GPS as compass with Arduino
Has someone tried to use 3 GPS and a arduino to make a compass?
There is several brands, for example furuno, that using 3 GPS receivers and by calculation gets a stabile compass. So it should be possible to make same with an Arduino and 3 GPS receivers.
You started a topic in the Uncategorised category of the forum when its description explicitly tells you not to
Your topic has been moved to a relevant category. Please be careful in future when deciding where to start new topics
Check it and let us know.
I think its possible, and how to make it work....well my guess is that they use phase difference. And do a calculation. Just like a inferometer DF. Just wondering if someone tried.
How much do these devices cost ?
Commercial GPS systems come in varying levels of complexity. With Arduino, you typically use consumer-grade modules that provide data at the NMEA level, delivering processed latitude and longitude information for general use. For accurate heading calculations, these modules would require antennas to be positioned several meters apart due to their lower accuracy.
High-precision systems on the market use advanced technologies and often include an IMU. These systems operate directly with raw GPS signals, analyzing phase differences and other data to calculate precise orientation. The fusion of this raw data allows for accurate attitude determination, even with smaller or closer antenna setups.
Why do you assume so?
This Furuno unit uses a custom-designed GPS receiver with four antennas, but according to their product description, heading can be determined with a custom designed receiver and just two antennas.
Neither is possible using hobby GPS receiver modules.
