10) {
    myScreen.print("0");
    myScreen.print(digits);
void updateTime() {
    setRTC = true;
String getLocalTime() {
  char buffer[16];
  tm t;
  _rtc_localtime(time(NULL), &t, RTC_4_YEAR_LEAP_YEAR_SUPPORT);
  strftime(buffer, 16, "%a %H:%M", &t);
  return String(buffer);
int getCurrentTime() { //formatted to hhmm for comparisons
  int multipliedTime;
  tm t;
  multipliedTime = (t.tm_hour * 100) + t.tm_min;
  return multipliedTime;
int getLocalHour() {
  int hour;
  tm t;
  _rtc_localtime(time(NULL), &t, RTC_FULL_LEAP_YEAR_SUPPORT);
  hour = t.tm_hour;
  return hour;
int getLocalMinutes() {
  int minutes;
  tm t;
  minutes = t.tm_min;
  return minutes;
int getDay() {
  int currentDay;
  tm t;
  currentDay = t.tm_mday;
  return currentDay;
int getMonth() {
  int currentMonth;
  tm t;
  currentMonth = t.tm_mon;
  return currentMonth;
//                                              PAGE - SUB MENU 1 STATISTICS
void page_SubMenu1() {
  //clear screen
  //print title
  myScreen.println(F("STATISTICS"));
  //draw framework once
  //horizontal framework
  myScreen.setCursor(70, 40);
  myScreen.setCursor(150, 40);
  myScreen.setCursor(220, 40);
  //vertical framework
  myScreen.setCursor(10, 60);
  myScreen.print(F("NTC-1"));
  myScreen.setCursor(10, 80);
  myScreen.print(F("DHT22-1"));
  myScreen.setCursor(10, 100);
  myScreen.print(F("SHT31-1"));
  myScreen.setCursor(10, 120);
  myScreen.print(F("BME280-1"));
  myScreen.setCursor(10, 140);
  myScreen.print(F("NTC-2"));
  myScreen.setCursor(10, 160);
  myScreen.print(F("DHT22-2"));
  myScreen.print(F("SHT31-2"));
  myScreen.print(F("BME280-2"));
//                                              PRINT SYSTEM STATS
void printStatistics() {
  //framework is created in SUB_MENU1
  //update readings on timer, called from main loop in updateStatistics
  //sensor set 1
  myScreen.setCursor(80, 60); //NTC 1
  myScreen.print(waterTemp1, 1);
  myScreen.print(F("\367"));
  myScreen.setCursor(80, 80); //DHT22 1
  printRedOrWhite(temp1, sensorFault[0], 1);
  myScreen.setCursor(150, 80);
  printRedOrWhite(hum1, sensorFault[6], 0);
  myScreen.setCursor(80, 100); //SHT31 1
  printRedOrWhite(temp3, sensorFault[2], 1);
  myScreen.setCursor(150, 100);
  printRedOrWhite(hum3, sensorFault[8], 0);
  myScreen.setCursor(80, 120); //BME280 1
  printRedOrWhite(temp5, sensorFault[4], 1);
  myScreen.setCursor(150, 120);
  printRedOrWhite(hum5, sensorFault[10], 0);
  myScreen.print(pres1, 1);
  //sensor set 2
  myScreen.setCursor(80, 140); //NTC 2
  myScreen.print(waterTemp2, 1);
  myScreen.setCursor(80, 160); // DHT22 2
  printRedOrWhite(temp2, sensorFault[1], 1);
  myScreen.setCursor(150, 160);
  printRedOrWhite(hum2, sensorFault[7], 0);
  myScreen.setCursor(80, 180); //SHT31 2
  printRedOrWhite(temp4, sensorFault[3], 1);
  myScreen.setCursor(150, 180);
  printRedOrWhite(hum4, sensorFault[9], 0);
  myScreen.setCursor(80, 200); //BME280 2
  printRedOrWhite(temp6, sensorFault[5], 1);
  myScreen.setCursor(150, 200);
  printRedOrWhite(hum6, sensorFault[11], 0);
  myScreen.setCursor(220, 200);
  myScreen.print(pres2, 1);
void printRedOrWhite(float sensorData, bool fault, bool temperature) {
  //if the sensor returns NAN the variable will not be updated and will be displayed in red
  if (fault) {
    myScreen.print(sensorData, 1);
    if (temperature) {
      myScreen.print("\367");
      myScreen.print("%");
    if (temperature) {
void printOutOfBounds(float sensorData, bool temperature) {
  //if the sensor data requires adjusting it will be displayed in red
  int val = sensorData * 10; //sensorData = float, airHigh = int from float * 10. So sensorData must also convert with * 10
  if (temperature) {
    if (val >= airHigh || val <= airLow) {
  if (!temperature) {
    if (val >= humidityHigh || val <= humidityLow) {
//                                              PAGE - SUB MENU2 RELAYS
void page_SubMenu2() {
  //clear screen
  //print title
  myScreen.println(F("RELAYS"));
  //print R-button positions
  myScreen.setCursor(0, 100); myScreen.print(F(" R0"));
  myScreen.setCursor(40, 100); myScreen.print(F(" R1"));
  myScreen.setCursor(80, 100); myScreen.print(F(" R2"));
  myScreen.setCursor(120, 100); myScreen.print(F(" R3"));
  myScreen.setCursor(160, 100); myScreen.print(F(" R4"));
  myScreen.setCursor(200, 100); myScreen.print(F(" R5"));
  myScreen.setCursor(240, 100); myScreen.print(F(" R6"));
  myScreen.setCursor(280, 100); myScreen.print(F(" R7"));
void drawRelaysState(int number, bool state, int xPos, int yPos) {
  xPos = number*xPos;
  if (state == HIGH) {
    myScreen.setCursor(xPos+10, yPos -20); //print relay state behind the selector icon(xPos+10), above or under the numbered relay
    myScreen.setTextColor(ST77XX_BLACK, ST77XX_GREEN);
    myScreen.print(F("ON"));
    myScreen.setCursor(xPos, yPos +20);
    myScreen.print(F("   "));
  else if (state == LOW) {
    myScreen.setCursor(xPos, yPos +20);   // not shifting xPos to prevent the row from wrapping around to the front -> -1 even
    myScreen.setTextColor(ST77XX_BLACK, ST77XX_RED);
    myScreen.print(F("OFF"));
//                                              PAGE - SUB MENU 3 TIMERS
void page_SubMenu3() {
  //clear screen
  //print title
  myScreen.println(F("TIMERS"));
//                                        GENERIC SUB MENU 3 ITEM PAGE
void page_SubMenu3_Item(uint8_t item_number) {
  uint8_t item_Pos = 1; //for menu 3
  //clear screen
  //print title
  myScreen.println(subPage3Items[item_number]);
//                                        PAGE - SUB MENU 4 SETTINGS
void page_SubMenu4() {
  //clear screen
  //print title
  myScreen.println(F("SETTINGS"));
//                                      GENERIC SUB MENU 4 ITEM PAGE
void page_SubMenu4_Item(uint8_t item_number) {
  //clear screen
  //print title
  myScreen.println(subPage4Items[item_number]);
//                                       MOVING THROUGH ALL PAGES CONTENT
void navigationFunctioner() {
  bool down_was_down = false;
  bool up_was_down = false;
  bool right_was_down = false;
  bool left_was_down = false;
  if (checkJoystick() == Down) { down_was_down = true; delay(100); }
  if (checkJoystick() == Up) { up_was_down = true; delay(100); }
  if (checkJoystick() == Right) { right_was_down = true; delay(100); }
