Hey folks, I'm using the usb a port on my GIGA R1 to log some data. Initially during the first 10 mins there is no issue in writing the data to the usb then all of a sudden it abruptly crashes indicated by red light of doom. The crash occurs right when the code is at FILE = fopen("...").
#include <Wire.h>
#include <WiFi.h>
#include <math.h>
#include <Arduino_USBHostMbed5.h>
#include <DigitalOut.h>
#include "Variables.h"
#include "PinAssign.h"
#include "MyConstants.h"
#include "thingProperties.h"
#include "VRTC.h"
USBHostMSD msd;
mbed::FATFileSystem usb("usb");
int transfercounter = 0;
bool transferinterval = true;
Wire.begin(); //SDA,SCl serial buses (All other I2C components)
Wire1.begin();//SDA1,SCl1 serial buses (EEPROM)
//Establish WiFi connection
WIFIConnectionHandler();
ArduinoCLoudConnection();
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
//GPIO pins for sensors
// Float pins
pinMode(top1, INPUT_PULLUP);
pinMode(bottom1, INPUT_PULLUP);
pinMode(top2, INPUT_PULLUP);
pinMode(bottom2, INPUT_PULLUP);
pinMode(dtop, INPUT_PULLUP);
pinMode(dbot, INPUT_PULLUP);
Serial.println("Float pins initiated");
// Flow Sensor pins
pinMode(FLOW_SENSOR_1, INPUT_PULLUP);
pinMode(FLOW_SENSOR_2, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(FLOW_SENSOR_1), flow1ISR, RISING);
Serial.println("Flow sensor pin 5 initialized");
attachInterrupt(digitalPinToInterrupt(FLOW_SENSOR_2), flow2ISR, RISING);
Serial.println("Flow sensor pin 14 initialized");
//GPIO pins for relays
// Valve relays
pinMode(t1d, OUTPUT);
digitalWrite(t1d, LOW);
pinMode(t2d, OUTPUT);
digitalWrite(t2d, LOW);
pinMode(dt1, OUTPUT);
digitalWrite(dt1, LOW);
pinMode(dt2, OUTPUT);
digitalWrite(dt2, LOW);
Serial.println("Valve relays defined");
// Pump Relays
pinMode(dsp, OUTPUT);
digitalWrite(dsp, LOW);
pinMode(drp, OUTPUT);
digitalWrite(drp, LOW);
pinMode(dpc1, OUTPUT);
digitalWrite(dpc1, LOW);
pinMode(dpc2, OUTPUT);
digitalWrite(dpc2, LOW);
Serial.println("Pump relays defined");
// Fan Relays
pinMode(df, OUTPUT);
pinMode(fcu, OUTPUT);
Serial.println("Fan relays defined");
digitalWrite(df, LOW);
digitalWrite(fcu, LOW);
delay(2000);
// Read previous state from EEPROM
lowTrig1 = readTriggerState(0);
lowTrig2 = readTriggerState(1);
overflow = readTriggerState(2);
Serial.println("LowTrig1 from EEPROM: " + String(lowTrig1) + "\nLowTrig2 from EEPROM: " + String(lowTrig2) + "\nOverflow from EEPROM: " + String(overflow));
//Sensors/Modules setup
// SHT connection
Precision = PRECISION_HIGH;
Heater = NO_HEATER;
// Initialize first sensor
select_channel(SENSOR1_CHANNEL);
Serial.println("Initializing first ES13511 sensor");
ES135xx_probe();
// Initialize second sensor
select_channel(SENSOR2_CHANNEL);
Serial.println("Initializing second ES13511 sensor");
ES135xx_probe();
// Temp sensor
sensors.begin();
//Begin RTC
setNtpTime();
//USB
USBconnection();
void loop(){
currentTime = millis();
// Check if connected to WiFi
if(WiFi.status() != WL_CONNECTED){
Serial.println("\nOffline loop");
Serial.print("System Clock: ");
Serial.println(getLocaltime());
//offline loop
loop2();
if (currentTime - currentMillis >= 120000 ) {
digitalWrite(PA_15, LOW);
Serial.println("Attempting reconnection...");
USBconnection();
else {
//online loop
loop1();
Loop 2 :
//OFFLINE Loop
void loop2(){
//Reset control variables
fanswitch = false;
SaltTransfer2_1 = false;
SaltTransfer1_2 = false;
T1Def = false;
T2Def = false;
testswitch = false;
reset = false;
