Here in the library for TinyGPS:
TinyGPS - a small GPS library for Arduino providing basic NMEA parsing
Copyright (C) 2008-9 Mikal Hart
All rights reserved.
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#include "WProgram.h"
#include "TinyGPS.h"
#define _GPRMC_TERM "GPRMC"
#define _GPGGA_TERM "GPGGA"
TinyGPS::TinyGPS()
: _time(GPS_INVALID_TIME)
, _date(GPS_INVALID_DATE)
, _latitude(GPS_INVALID_ANGLE)
, _longitude(GPS_INVALID_ANGLE)
, _altitude(GPS_INVALID_ALTITUDE)
, _speed(GPS_INVALID_SPEED)
, _course(GPS_INVALID_ANGLE)
, _last_time_fix(GPS_INVALID_FIX_TIME)
, _last_position_fix(GPS_INVALID_FIX_TIME)
, _parity(0)
, _is_checksum_term(false)
, _sentence_type(_GPS_SENTENCE_OTHER)
, _term_number(0)
, _term_offset(0)
, _gps_data_good(false)
#ifndef _GPS_NO_STATS
, _encoded_characters(0)
, _good_sentences(0)
, _failed_checksum(0)
#endif
_term[0] = '\0';
// public methods
bool TinyGPS::encode(char c)
bool valid_sentence = false;
++_encoded_characters;
switch(c)
case ',': // term terminators
_parity ^= c;
case '\r':
case '\n':
case '*':
if (_term_offset < sizeof(_term))
_term[_term_offset] = 0;
valid_sentence = term_complete();
++_term_number;
_term_offset = 0;
_is_checksum_term = c == '*';
return valid_sentence;
case '
Sorry, I did not realise that my it wasn't obvious in my code,
From my understanding, all of this kind of stuff is using EEPROM:
_new_altitude = parse_decimal();
Is this the case? and if so then what can I do about it?
Mowcius: // sentence begin
_term_number = _term_offset = 0;
_parity = 0;
_sentence_type = _GPS_SENTENCE_OTHER;
_is_checksum_term = false;
_gps_data_good = false;
// ordinary characters
if (_term_offset < sizeof(_term) - 1)
_term[_term_offset++] = c;
if (!_is_checksum_term)
_parity ^= c;
void TinyGPS::stats(unsigned long *chars, unsigned short *sentences, unsigned short *failed_cs)
if (chars) *chars = _encoded_characters;
if (sentences) *sentences = _good_sentences;
if (failed_cs) *failed_cs = _failed_checksum;
#endif
// internal utilities
int TinyGPS::from_hex(char a)
if (a >= 'A' && a <= 'F')
return a - 'A' + 10;
else if (a >= 'a' && a <= 'f')
return a - 'a' + 10;
return a - '0';
unsigned long TinyGPS::parse_decimal()
char *p = _term;
bool isneg = *p == '-';
if (isneg) ++p;
unsigned long ret = 100UL * gpsatol(p);
while (gpsisdigit(*p)) ++p;
if (*p == '.')
if (gpsisdigit(p[1]))
ret += 10 * (p[1] - '0');
if (gpsisdigit(p[2]))
ret += p[2] - '0';
return isneg ? -ret : ret;
unsigned long TinyGPS::parse_degrees()
char *p;
unsigned long left = gpsatol(_term);
unsigned long tenk_minutes = (left % 100UL) * 10000UL;
for (p=_term; gpsisdigit(*p); ++p);
if (p == '.')
unsigned long mult = 1000;
while (gpsisdigit(++p))
tenk_minutes += mult * (*p - '0');
mult /= 10;
return (left / 100) * 100000 + tenk_minutes / 6;
// Processes a just-completed term
// Returns true if new sentence has just passed checksum test and is validated
bool TinyGPS::term_complete()
if (_is_checksum_term)
byte checksum = 16 * from_hex(_term[0]) + from_hex(_term[1]);
if (checksum == _parity)
if (_gps_data_good)
++_good_sentences;
#endif
_last_time_fix = _new_time_fix;
_last_position_fix = _new_position_fix;
switch(_sentence_type)
case _GPS_SENTENCE_GPRMC:
_time = _new_time;
_date = _new_date;
_latitude = _new_latitude;
_longitude = _new_longitude;
_speed = _new_speed;
_course = _new_course;
case _GPS_SENTENCE_GPGGA:
_altitude = _new_altitude;
_time = _new_time;
return true;
++_failed_checksum;
#endif
return false;
// the first term determines the sentence type
if (_term_number == 0)
if (!gpsstrcmp(_term, _GPRMC_TERM))
_sentence_type = _GPS_SENTENCE_GPRMC;
else if (!gpsstrcmp(_term, _GPGGA_TERM))
_sentence_type = _GPS_SENTENCE_GPGGA;
return false;
if (_sentence_type != _GPS_SENTENCE_OTHER && _term[0])
switch((_sentence_type == _GPS_SENTENCE_GPGGA ? 200 : 100) + _term_number)
case 101: // Time in both sentences
case 201:
_new_time = parse_decimal();
_new_time_fix = millis();
case 102: // GPRMC validity
_gps_data_good = _term[0] == 'A';
case 103: // Latitude
case 202:
_new_latitude = parse_degrees();
_new_position_fix = millis();
case 104: // N/S
case 203:
if (_term[0] == 'S')
_new_latitude = -_new_latitude;
case 105: // Longitude
case 204:
_new_longitude = parse_degrees();
case 106: // E/W
case 205:
if (_term[0] == 'W')
_new_longitude = -_new_longitude;
case 107: // Speed (GPRMC)
_new_speed = parse_decimal();
case 108: // Course (GPRMC)
_new_course = parse_decimal();
case 109: // Date (GPRMC)
_new_date = gpsatol(_term);
case 206: // Fix data (GPGGA)
_gps_data_good = _term[0] > '0';
case 209: // Altitude (GPGGA)
return false;
long TinyGPS::gpsatol(const char *str)
long ret = 0;
while (gpsisdigit(*str))
ret = 10 * ret + *str++ - '0';
return ret;
int TinyGPS::gpsstrcmp(const char *str1, const char *str2)
while (*str1 && *str1 == *str2)
++str1, ++str2;
return *str1;
**_new_altitude = parse_decimal();**
Mowcius