  if (checkJoystick() == Left) { left_was_down = true; delay(100); }
  if (currPage == ROOT_MENU) { //=====================================================================ROOT=================================================
    if (updateDisplay) {
      myScreen.setCursor(0, 80);
      printSelected(1, root_Pos);    myScreen.println(F("STATISTICS"));
      printSelected(2, root_Pos);    myScreen.println(F("RELAYS"));
      printSelected(3, root_Pos);    myScreen.println(F("TIMERS"));
      printSelected(4, root_Pos);    myScreen.println(F("SETTINGS"));
    //move the pointer down
    if (checkJoystick() == Down && down_was_down == true) {
      if (root_Pos == ROOT_MENU_CNT) {      root_Pos = 1;    }
      else {      root_Pos++;    }
    //move the pointer Up
    if (checkJoystick() == Up && up_was_down == true) {
      if (root_Pos == 1) {      root_Pos = ROOT_MENU_CNT;    }
      else {      root_Pos--;    }
    //move to the selected page
    if (checkJoystick() == Right && right_was_down == true) {
      switch (root_Pos) {
        case 1: currPage = SUB_MENU1; return;
        case 2: currPage = SUB_MENU2; return;
        case 3: currPage = SUB_MENU3; return;
        case 4: currPage = SUB_MENU4; return;
  if (currPage == SUB_MENU1) { //=====================================================================SUB1 STATS===========================================
    //exit - move back to the root menu
    if (checkJoystick() == Left && left_was_down == true) {
      currPage = ROOT_MENU; return;
  if (currPage == SUB_MENU2) { //=====================================================================SUB2 RELAYS===========================================
    if (updateDisplay){
      //draw selector
      myScreen.setCursor(0, 100); printSelectedSmall(1, rel_Pos);
      myScreen.setCursor(40, 100); printSelectedSmall(2, rel_Pos);
      myScreen.setCursor(80, 100); printSelectedSmall(3, rel_Pos);
      myScreen.setCursor(120, 100); printSelectedSmall(4, rel_Pos);
      myScreen.setCursor(160, 100); printSelectedSmall(5, rel_Pos);
      myScreen.setCursor(200, 100); printSelectedSmall(6, rel_Pos);
      myScreen.setCursor(240, 100); printSelectedSmall(7, rel_Pos);
      myScreen.setCursor(280, 100); printSelectedSmall(8, rel_Pos);
      //draw drawRelaysState(int number, bool state, int xPos, int yPos) 10 pixels to the right of the first rel_Pos
      for (int i = 0; i < numberOfRelays; i++) drawRelaysState(i, digitalRead(relay[i]), 40, 100);
      if (rel_Pos == 1) {myScreen.setCursor(10, 150); myScreen.print(F("LIGHTS        "));}
      if (rel_Pos == 2) {myScreen.setCursor(10, 150); myScreen.print(F("FANS          "));}
      if (rel_Pos == 3) {myScreen.setCursor(10, 150); myScreen.print(F("RAIN          "));}
      if (rel_Pos == 4) {myScreen.setCursor(10, 150); myScreen.print(F("BACKWALL DRIP "));}
      if (rel_Pos == 5) {myScreen.setCursor(10, 150); myScreen.print(F("FOGGER        "));}
      if (rel_Pos == 6) {myScreen.setCursor(10, 150); myScreen.print(F("LAND HEATING  "));}
      if (rel_Pos == 7) {myScreen.setCursor(10, 150); myScreen.print(F("WINDOW HEATING"));}
      if (rel_Pos == 8) {myScreen.setCursor(10, 150); myScreen.print(F("AIRPUMP       "));}
      // clear the update flag
    //move the pointer right
      if (rel_Pos == SUB_MENU2_CNT) {rel_Pos = 1;}
      else {rel_Pos++;}
    //move the pointer left / back to main menu
      if (rel_Pos == 1) { currPage = ROOT_MENU; return; }
      else {rel_Pos--;}
    //switch selected relay on
      if (digitalRead(relay[rel_Pos-1]) == LOW) { //first position in array in 0, so rel_Pos -1
        digitalWrite(relay[rel_Pos-1], HIGH); }
    //switch selected relay off
      if (digitalRead(relay[rel_Pos-1]) == HIGH) {
        digitalWrite(relay[rel_Pos-1], LOW); }
  if (currPage == SUB_MENU3) { //=====================================================================SUB3 TIMERS===========================================
    if (updateDisplay){
      // print the items
      myScreen.setCursor(0, 30);
      printSelected(1, sub_Pos_3); myScreen.println(F("LIGHTS"));
      printSelected(2, sub_Pos_3); myScreen.println(F("RAIN"));
      printSelected(3, sub_Pos_3); myScreen.println(F("BACKWALL DRIP"));
      printSelected(4, sub_Pos_3); myScreen.println(F("FOGGER"));
      printSelected(5, sub_Pos_3); myScreen.println(F("AIR PUMP"));
      printSelected(6, sub_Pos_3); myScreen.println(F("SYNC TIME"));
      if (sub_Pos_3 == SUB_MENU3_CNT) {sub_Pos_3 = 1;} else {sub_Pos_3++;}
      if (sub_Pos_3 == 1) {sub_Pos_3 = SUB_MENU3_CNT;} else {sub_Pos_3--;}
      switch (sub_Pos_3) {
        case 1: currPage = SUB_MENU3_ITEM1; return;
        case 2: currPage = SUB_MENU3_ITEM2; return;
        case 3: currPage = SUB_MENU3_ITEM3; return;
        case 4: currPage = SUB_MENU3_ITEM4; return;
        case 5: currPage = SUB_MENU3_ITEM5; return;
        case 6: setRTC = false; return; //manually tell the RTC to re-sync
    //move back to the root menu
  if (currPage == SUB_MENU3_ITEM1) { //================================SUB3 ITEM 1 MAIN LIGHTS===============================================
    int xPos1 = 30, yPos1 = 40, yPos2 = 80, offset1 = 80;
    if (updateDisplay){
      // print the items
      myScreen.setCursor(0, yPos1);
      printSelected(1, sub_Pos_3_1); printTimer(1, xPos1, yPos1, 0, false);  myScreen.print(" START");  //printTimer(int number, int xPos, int yPos, int eepromNumber, bool printDuration)
      myScreen.setCursor(0, yPos2);
      printSelected(2, sub_Pos_3_1); printTimer(2, xPos1, yPos2, 2, false);  myScreen.print(" STOP");
    if (checkJoystick() == Down && down_was_down == true) { //move the pointer down
      if (sub_Pos_3_1 == 1) {sub_Pos_3_1 = 2;}
    if (checkJoystick() == Up && up_was_down == true) {  //move the pointer Up
      if (sub_Pos_3_1 == 2) {sub_Pos_3_1 = 1;}
    if (sub_Pos_3_1 == 1 && checkJoystick() == Right && right_was_down == true) { // change ON timer
      //outputDebugln("startChangeTime ON timer");
      startChangeTime(0, 1, xPos1 + offset1, yPos1); // startChangeTime(int eepromHour, int eepromMinutes, int xPos, int yPos)
    if (sub_Pos_3_1 == 2 && checkJoystick() == Right && right_was_down == true) { // change OFF timer
      //outputDebugln("startChangeTime OFF timer");
      startChangeTime(2, 3, xPos1 + offset1, yPos2);
