I am building a GPS Logger and use the following code below, but nothing writes to the SD Card, works in an SD Test, but not when using code below
// GPS Data logged into an SD Card
// Written by Adrianos Botis e-mail:adrianosbotis@gmail.com
//* SD card attached to SPI bus as follows:
//** MOSI - pin 11
//** MISO - pin 12
//** CLK - pin 13
//** CS - pin 4 (for MKRZero SD: SDCARD_SS_PIN)
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#include <SD.h>
#include<SPI.h>
// Choose two Arduino pins to use for softwarge serial
int RXPin = 2;
int TXPin = 3;
const int chipSelect = 4;
int GPSBaud = 9600;
TinyGPSPlus gps;
SoftwareSerial gpsSerial(RXPin, TXPin);
// Start the software serial port at the GPS's default baud
gpsSerial.begin(GPSBaud);
Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done.");
String dataString = "";
String dataString2 = "";
String dataString3 = "";
String dataString4 = "";
// This sketch displays information every time a new sentence is correctly encoded.
while (gpsSerial.available() > 0)
if (gps.encode(gpsSerial.read()))
displayInfo();
if (gps.location.isValid())
dataString = String(gps.altitude.meters(), 3);
dataString2 = String(gps.location.lat(), 6);
dataString3 = String(gps.location.lng(), 6);
File dataFile = SD.open("GpsDat.txt", FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.print("Altitude: ");
dataFile.println(dataString);
dataFile.print("Longtitude: ");
dataFile.println(dataString2);
dataFile.print("Latitude: ");
dataFile.print(dataString3);
dataFile.print("Time: ");
if (gps.time.hour() < 10) dataFile.print(F("0"));
dataFile.print(gps.time.hour());
dataFile.print(":");
if (gps.time.minute() < 10) dataFile.print(F("0"));
dataFile.print(gps.time.minute());
if (gps.time.second() < 10) dataFile.print(F("0"));
dataFile.print(gps.time.second());
dataFile.print(".");
if (gps.time.centisecond() < 10) dataFile.print(F("0"));
dataFile.println(gps.time.centisecond());
dataFile.println();
dataFile.close();
Serial.println("Failed to open file");
Serial.println("Location: Not Available");
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
// If 5000 milliseconds pass and there are no characters coming in
// over the software serial port, show a "No GPS detected" error
if (millis() > 50000 && gps.charsProcessed() < 10)
Serial.println("No GPS detected");
while(true);
void displayInfo()
Serial.print("Latitude: ");
Serial.println(gps.location.lat(), 6);
Serial.print("Longitude: ");
Serial.println(gps.location.lng(), 6);
Serial.print("Altitude: ");
Serial.println(gps.altitude.meters());
Serial.print("Number of Satellites: ");
Serial.println(gps.satellites.value(), 6);
Serial.print("Date: ");
if (gps.date.isValid())
Serial.print(gps.date.month());
Serial.print("/");
Serial.print(gps.date.day());
Serial.print("/");
Serial.println(gps.date.year());
Serial.println("Not Available");
Serial.print("Time: ");
if (gps.time.isValid())
if (gps.time.hour() < 10) Serial.print(F("0"));
Serial.print(gps.time.hour());
Serial.print(":");
if (gps.time.minute() < 10) Serial.print(F("0"));
Serial.print(gps.time.minute());
Serial.print(":");
if (gps.time.second() < 10) Serial.print(F("0"));
Serial.print(gps.time.second());
Serial.print(".");
if (gps.time.centisecond() < 10) Serial.print(F("0"));
Serial.println(gps.time.centisecond());
