Hello guys, I am creating a project: GPS clock using Arudino and GPS module (Neo 6m)
I have locked GPS module to satelite and verified its working using lcd screen. Now i am facing trouble code for Displaying time on seven segment display using GPS module
We have done multiplexing of 4 seven segment display (anode)
Problem Statement: Now i need to create code to extract Time from GPS module ( Neo 6m ) and Display it on the four 7 segments's ( Hour : Minute ) format
EDIT: CODE for GPS module with LCD , have verfied on lcd it works. Now instead of LCD need to make it work for 7 segment
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
static const int RXPin = 4, TXPin = 3;// Here we make pin 4 as RX of arduino & pin 3 as TX of arduino
static const uint32_t GPSBaud = 9600;
TinyGPSPlus gps;
SoftwareSerial ss(RXPin, TXPin);
ss.begin(GPSBaud);
while (ss.available() > 0)
if (gps.encode(ss.read()))
displayInfo();
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F("No GPS detected: check wiring."));
while(true);
void displayInfo()
Serial.print(F("Location: "));
if (gps.location.isValid())
Serial.print(gps.location.lat(), 6);
Serial.print(F(","));
Serial.print(gps.location.lng(), 6);
Serial.print(F("INVALID"));
Serial.print(F(" Date "));
if (gps.date.isValid())
Serial.print(gps.date.month());
Serial.print(F("/"));
Serial.print(gps.date.day());
Serial.print(gps.date.year());
Will appreciate if you guys provide me a starting points to understand the logic and code
Hi.
I use the TM1637 4-digit 7-segment LED display module. It needs only 4 connections - 5V, GND, DIO & CLK. There are a couple of libraries available that do all the low level detailed work. All the user does is tell it the number to display and in what format.
Resistors are connected to VCC of 7 Seg, which works as Select Line(“Select Lines” are the wires which enable or disable the communication to the individual devices)
Yes. This was discussed a few months back. Someone had your exact need and worked out a way of using the processor on the TM1637 to drive a large display.
TM1637 can drive a 4-inch 7 segment display using drive transistors.
Your current schematic will not work with a display of that size. The segments tend to be made up of multiple LEDs in series/parallel, requiring more voltage and current than can be supplied directly by an arduino.
< edit > Using four TPIC6B595 shift registers would be another option, if you do not want to multiplex the display.