      return;
  if (currPage == SUB_MENU3_ITEM2) { //=================================SUB3 ITEM 2 SPRINKLERS================================================
    int xPos1 = 30, yPos1 = 40, yPos2 = 70, yPos3 = 100, yPos4 = 130, yPos5 = 160, offset1 = 80, offset2 = 260;
    if (updateDisplay){
      // print the items
      printSelected(1, sub_Pos_3_2); printTimer(1, xPos1, yPos1, 4, true); //printTimers(int number, int xPos, int yPos, int eepromNumber, bool printDuration)
      printSelected(2, sub_Pos_3_2); printTimer(2, xPos1, yPos2, 8, true);
      myScreen.setCursor(0, yPos3);
      printSelected(3, sub_Pos_3_2); printTimer(3, xPos1, yPos3, 12, true);
      myScreen.setCursor(0, yPos4);
      printSelected(4, sub_Pos_3_2); printTimer(4, xPos1, yPos4, 16, true);
      myScreen.setCursor(0, yPos5);
      printSelected(5, sub_Pos_3_2); printTimer(5, xPos1, yPos5, 20, true);
      if (sub_Pos_3_2 == numberOfTimers) {sub_Pos_3_2 = 1;} else {sub_Pos_3_2++;}
      if (sub_Pos_3_2 == 1) {sub_Pos_3_2 = numberOfTimers;} else {sub_Pos_3_2--;}
    if (sub_Pos_3_2 == 1 && checkJoystick() == Right && right_was_down == true) { // change timer 1 start and duration
      startChangeTime(4, 5, xPos1 + offset1, yPos1); // startChangeTime(int eepromHour, int eepromMinutes, int xPos, int yPos)
      startChangeSeconds(6, xPos1 + offset2, yPos1); // startChangeSeconds(int eepromSeconds, int xPos, int yPos)
    if (sub_Pos_3_2 == 2 && checkJoystick() == Right && right_was_down == true) {
      startChangeTime(8, 9, xPos1 + offset1, yPos2);
      startChangeSeconds(10, xPos1 + offset2, yPos2);
    if (sub_Pos_3_2 == 3 && checkJoystick() == Right && right_was_down == true) {
      startChangeTime(12, 13, xPos1 + offset1, yPos3);
      startChangeSeconds(14, xPos1 + offset2, yPos3);
    if (sub_Pos_3_2 == 4 && checkJoystick() == Right && right_was_down == true) {
      startChangeTime(16, 17, xPos1 + offset1, yPos4);
      startChangeSeconds(18, xPos1 + offset2, yPos4);
    if (sub_Pos_3_2 == 5 && checkJoystick() == Right && right_was_down == true) {
      startChangeTime(20, 21, xPos1 + offset1, yPos5);
      startChangeSeconds(22, xPos1 + offset2, yPos5);
      return;
  if (currPage == SUB_MENU3_ITEM3) { //=================================SUB3 ITEM 3 BACKWALL DRIP=============================================
    int xPos1 = 30, yPos1 = 40, yPos2 = 80, offset1 = 80, offset2 = 260;
    if (updateDisplay){
      // print the items
      printSelected(1, sub_Pos_3_3); printTimer(1, xPos1, yPos1, 24, true);
      printSelected(2, sub_Pos_3_3); printTimer(2, xPos1, yPos2, 28, true);
      if (sub_Pos_3_3 == 2) {sub_Pos_3_3 = 1;} else {sub_Pos_3_3++;}
      if (sub_Pos_3_3 == 1) {sub_Pos_3_3 = 2;} else {sub_Pos_3_3--;}
    if (sub_Pos_3_3 == 1 && checkJoystick() == Right && right_was_down == true) {
      startChangeTime(24, 25, xPos1 + offset1 , yPos1);
      startChangeSeconds(26, xPos1 + offset2, yPos1);
    if (sub_Pos_3_3 == 2 && checkJoystick() == Right && right_was_down == true) {
      startChangeTime(28, 29, xPos1 + offset1 , yPos2);
      startChangeSeconds(30, xPos1 + offset2, yPos2);
      return;
  if (currPage == SUB_MENU3_ITEM4) { //=================================SUB3 ITEM 4 FOGGER====================================================
    if (updateDisplay){
      // print the items
      printSelected(1, sub_Pos_3_4); printTimer(1, xPos1, yPos1, 32, false);  myScreen.print(" START");
      printSelected(2, sub_Pos_3_4); printTimer(2, xPos1, yPos2, 34, false);  myScreen.print(" STOP");
      if (sub_Pos_3_4 == 1) {sub_Pos_3_4 = 2;}
      if (sub_Pos_3_4 == 2) {sub_Pos_3_4 = 1;}
    if (sub_Pos_3_4 == 1 && checkJoystick() == Right && right_was_down == true) {
      startChangeTime(32, 33, xPos1 + offset1, yPos1);
    if (sub_Pos_3_4 == 2 && checkJoystick() == Right && right_was_down == true) {
      startChangeTime(34, 35, xPos1 + offset1, yPos2);
      return;
  if (currPage == SUB_MENU3_ITEM5) { //=================================SUB3 ITEM 5 AIR PUMP==================================================
    if (updateDisplay){
      // print the items
      printSelected(1, sub_Pos_3_5); printTimer(1, xPos1, yPos1, 38, true);
      printSelected(2, sub_Pos_3_5); printTimer(2, xPos1, yPos2, 42, true);
      printSelected(3, sub_Pos_3_5); printTimer(3, xPos1, yPos3, 46, true);
      printSelected(4, sub_Pos_3_5); printTimer(4, xPos1, yPos4, 50, true);
      printSelected(5, sub_Pos_3_5); printTimer(5, xPos1, yPos5, 54, true);
      if (sub_Pos_3_5 == numberOfTimers) {sub_Pos_3_5 = 1;} else {sub_Pos_3_5++;}
      if (sub_Pos_3_5 == 1) {sub_Pos_3_5 = numberOfTimers;} else {sub_Pos_3_5--;}
    if (sub_Pos_3_5 == 1 && checkJoystick() == Right && right_was_down == true) {
      startChangeTime(38, 39, xPos1 + offset1 , yPos1);
      startChangeSeconds(40, xPos1 + offset2, yPos1); //duration of seconds can be turned into minutes in on/off function *60
    if (sub_Pos_3_5 == 2 && checkJoystick() == Right && right_was_down == true) {
      startChangeTime(42, 43, xPos1 + offset1 , yPos2);
      startChangeSeconds(44, xPos1 + offset2, yPos2);
    if (sub_Pos_3_5 == 3 && checkJoystick() == Right && right_was_down == true) {
      startChangeTime(46, 47, xPos1 + offset1 , yPos3);
      startChangeSeconds(48, xPos1 + offset2, yPos3);
    if (sub_Pos_3_5 == 4 && checkJoystick() == Right && right_was_down == true) {
      startChangeTime(50, 51, xPos1 + offset1 , yPos4);
      startChangeSeconds(52, xPos1 + offset2, yPos4);
    if (sub_Pos_3_5 == 5 && checkJoystick() == Right && right_was_down == true) {
      startChangeTime(54, 55, xPos1 + offset1 , yPos5);
      startChangeSeconds(56, xPos1 + offset2, yPos5);
      return;
  if (currPage == SUB_MENU4) { //=====================================================================SUB4=================================================
    if (updateDisplay){
      // print the items
      printSelected(1, sub_Pos_4); myScreen.println(F("SET TEMPERATURE"));
      printSelected(2, sub_Pos_4); myScreen.println(F("SET HUMIDITY"));
      printSelected(3, sub_Pos_4); myScreen.println(F("SET LAND TEMPERATURE"));
      printSelected(4, sub_Pos_4); myScreen.println(F("SET RAINSTORM"));
      myScreen.println();
      printSelected(5, sub_Pos_4); myScreen.println(F("RESET CRASH COUNTER"));
