Hello guys I am newbe here! I need your help with a code for running a PARALLAX GPS MODULE PMB-648 with arduino duemilanove. I need to extract the NMEA data, just the speed mph and print it to a seven segment display. I am using a 4-digit LED-driver with I^2C-Bus interface SAA106.
I have only basic computer skills loops and switches. Pin TXD in the module goes to RX pin in arduino, but I am not so sure if that is the way is suppose to be connected, and I believe I am suppose to connect the SDA and CLK pins of the IC to pin number 4 and 5 analog input in the arduino. The PDF contains the slave address for the IC. The only code example i have is from arduino playground extracting GPS data I will appreciate a complete code if that is not too much to ask. I attached a picture of the 4-Digit LED-driver and the GPS module.
GPS module http://www.microcenter.com/single_product_results.phtml?product_id=0377206
4-digit LED-Driver http://www.nxp.com/documents/data_sheet/SAA1064_CNV.pdf
Example code for connecting a Parallax GPS module to the Arduino
#include <string.h>
#include <ctype.h>
int ledPin = 13; // LED test pin
int rxPin = 0; // RX PIN
int txPin = 1; // TX TX
int byteGPS=-1;
char linea[300] = "";
char comandoGPR[7] = "$GPRMC";
int cont=0;
int bien=0;
int conta=0;
int indices[13];
pinMode(ledPin, OUTPUT); // Initialize LED pin
pinMode(rxPin, INPUT);
pinMode(txPin, OUTPUT);
Serial.begin(4800);
for (int i=0;i<300;i++){ // Initialize a buffer for received data
linea[i]=' ';
digitalWrite(ledPin, HIGH);
byteGPS=Serial.read(); // Read a byte of the serial port
if (byteGPS == -1) { // See if the port is empty yet
delay(100);
linea[conta]=byteGPS; // If there is serial port data, it is put in the buffer
conta++;
Serial.print(byteGPS, BYTE);
if (byteGPS==13){ // If the received byte is = to 13, end of transmission
digitalWrite(ledPin, LOW);
cont=0;
bien=0;
for (int i=1;i<7;i++){ // Verifies if the received command starts with $GPR
if (linea[i]==comandoGPR[i-1]){
bien++;
if(bien==6){ // If yes, continue and process the data
if (linea[i]==','){ // check for the position of the "," separator
indices[cont]=i;
cont++;
if (linea[i]=='*'){ // ... and the "*"
indices[12]=i;
cont++;
Serial.println(""); // ... and write to the serial port
Serial.println("");
Serial.println("---------------");
for (int i=0;i<12;i++){
switch(i){
case 0 :Serial.print("Time in UTC (HhMmSs): ");break;
case 1 :Serial.print("Status (A=OK,V=KO): ");break;
case 2 :Serial.print("Latitude: ");break;
case 3 :Serial.print("Direction (N/S): ");break;
case 4 :Serial.print("Longitude: ");break;
case 5 :Serial.print("Direction (E/W): ");break;
case 6 :Serial.print("Velocity in knots: ");break;
case 7 :Serial.print("Heading in degrees: ");break;
case 8 :Serial.print("Date UTC (DdMmAa): ");break;
case 9 :Serial.print("Magnetic degrees: ");break;
case 10 :Serial.print("(E/W): ");break;
case 11 :Serial.print("Mode: ");break;
case 12 :Serial.print("Checksum: ");break;
for (int j=indices[i];j<(indices[i+1]-1);j++){
Serial.print(linea[j+1]);
Serial.println("");
conta=0; // Reset the buffer
linea[i]=' ';
Thanks,
