GLCD library for LM12864LFW
hello ,
when i tried to use GLCD library for LM12864LFW in this link
http://playground.arduino.cc/Code/LCD12864
there is an error
C:\Program Files (x86)\Arduino\libraries\LCD12864\LCD12864.cpp:20:21: fatal error: wiring.h: No such file or directory #include <wiring.h>
thanks ,
any help ?
Modern libraries look at the version number of the IDE.
Really old pre- version 1.0.0 will want Wiring.h
Modern IDEs like v1.6.x will want Arduino.h
I suggest that you upgrade to a current version of Arduino IDE. e.g. v1.6.9
And a current graphics library. I am guessing that you have a regular KS0108 display.
Untested. I am not at a PC at the moment.
thanks david i will upgrade my IDE but my IDE is 1.6.8 and i have GLCD LM12864LFW not KS0108 is this work after upgrade .
thanks in advance
Well, I googled LM12864LFW and it looks very much like a KS0108 style of display.
I then googled your Arduino Playground - LCD12864 and found that it is designed for a ST7920 style of display.
I suggest that you find a regular KS0108 library and a KS0108 tutorial. The KS0108 is the most common form of 128x64 GLCD display. e.g. the OpenGLCD library or the U8glib library
David.
david_prentice:
I then googled your Arduino Playground - HomePage and found that it is designed for a ST7920 style of display.
David.
hi david,
thanks for your help but i have upgraded to 1.6.9 and also have the same problem #include <wiring.h>
any help about this GLCD for LM12864LFW
eng_ibrahim_comm2012,
you have 2 issues:
  1. you are trying to use a very old library that won't work on any IDE since 1.0
  2. you are wanting to use a library that will not work for the chipset on glcd module you say you have.
Take david's advice and switch to a newer & maintained library that works with the IDE you have and more importantly, supports the chipset on the glcd you say you have.
--- bill