      if (sub_Pos_4 == SUB_MENU4_CNT) {sub_Pos_4 = 1;} else {sub_Pos_4++;}
      if (sub_Pos_4 == 1) {sub_Pos_4 = SUB_MENU4_CNT;} else {sub_Pos_4--;}
      switch (sub_Pos_4) {
        case 1: currPage = SUB_MENU4_ITEM1; return;
        case 2: currPage = SUB_MENU4_ITEM2; return;
        case 3: currPage = SUB_MENU4_ITEM3; return;
        case 4: currPage = SUB_MENU4_ITEM4; return;
        case 5: currPage = SUB_MENU4_ITEM5; return;
  if (currPage == SUB_MENU4_ITEM1) { //===================SUB4 ITEM 1 SET TEMPERATURE====================================
    int xPos1 = 30, xPos2 = 160, yPos1 = 40, yPos2 = 80, yPos3 = 120;
    if (updateDisplay){
      // print the items
      printSelected(1, sub_Pos_4_1); printMinMax(xPos1, yPos1, 60, "MIN TEMPERATURE ", "\367");  //printMinMax(int xPos, int yPos, int eepromNumber, const char* txt, const char* txt2)
      printSelected(2, sub_Pos_4_1); printMinMax(xPos1, yPos2, 61, "MAX TEMPERATURE ", "\367");
      printSelected(3, sub_Pos_4_1); printMinMax(xPos1, yPos3, 70, "IDEAL ", "\367");
      myScreen.setCursor(xPos2, yPos3); myScreen.print("Mod: "); myScreen.print(tempModifier, 2);
      if (sub_Pos_4_1 == 3) {sub_Pos_4_1 = 1;} else {sub_Pos_4_1++;}
      if (sub_Pos_4_1 == 1) {sub_Pos_4_1 = 3;} else {sub_Pos_4_1--;}
    if (sub_Pos_4_1 == 1 && checkJoystick() == Right && right_was_down == true) { //min temp
      setValue(xPos1, yPos1, 10, 25, 60, 190); //setValue(int xPos, int yPos, int minValue, int maxValue, int eepromNumber, int shiftToRight)
    if (sub_Pos_4_1 == 2 && checkJoystick() == Right && right_was_down == true) { //max temp
      setValue(xPos1, yPos2, 20, 35, 61, 190);
    if (sub_Pos_4_1 == 3 && checkJoystick() == Right && right_was_down == true) { //ideal temp
      setValue(xPos1, yPos3, 10, 35, 70, 70);
      return;
  if (currPage == SUB_MENU4_ITEM2) { //===================SUB4 ITEM 2 SET HUMIDITY=======================================
    if (updateDisplay){
      // print the items
      printSelected(1, sub_Pos_4_2); printMinMax(xPos1, yPos1, 62, "MIN HUMIDITY ", "%");  //printMinMax(int xPos, int yPos, int eepromNumber, const char* txt, const char* txt2)
      printSelected(2, sub_Pos_4_2); printMinMax(xPos1, yPos2, 63, "MAX HUMIDITY ", "%");
      printSelected(3, sub_Pos_4_2); printMinMax(xPos1, yPos3, 71, "IDEAL ", "%");
      myScreen.setCursor(xPos2, yPos3); myScreen.print("Mod: "); myScreen.print(humModifier, 2);
      if (sub_Pos_4_2 == 3) {sub_Pos_4_2 = 1;} else {sub_Pos_4_2++;}
      if (sub_Pos_4_2 == 1) {sub_Pos_4_2 = 3;} else {sub_Pos_4_2--;}
    if (sub_Pos_4_2 == 1 && checkJoystick() == Right && right_was_down == true) { //min humidity
      setValue(xPos1, yPos1, 40, 70, 62, 155); //setValue(int xPos, int yPos, int minValue, int maxValue, int eepromNumber, int shiftToRight)
    if (sub_Pos_4_2 == 2 && checkJoystick() == Right && right_was_down == true) { //max humidity
      setValue(xPos1, yPos2, 50, 95, 63, 155);
    if (sub_Pos_4_2 == 3 && checkJoystick() == Right && right_was_down == true) { //ideal humidity
      setValue(xPos1, yPos3, 50, 90, 71, 70);
      return;
  if (currPage == SUB_MENU4_ITEM3) { //===================SUB4 ITEM 3 SET LAND TEMPERATURE===============================
    int xPos1 = 30, yPos1 = 40, yPos2 = 80;
    if (updateDisplay){
      // print the items
      printSelected(1, sub_Pos_4_3); printMinMax(xPos1, yPos1, 64, "DAY TEMPERATURE ", "\367");  //printMinMax(int xPos, int yPos, int eepromNumber, const char* txt, const char* txt2)
      printSelected(2, sub_Pos_4_3); printMinMax(xPos1, yPos2, 65, "NIGHT TEMPERATURE ", "\367");
      if (sub_Pos_4_3 == 1) {sub_Pos_4_3 = 2;}
      if (sub_Pos_4_3 == 2) {sub_Pos_4_3 = 1;}
    if (sub_Pos_4_3 == 1 && checkJoystick() == Right && right_was_down == true) { //day temp
      setValue(xPos1, yPos1, 10, 25, 64, 190); //setValue(int xPos, int yPos, int minValue, int maxValue, int eepromNumber, int shiftToRight)
    if (sub_Pos_4_3 == 2 && checkJoystick() == Right && right_was_down == true) { //night temp
      setValue(xPos1, yPos2, 10, 20, 65, 220);
      return;
  if (currPage == SUB_MENU4_ITEM4) { //===================SUB4 ITEM 4 SET RAINSTORM======================================
    int xPos1 = 30, yPos1 = 40, yPos2 = 80, yPos3 = 120, yPos4 = 160;
    if (updateDisplay){
      // print the items
      printSelected(1, sub_Pos_4_4); printMinMax(xPos1, yPos1, 66, "MAX NUMBER ", "");  //printMinMax(int xPos, int yPos, int eepromNumber, const char* txt, const char* txt2)
      printSelected(2, sub_Pos_4_4); printMinMax(xPos1, yPos2, 67, "DURATION ", "");
      printSelected(3, sub_Pos_4_4); printMinMax(xPos1, yPos3, 68, "VENT PAUSE ", "");
      printSelected(4, sub_Pos_4_4); myScreen.print("RAINY DAY: "); if (rainyDay) { myScreen.print("TRUE "); } else { myScreen.print("FALSE"); }
      if (sub_Pos_4_4 == 4) {sub_Pos_4_4 = 1;} else {sub_Pos_4_4++;}
      if (sub_Pos_4_4 == 1) {sub_Pos_4_4 = 4;} else {sub_Pos_4_4--;}
    if (sub_Pos_4_4 == 1 && checkJoystick() == Right && right_was_down == true) {
      setValue(xPos1, yPos1, 1, 5, 66, 130); //setValue(int xPos, int yPos, int minValue, int maxValue, int eepromNumber, int shiftToRight)
    if (sub_Pos_4_4 == 2 && checkJoystick() == Right && right_was_down == true) {
      setValue(xPos1, yPos2, 10, 60, 67, 110);
    if (sub_Pos_4_4 == 3 && checkJoystick() == Right && right_was_down == true) {
      setValue(xPos1, yPos3, 10, 120, 68, 130);
    if (sub_Pos_4_4 == 4 && checkJoystick() == Right && right_was_down == true) {
      rainyDay = !rainyDay;
      return;
  if (currPage == SUB_MENU4_ITEM5) { //===================SUB4 ITEM 5 RESET CRASHCOUNTER=================================
    if (updateDisplay){
      // print the items
      printSelected(1, sub_Pos_4_5); myScreen.print("CRASH COUNTER = "); myScreen.print(EEPROM.readByte(100)); myScreen.print("  ");
      myScreen.setTextColor(ST77XX_RED);
      printSelected(2, sub_Pos_4_5); myScreen.print("CONFIRM RESET");
      myScreen.setTextColor(ST77XX_WHITE);
      if (sub_Pos_4_5 == 1) {sub_Pos_4_5 = 2;}
      if (sub_Pos_4_5 == 2) {sub_Pos_4_5 = 1;}
    if (sub_Pos_4_5 == 2 && checkJoystick() == Right && right_was_down == true) {
      EEPROM.writeByte(100, 0);
      return;
