Got this error when compiling my program
expected constructor, destructor, or type conversion before '(' token
pinMode (buttonApin, INPUT_PULLUP);
pinMode (buttonBpin, INPUT_PULLUP);
if(digitalRead(buttonApin) == LOW)
digitalWrite(ledPin, HIGH);
if (digitalRead(buttonBpin) == LOW)
digitalWrite(ledPin, LOW);
Do people even look at their code when they get an error or do they just go straight to posting?
I think you've got a couple of lines that have tried to escape your setup method.
Delta_G:
And then when you fix that, you'll need to declare the pin names.
This is your full error message
sketch_jan04a:8: error: expected constructor, destructor, or type conversion before '(' token
sketch_jan04a:9: error: expected constructor, destructor, or type conversion before '(' token
C:\Users\sterretje\AppData\Local\Temp\arduino_3cedea2dd92612558140226e5eb8e195\sketch_jan04a.ino: In function 'void loop()':
sketch_jan04a:16: error: 'buttonApin' was not declared in this scope
   if (digitalRead(buttonApin) == LOW)
sketch_jan04a:18: error: 'ledPin' was not declared in this scope
sketch_jan04a:21: error: 'buttonBpin' was not declared in this scope
sketch_jan04a:23: error: 'ledPin' was not declared in this scope
exit status 1
Usually you work your way down fixing the first one, next the second one etc.
Please learn how to use code tags when posting code and error message.