FanisON = true;
dehumidifier_status = true;
dehumidifier_Status = false;
dPC_Status = false;
printonce = false;
power = false;
previousTime = currentTime;
USBstorage();
FloatSensorReading();
SensorReadings();
Dehumidification();
Cooling();
onResetChange();
delay(100);
Functions:
void USBconnection(){
pinMode(PA_15, OUTPUT); //enable the USB-A port
digitalWrite(PA_15, HIGH);
while (!msd.connect()) {
Serial.println("Connecting to USB device...");
Serial.println("USB device connected.");
if (usb.mount(&msd) == 0) {
Serial.println("USB drive mounted.");
Serial.println("Failed to mount USB drive.");
void USBstorage(){
String timestamp = getLocaltime();
// Create a file on the USB drive
FILE *file = fopen("/usb/Sensor_Data.txt", "a"); // Append mode
if (file) {
if(USBon){
fprintf(file, " | Storage RH%% | Storage T°C | Utility RH%% | Utility T°C | Tank1 T°C | Tank2 T°C | Float status 1 | Float status 2 | Float status overflow |\n");
USBon = false;
fprintf(file, "%s| ", timestamp.c_str());
fprintf(file, " %.2f |", storage_hum);
fprintf(file, " %.2f |", storage_temp);
fprintf(file, " %.2f |", utility_hum);
fprintf(file, " %.2f |", utility_temp);
fprintf(file, " %.2f |", Temp_tank1);
fprintf(file, " %.2f |", Temp_tank2);
fprintf(file, " %d |", lowTrig1);
fprintf(file, " %d |", lowTrig2);
fprintf(file, " %d |\n", overflow);
Serial.println("Data written to USB drive.");
fclose(file);
Serial.println("Error opening file.");
i have also noticed that if the loop takes considerable time between cycles then the board crashes immediately in the second cycle just after uploading the sketch. i tried to dismount it before i try to connect to the wifi network and reconnect it back after the wifi connection block to mitigate this issue but the issue persists.
//offline loop
loop2();
USBconnection();
Output for the above block:
03:36.046 -> Offline loop
12:03:36.046 -> System Clock: 2024-06-28 12:04:42
12:03:36.046 -> Data written to USB drive.
12:03:36.090 -> Reading from EEPROM----> Float status 1: 1, Float status 2: 1, Float status 3:1
12:03:36.090 -> Tank 1: ACTIVE | Tank 2: ACTIVE | Supply pump: INACTIVE
12:03:36.090 -> Check wiring
12:03:36.090 -> Storage Temp = 0.00 C Storage RH = 0.00% | Check wiring
12:03:36.090 -> Utility Temp = 0.00 C Utility RH = 0.00%
12:03:36.808 -> Temperature 1: -127.00 C | Temperature 2: -127.00 C
12:03:36.808 -> Flow Rate supply: 0.00 L/min | Flow Rate return: 0.00 L/min
12:03:36.808 ->
12:03:37.810 -> Check wiring
12:03:37.810 -> Dew point cooler OFF
12:03:38.911 -> Attempting reconnection...
12:03:38.911 -> Attempting to connect to primary WiFi network...
12:03:39.607 -> ...........
12:03:40.604 -> Failed to connect to the primary network. Trying the first alternative network...
12:04:16.468 -> ..........
12:04:17.335 -> Failed to connect to the first alternative network. Trying the second one...
12:04:18.039 -> ...........
12:04:19.057 -> Failed to connect to both alternative networks.
12:04:19.057 -> Connecting to USB device...
12:04:20.033 -> Connecting to USB device...
12:04:21.147 -> USB device connected.
12:04:21.147 -> Failed to mount USB drive.
12:04:22.150 ->
12:04:22.150 -> Offline loop
12:04:22.150 -> System Clock: 2024-06-28 12:05:28
the board crashed here. Dont know why it fails to mount usb. The board crashes at the same place even if i remove the wifi checking block just that it runs for a few mins then crashes. Any help would be appreciated