void printSelected(uint8_t p1, uint8_t p2) {
  if (p1 == p2) { myScreen.print(F(" > ")); }
  else { myScreen.print(F("   ")); }
void printSelectedSmall(uint8_t p1, uint8_t p2) {
  if (p1 == p2) { myScreen.print(F(">")); }
//                                             AUTO GO BACK TO HOMEPAGE
void autoGoBackToHomePage() {
  unsigned long currentMillis = millis();  //call current millis
  if (checkJoystick() != 0) {  // Reset millis counter if joystick is moved
  if (currPage != SCREEN_SAVER) {
    if (currPage != ROOT_MENU && currentMillis - previousMillis > 60 * 1000) {  //1 minute
      previousMillis = currentMillis;  //replace previous millis by current millis as new start point
void screenSaver() {
  unsigned long currentMillis2 = millis();
    previousMillis2 = currentMillis2;
  if (currPage == ROOT_MENU && currentMillis2 - previousMillis2 > 300 * 1000) {  //after 5 minutes of no movement
    currPage = SCREEN_SAVER;
    outputDebugln("Screensaver activated");
void activateScreen() {
  if (currPage == SCREEN_SAVER && checkJoystick() != 0) {  //turn back on when joystick is moved
    outputDebugln("Screen reactivated");
//                                                     CLIMATE CONTROL
void climateSettings() {
  //adjust settings for seasons with multiMap arrays.
  //date[] is the 'x-axis' and the xModifier is the 'y-axis' for a graph to calculate all points based on weather data from Costa Rica
  float date[13] = {1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13}; //months. 13 is added so month 12 can have 'days'
  float tempertureModifier[13] = {0.96, 0.92, 0.92, 0.92, 0.92, 0.96, 1.12, 1.04, 1, 0.96, 0.92, 0.96, 0.96}; //based on 25 degrees celsius
  float humidityModifier[13] = {1.2, 1.15, 1.09, 1.04, 1.01, 1, 0.97, 1, 1.13, 1.2, 1.07, 1.13, 1.2}; //based on 75% RH --- depending on sensor positions you might need to change the base
  float today = getDay() * (1/32) + getMonth(); //today is number of the month plus a fraction for each day, filling out the date[] graph axis
  humidityVariation = multiMap(today, date, humidityModifier, 13);
  temperatureVariation = multiMap(today, date, tempertureModifier, 13);
  //adjust settings for daytime
  if (getLocalHour() == 13 || getLocalHour() == 14) { //midday
    daytimeHumVariation = 0.9;
    daytimeTempVariation = 1.1;
  } else if (getLocalHour() >= 23 || getLocalHour() <= 7) { //night
    daytimeHumVariation = 1.25;
    daytimeTempVariation = 0.8;
    daytimeTempVariation = 1;
  //adjust settings for weather outside
  if (rainyDay) {
    weatherVariation = 1.1; //10% more humidity
    weatherVariation = 1;
  humModifier = humidityVariation * daytimeHumVariation * weatherVariation;
  tempModifier = temperatureVariation * daytimeTempVariation;
  //everything times 10 for better resolution
  minAirTemp = EEPROM.readByte(60) * 10;
  maxAirTemp = EEPROM.readByte(61) * 10;
  minHumidity = EEPROM.readByte(62) * 10;
  maxHumidity = EEPROM.readByte(63) * 10;
  dayWaterTemp = EEPROM.readByte(dayTemperature) * 10;
  nightWaterTemp = EEPROM.readByte(nightTemperature) * 10;
  if (!airTransition) { //if the value changed due to a modifier or user change it will start to transition. While transitioning don't reset the value
    desiredAirTemp = (EEPROM.readByte(desiredTemp) * 10) * tempModifier;
    desiredHumidity = (EEPROM.readByte(desiredHumi) * 10) * humModifier;
  if (desiredAirTemp < (waterTemp - hysteresis / 4)) { //cannot cool lower that outside temperature. For now waterTemp = external airTemp
    desiredAirTemp = waterTemp - hysteresis / 4; //compensate for hysteresis upper limit
  airHigh = desiredAirTemp + (hysteresis / 2);
  airLow = desiredAirTemp - (hysteresis / 2);
  humidityHigh = desiredHumidity + hysteresis;
  humidityLow = desiredHumidity - hysteresis;
  outputDebug("Temperature modifier: ");
  outputDebugln(tempModifier);
  outputDebug("Humidity modifier: ");
  outputDebugln(humModifier);
void climateControl() {
  airTemp = airTempAverage * 10; //all average readings have 1 decimal number. Scale up by 10 to work with ints
  humidity = humidityAverage * 10;
  waterTemp = waterTempAverage * 10;
  if (dayTime) { //day schedule
    hold = false;
    if (humidity >= maxHumidity) { //disable sprinklers
      noRain = true;
    } else { noRain = false; }
    if (waterTemp - 10 < dayWaterTemp) {
      digitalWrite(relay[5], HIGH);  //land heat on
    if (waterTemp >= dayWaterTemp) {
      digitalWrite(relay[5], LOW);   //land heat off
    //if all conditions are within half the hysteresis margins, do nothing
    if (airTemp <= (desiredAirTemp + hysteresis / 4) && airTemp >= (desiredAirTemp - hysteresis / 4) && humidity <= (desiredHumidity + hysteresis / 2) && humidity >= (desiredHumidity - hysteresis / 2)) {
    if (humidityMonitoring) {
      if (airTemp > airHigh && humidity > humidityHigh) {
        climateState = CASE1;
      else if (airTemp < airLow && humidity < humidityLow) {
        hold = true;
        climateState = CASE2;
      else if (airTemp > airHigh && humidity < humidityLow) {
        hold = true;  // prevent other singular trigger
        climateState = CASE3;
      else if (airTemp < airLow && humidity > humidityHigh) {
        hold = true;
        climateState = CASE4;
    if (!hold) {
      if (humidity > humidityHigh && humidityMonitoring) {
        climateState = CASE5;
      else if (airTemp > airHigh) {
        climateState = CASE6;
      else if (humidity < humidityLow) {
        climateState = CASE7;
      else if (airTemp < airLow) {
        climateState = CASE8;
  if (!dayTime) { //night schedule
    if (waterTemp - 10 < nightWaterTemp) {
    if (waterTemp >= nightWaterTemp) {
    if (humidity >= humidityLow && humidity <= humidityHigh) {
    else if (airTemp > airHigh) { //cannot run until AirCo
      //climateState = CASE9; //pushes humidity too low in summer
      climateState = CASE10;
    else if (airTemp < minAirTemp) {
      climateState = CASE11;
    else if (humidity > (970)) { //don't let it get 100%
      climateState = CASE12;
void climateChange() {  //it's real
  //If desiredAirTemp has a new value, start a transition from the old to the new
  if (desiredAirTemp != oldAirTemp && !airTransition) { //If the program sets a new target temperature, start to transition gradually.
