#include <Keypad.h>
const byte ROWS = 4;
const byte COLS = 4;
int total =0;
char hexaKeys[ROWS][COLS] = {
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
byte rowPins[ROWS] = {9, 8, 7, 6};
byte colPins[COLS] = {5, 4, 3, 2};
Keypad customKeypad = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
void setup(){
void loop(){
int customKey = customKeypad.getKey();
if (customKey==49){
total++;
Serial.println(total);
i am facing a problem where the total global variable is not increasing to more than 1 when I press a key on the keypad.
DaveX
May 30, 2024, 1:52pm
3
Works for me. Might be power/wiring resetting the sketch.
If you drop your code into keypad-input.ino - Wokwi ESP32, STM32, Arduino Simulator simulation (from wokwi-membrane-keypad Reference | Wokwi Docs )
...it counts up on the '1' button fine:
1
2
3
4
5
6
This should happen with any key i press.
update if 1 is pressed on the keypad
b707
May 30, 2024, 2:11pm
7
So did you test the code with pressing '1' or just any key?
try again and now press the ONE many times
i tried but did not work!
The value (total) automatically turns to 0 .
if 1 is pressed continuously then only it increases.
any solution?
DaveX
May 30, 2024, 2:18pm
10
That looks exactly like what the code is written to do.
What do you intend it to do?
The value of total automatically turns to 0.
increasing the value to 10,after 2 or 5 sec it automatically turns to zero.
b707
May 30, 2024, 2:24pm
12
Please add the line to setup()
void setup(){
Serial.println("Reset");
and test again
Show the output of the Serial Monitor while you pressing the various keys
b707
May 30, 2024, 2:30pm
14
Your board restarted while you pressed some keys.
It seems that your connection to the keyboard is incorrect (short circuit)
means the usb port is not working properly?
but the power led in arduino is not turning off even for a second ?
b707
May 30, 2024, 2:36pm
16
NO
I meant the connection to your arduino keypad.
The USB has nothing to do with the issue
meaning that the wire are not loosy?
DaveX
May 30, 2024, 2:39pm
18
Since the Arduino only runs setup() once per powerup/reset, the repeated "RESET" means that something must be resetting the board. Maybe there's some loose wire somewhere connecting power to ground or something pushing the red RESET button on the Uno?
