The algorithm to do this, that is, if you don't want a whole trashcan full of busted quadcopters, is not trivial. The accuracy profile of GPS is pretty good over short distances -- meaning that when position data is off at one location, for nearby locations, it should be off by almost the same amount (I would say a foot or two worst case).
So relative distance values, speeds, and direction are good.
So let's say you've equipped these copters with GPS's, Arduinos, and some 433 MHz. radios (better than higher frequencies for range). The copters all have unique node numbers on your radio network, and node n (> 1) listens for info, say speed, direction, and position from node n - 1. When that is acquired, it computes a homing vector (this is fairly complicated math) for a point in the sky somewhere behind node n - 1. But unless node n - 1 is already stabilized behind node n -2, node n-1 may be altering its course, so its data is promptly out of date. The whole situation will degenerate into some sort of amusing meandering mess, as I said, unless a very smart algorithm is developed. Unless you are a darned good mathematician, you won't get there.
An alternative is to get node 2 synced up with node 1, then node 3 has reliable information about node 2, etc. But the little 433 MHz. radios being in the ISM bands, are limited in power, and even for line-of-sight, probably at best can give you 1/2 mi. reliable range. So by the time the early nodes are synced up, some of the later nodes may we wandering about out of radio range.
Finally, if you have several radios transmitting, you have to work out a framework which prevents collisions of radio traffic (interference). In general, this means keep your data packets short, with a long enough retransmit cycle so that collisions are unlikely. Of course with GPS on board each copter you do have a universal highly accurate clock, so you plan a transmission schedule based on that.