    airStartVal = oldAirTemp;
    airEndVal = desiredAirTemp;
    airTransition = true;
  if (airTransition) {
    desiredAirTemp = smoothTransition(airStartVal, airEndVal, 40, 15000, 1, updateTemp); //In this case 40 intervals of 15 seconds. 1 for temp 0 for humidity
    if (desiredAirTemp == airEndVal) {
      oldAirTemp = desiredAirTemp;
      airStep = 0;  //reset step for next transition
      airTransition = false; //exit transition phase
  if (desiredHumidity != oldHumidity && !humTransition) {
    humStartVal = oldHumidity;
    humEndVal = desiredHumidity;
    humTransition = true;
  if (humTransition) {
    desiredHumidity = smoothTransition(humStartVal, humEndVal, 40, 15000, 0, updateHum);
    if (desiredHumidity == humEndVal) {
      oldHumidity = desiredHumidity;
      humStep = 0;
  if (climateState != previousClimateState) {
    switch (climateState) {
      case CASE0:                      //default do nothing
        digitalWrite(relay[1], LOW);  //fans off
        pwmVal1 = 0;
        analogWrite(pwmPin_1, pwmVal1);
        digitalWrite(relay[6], LOW);  //window heating off --- ??? maybe not?
          digitalWrite(relay[4], LOW);  //fogger off
        outputDebugln("CASE 0");
      case CASE1:                      //decrease temperature and decrease humidity
        digitalWrite(relay[1], HIGH);  //fans on
        outputDebugln("CASE 1 airTemp high & humidity high --- fans on max");
        startup = 0;
        startDelay = millis();
      case CASE2:                      //increase temperature and increase humidity
        pwmVal1 = 0;
        digitalWrite(relay[4], HIGH);  //fogger on
        digitalWrite(relay[6], HIGH);  //window heating on
        outputDebugln("CASE 2 airTemp low & humidity low --- heating on & fogger on");
      case CASE3:                      //decrease temperature and increase humidity
        //running sequence below
        outputDebugln("CASE 3 airTemp high & humidity low --- fans off & sprinklers on");
      case CASE4:                      //increase temperature and decrease humidity
        digitalWrite(relay[6], HIGH);  //heating on
        digitalWrite(relay[1], HIGH);  //fans low
        pwmVal1 = 60;                  //low state --- needs testing --- 23% is lowest setting for current fans to start moving
        outputDebugln("CASE 4 airTemp low && humidity high --- heating on & fans low");
      //single states
      case CASE5:                      //decrease humidity
          digitalWrite(relay[1], HIGH);//fans on
          startup = 0;
        outputDebugln("CASE 5 humidity high --- fans on");
      case CASE6:                      //decrease temperature
        outputDebugln("CASE 6 airTemp high --- fans on");
        startup = 0;
      case CASE7:                      //increase humidity
        pwmVal1 = 0;
        outputDebugln("CASE 7 humidity low --- fogger on");
      case CASE8:                      //increase temperature
        pwmVal1 = 0;
        digitalWrite(relay[6], HIGH);  //window heat on
        outputDebugln("CASE 8 airTemp low --- heat on");
      //night
      case CASE9:                      //decrease temperature
        outputDebugln("CASE 9 airTemp high --- fans on");
        startup = 0;
      case CASE10:                     //increase humidity
        pwmVal1 = 0;
        outputDebugln("CASE 10 humidity low --- fogger on");
      case CASE11:                     //increase temperature
        pwmVal1 = 0;
        outputDebugln("CASE 11 airTemp low --- heat on");
      case CASE12:                     //decrease humidity
        outputDebugln("CASE 12 humidity max --- fans on");
        startup = 0;
    previousClimateState = climateState;
  if (climateState == CASE1) {      //decrease temperature and decrease humidity
    fanSpeedController(2);
  else if (climateState == CASE3) {  //decrease temperature and increase humidity
    //turn on sprinklers and wait a bit for endothermic evaporation, then turn on fans again. This event is unlikely to happen.
    static byte state = 0;  //at start go to state 0 with ++
    if (millis() - intervalMark >= sequenceInterval[state]) {
      // go to the next state
      state++;
      state = state % 5;
      outputDebug(F("state = "));
      outputDebugln(state);
      // act according to state
      switch (state) {
        case 0:  //fans off and wait 2 seconds
          pwmVal1 = 0;
        case 1:  //sprinklers for 3 seconds
          digitalWrite(relay[2], HIGH);
        case 2:  //sprinklers off and wait another 30 seconds
          digitalWrite(relay[2], LOW);
        case 3:  //fans back on for 5 minutes
          if (airTemp > maxAirTemp) { airTemp = maxAirTemp; }
          mappedTemp = map(airTemp, desiredAirTemp, (desiredAirTemp + 50), 0, 100);
          pwmVal1 = multiMap<float>(mappedTemp, input, output, 11);
        case 4:  //same as 3 because of max lenght difficulty
      intervalMark = millis();
  else if (climateState == CASE5) {  //decrease humidity
    fanSpeedController(1);
  else if (climateState == CASE6) {  //decrease temperature
  else if (climateState == CASE8) {  //increase temperature
    //digitalWrite(relay[1], LOW); //fans_2 to be made icm with front window ventilation
    //mappedTemp = map(airTemp, desiredAirTemp, maxAirTemp, 0, 100);
    //pwmVal2 = multiMap<float>(mappedTemp, input, output, 11);
  else if (climateState == CASE9) {  //decrease temperature
  else if (climateState == CASE12) {  //decrease humidity
  pwm1Speed = map(pwmVal1, 0, 255, 0, 100);
void makeItRain() { //needs work
  if (millis() - previousPoint >= 3600000UL) { // rainstorm is after 1 hPa drop for 3 consecutive hours
    currentReading = pressureAverage;
    if(previousReading - currentReading >= rainCalculationFactor) {
      rainCounter ++;
      outputDebug("rainCounter ");
      outputDebugln(rainCounter);
    } else if (rainCounter != 0) {
      rainCounter --;
    previousReading = currentReading;
    previousPoint = millis ();
  if (rainCounter >= 3) {
    rainyDay = true;
    rainCounter = 1;
    outputDebugln("it's a rainy day!");
void fanSpeedController(int type) {
  float data, targetValue, maxValue, rangeValue;
  if (climateControlPause) { //stop fans during pause
    pwmVal1 = 0;
  if (!climateControlPause) {
    if (type == 1) {
      if (dayTime) {
        data = humidity;
        maxValue = maxHumidity;
        targetValue = desiredHumidity;
        rangeValue = targetValue + (2 * hysteresis);
      } else if (!dayTime) { //at night allow high humidity but not 100%
        data = humidity;
        maxValue = 1000;
        targetValue = 980;
        rangeValue = 1000;
    if (type == 2) {
      data = airTemp;
      maxValue = maxAirTemp;
      targetValue = desiredAirTemp;
      rangeValue = targetValue + hysteresis;
    if (data > maxValue) { data = maxValue; }
    switch (startup) { //set PWM to minimum value to start the fan moving
      case 0:
        pwmVal1 = 60;
        if (millis() - startDelay >= 1000) { startup++; }
      case 1: //switch to automatic variable control
        mappedTemp = map(data, targetValue, rangeValue, 0, 100);
float smoothTransition(float start, float end, uint8_t intervals, unsigned long intervalTime, bool temp, TransitionCallback callback) {
  float delta = (float)(end - start) / intervals;
  if (temp) {
    if ((millis() - lastAirUpdateTime >= intervalTime) && (airStep <= intervals)) {
      start += delta * airStep;
      airStep++;
      lastAirUpdateTime = millis();
      callback(start); //callback function for real-time updated values during transition
      //outputDebug("transitioning to new temperature value ");
      //outputDebugln(start);
    if ((millis() - lastHumUpdateTime >= intervalTime) && (humStep <= intervals)) {
      start += delta * humStep;
      humStep++;
      lastHumUpdateTime = millis();
      callback(start);
      //outputDebug("transitioning to new humidity value ");
  return start;
void updateTemp(float value) {
    myScreen.print((value / 10), 1);
void updateHum(float value) {
//                                               ENTER AND SAVE VALUES TO EEPROM
void startChangeTime(int eepromHour, int eepromMinutes, int xPos, int yPos) { // xPos is starting location for Hour digits. xPos for minutes is shifted right
  int hourTime = EEPROM.readByte(eepromHour);
  int minuteTime = EEPROM.readByte(eepromMinutes);
  bool hourHasBeenSaved = false;
  bool minuteHasBeenSaved = false;
  bool everythingHasBeenSaved = false;
  ChangeTimeState state = CHANGING_HOUR;
  //if (!everythingHasBeenSaved) {
  while (!everythingHasBeenSaved) {
    switch (state) {
      case CHANGING_HOUR:
        if (checkJoystick() == Right) { right_was_down = true; delay(200); }
        hourTime = changeTime(hourTime, 0, 23, xPos, yPos);
          EEPROM.writeByte(eepromHour, hourTime);
          myScreen.setTextColor(ST77XX_WHITE, ST77XX_BLACK); //revert color to normal
          myScreen.setCursor(xPos, yPos);
          printDigits(hourTime);
          hourHasBeenSaved = true;
        if (hourHasBeenSaved && !minuteHasBeenSaved) {
          state = CHANGING_MINUTE;
      case CHANGING_MINUTE:
        minuteTime = changeTime(minuteTime, 0, 59, xPos +35, yPos); //+35 to shift from hour digits to minute digits
          EEPROM.writeByte(eepromMinutes, minuteTime);
          myScreen.setCursor(xPos +35, yPos);
          printDigits(minuteTime);
          minuteHasBeenSaved = true;
        if (minuteHasBeenSaved && hourHasBeenSaved) {
          state = SAVING_COMPLETE;
          delay(400);
      case SAVING_COMPLETE:
        everythingHasBeenSaved = true;
        //outputDebugln("saving completed");
int changeTime(int &timeValue, int minValue, int maxValue, int xPos, int yPos) {
  myScreen.setTextColor(ST77XX_BLACK, ST77XX_WHITE); //invert the selected block
  printDigits(timeValue);
    timeValue++;
    if (timeValue > maxValue) {
      timeValue = minValue;
    timeValue--;
    if (timeValue < minValue) {
      timeValue = maxValue;
  return timeValue;
void startChangeSeconds(int eepromSeconds, int xPos, int yPos) {
  int secondsTime = EEPROM.readByte(eepromSeconds);
  bool timeHasBeenSaved = false;
  bool valueStored = false; //extra delay flag to prevent instant exit and restart
  while(!timeHasBeenSaved) {
    secondsTime = changeTime(secondsTime, 0, 59, xPos, yPos);
      EEPROM.writeByte(eepromSeconds, secondsTime);
      printDigits(secondsTime);
      valueStored = true;
      //outputDebugln("duration stored");
    if (valueStored){
      delay(200);
      timeHasBeenSaved = true;
void printTimer(int number, int xPos, int yPos, int eepromNumber, bool printDuration) {
  myScreen.print("TIMER");
  myScreen.print(number);
  myScreen.setCursor(xPos + 80, yPos); // 80 only works for the time + duration notation
  printDigits(EEPROM.readByte(eepromNumber));
  myScreen.print(":");
  printDigits(EEPROM.readByte(eepromNumber + 1));
  if (printDuration){
    myScreen.print(" DURATION");
    myScreen.setCursor(xPos + 260, yPos);
    printDigits(EEPROM.readByte(eepromNumber + 2));
void printMinMax(int xPos, int yPos, int eepromNumber, const char* txt, const char* txt2) {
  myScreen.print(txt);
  myScreen.print(txt2);
void setValue(int xPos, int yPos, int minValue, int maxValue, int eepromNumber, int shiftToRight) {
  int xPos2 = xPos + shiftToRight; //adjusting location after text
  int valueToSet = EEPROM.readByte(eepromNumber);
  bool valueHasBeenStored = false;
  bool setValueStored = false; //extra delay flag to prevent instant exit and restart
  while (!valueHasBeenStored) {
    valueToSet = changeTime(valueToSet, minValue, maxValue, xPos2, yPos);
      EEPROM.writeByte(eepromNumber, valueToSet);
      myScreen.setCursor(xPos2, yPos);
      printDigits(valueToSet);
      setValueStored = true;
    if (setValueStored) {
      delay(200);
      valueHasBeenStored = true;
//                                                     AUTOMATED TIMER FUNCTIONS
void automatedSwitching() {
  currentTime = getCurrentTime();
//====================================LIGHTS=====================================
  int lightOnHour = EEPROM.readByte(0), lightOnMinute = EEPROM.readByte(1), lightOffHour = EEPROM.readByte(2), lightOffMinute = EEPROM.readByte(3);
  int onTime = (lightOnHour * 100) + lightOnMinute;
  int offTime = (lightOffHour * 100) + lightOffMinute;
  switchTimer(0, onTime, offTime); //switchTimer(relay, ON, OFF)
//====================================VENTILATION================================
  int delayedOn = onTime + 30; //30 minutes after light on
  int delayedOff = offTime - 30; //30 minutes before light off
  //switchTimer (1, delayedOn, delayedOff); // fans should not be on by default
//====================================SPRINKLERS=================================
  int rain1Hour = EEPROM.readByte(4),   rain1Minute = EEPROM.readByte(5),  rain1Duration = EEPROM.readByte(6);
  int rain2Hour = EEPROM.readByte(8),   rain2Minute = EEPROM.readByte(9),  rain2Duration = EEPROM.readByte(10);
  int rain3Hour = EEPROM.readByte(12),  rain3Minute = EEPROM.readByte(13), rain3Duration = EEPROM.readByte(14);
  int rain4Hour = EEPROM.readByte(16),  rain4Minute = EEPROM.readByte(17), rain4Duration = EEPROM.readByte(18);
  int rain5Hour = EEPROM.readByte(20),  rain5Minute = EEPROM.readByte(21), rain5Duration = EEPROM.readByte(22);
  if (!noRain) {
    switchCountdown(2, rain1Hour, rain1Minute, rain1Duration, 1); //switchCountdown(relay, start hour, start minute, duration, timerNumber)
    switchCountdown(2, rain2Hour, rain2Minute, rain2Duration, 2);
    switchCountdown(2, rain3Hour, rain3Minute, rain3Duration, 3);
    switchCountdown(2, rain4Hour, rain4Minute, rain4Duration, 4);
    switchCountdown(2, rain5Hour, rain5Minute, rain5Duration, 5);
  if (rainyDay) {
    switchCountdown(2, 16, 5, 10, 13); //extra 'rain' at 16:05 for x secs
    switchCountdown(2, 20, 5, 10, 14);
    if (!hasNotRunYet[13] || !hasNotRunYet[14]) { //if one of the above 2 timers goes off, then reset rainyDay
      rainyDay = false;
      outputDebugln("extra rain");
//====================================BACKWALL DRIP==============================
  int drip1Hour = EEPROM.readByte(24),   drip1Minute = EEPROM.readByte(25),  drip1Duration = EEPROM.readByte(26);
  int drip2Hour = EEPROM.readByte(28),   drip2Minute = EEPROM.readByte(29),  drip2Duration = EEPROM.readByte(30);
  switchCountdown(3, drip1Hour, drip1Minute, drip1Duration, 6);
  switchCountdown(3, drip2Hour, drip2Minute, drip2Duration, 7);
//====================================FOGGER=====================================
  int fogOnHour = EEPROM.readByte(32), fogOnMinute = EEPROM.readByte(33), fogOffHour = EEPROM.readByte(34), fogOffMinute = EEPROM.readByte(35);
  int fogOn = (fogOnHour * 100) + fogOnMinute;
  int fogOff = (fogOffHour * 100) + fogOffMinute;
  //switchTimer(4, fogOn, fogOff); //is preventing fogger to be turned on any other time than it's scheduled on time. could be a problem
  switchCountdown(4, fogOnHour, fogOnMinute, 3600000, 15); //on for 1 hr as an alternative?
  if (currentTime >= onTime && currentTime <= fogOn) {
    humidityMonitoring = false;
//====================================WINDOW HEAT================================
  //switchTimer(6, onTime, offTime); //for now linked to temperature controll. Will eventuelly be on permanent and fans over the heat to controll the temp
//====================================AIRPUMP====================================
  int airpump1Hour = EEPROM.readByte(38),  airpump1Minute = EEPROM.readByte(39), airpump1Duration = EEPROM.readByte(40);
  int airpump2Hour = EEPROM.readByte(42),  airpump2Minute = EEPROM.readByte(43), airpump2Duration = EEPROM.readByte(44);
  int airpump3Hour = EEPROM.readByte(46),  airpump3Minute = EEPROM.readByte(47), airpump3Duration = EEPROM.readByte(48);
  int airpump4Hour = EEPROM.readByte(50),  airpump4Minute = EEPROM.readByte(51), airpump4Duration = EEPROM.readByte(52);
  int airpump5Hour = EEPROM.readByte(54),  airpump5Minute = EEPROM.readByte(55), airpump5Duration = EEPROM.readByte(56);
  switchCountdown(7, airpump1Hour, airpump1Minute, airpump1Duration, 8);
  switchCountdown(7, airpump2Hour, airpump2Minute, airpump2Duration, 9);
  switchCountdown(7, airpump3Hour, airpump3Minute, airpump3Duration, 10);
  switchCountdown(7, airpump4Hour, airpump4Minute, airpump4Duration, 11);
  switchCountdown(7, airpump5Hour, airpump5Minute, airpump5Duration, 12);
void switchTimer(int relayNumber, int startTime, int stopTime) {
  if (currentTime >= startTime && currentTime < stopTime) {
    if (digitalRead(relay[relayNumber]) == LOW) {
      digitalWrite(relay[relayNumber], HIGH);
      outputDebug("Timer ");
      outputDebug(relayNumber);
      outputDebugln(" on");
  if (currentTime < startTime || currentTime >= stopTime) {
    if (digitalRead(relay[relayNumber]) == HIGH) {
      digitalWrite(relay[relayNumber], LOW);
      outputDebugln(" off");
void switchCountdown(int relayNumber, int startHour, int startMinute, long duration, int timerNumber) {
  currentHour = getLocalHour();
  currentMinute = getLocalMinutes();
  if (currentHour == startHour && currentMinute == startMinute && hasNotRunYet[timerNumber]) {
    countdown[timerNumber] = millis();
    hasNotRunYet[timerNumber] = false; //flag prevents being activated more than once
    timerActive[timerNumber] = true;
    outputDebug("relay ");
    outputDebug(" on with ");
    outputDebug(duration);
    outputDebugln(" seconds countdown");
  if (timerActive[timerNumber] && digitalRead(relay[relayNumber]) == HIGH) {
    if (millis() - countdown[timerNumber] > (duration * 1000)) { //seconds to milliseconds
      timerActive[timerNumber] = false;
  if (!hasNotRunYet[timerNumber]) {
    if (millis() - countdown[timerNumber] > resetDelay) {
      hasNotRunYet[timerNumber] = true;
      outputDebug("hasNotYetRun ");
      outputDebug(timerNumber);
      outputDebugln(" reset");
void fanPause() {
  if (digitalRead(relay[2]) == HIGH && !climateControlPause) {
    pauseStart = millis();
    analogWrite(pwmPin_1, 0); //fans off
    outputDebugln("ClimateControl paused");
    climateControlPause = true;
    if (millis() - pauseStart > fanPauseTime) {
      climateControlPause = false;
      outputDebugln("Pause ended");
solution here Arduino RTC does not stay in sync despite use of ArduinoCloud.getLocalTime(); - #35 by arneko
