GPS + Si5351A + I2C LCD
Hello,
please i need some help, i got this code for a project that i need to build around an nano arduino and ublox 6M with 20x4 I2C screen. But when i verify the code i get this fault
C:\Users\George\Desktop\GPS-Si5351-VFO-QEX-JUL-AUG-2015-master(1)\GPS-Si5351-VFO-QEX-JUL-AUG-2015-master\Si5351_vfo_v5_3c_I2C\Si5351_vfo_v5_3c_I2C.ino: In function 'void setup()':
C:\Users\George\Desktop\GPS-Si5351-VFO-QEX-JUL-AUG-2015-master(1)\GPS-Si5351-VFO-QEX-JUL-AUG-2015-master\Si5351_vfo_v5_3c_I2C\Si5351_vfo_v5_3c_I2C.ino:220:3: error: 'Wire' was not declared in this scope
   Wire.begin(1);                  // join I2C bus (address = 1)
C:\Users\George\Desktop\GPS-Si5351-VFO-QEX-JUL-AUG-2015-master(1)\GPS-Si5351-VFO-QEX-JUL-AUG-2015-master\Si5351_vfo_v5_3c_I2C\Si5351_vfo_v5_3c_I2C.ino:220:3: note: suggested alternative: 'time'
   time
C:\Users\George\Desktop\GPS-Si5351-VFO-QEX-JUL-AUG-2015-master(1)\GPS-Si5351-VFO-QEX-JUL-AUG-2015-master\Si5351_vfo_v5_3c_I2C\Si5351_vfo_v5_3c_I2C.ino:268:7: error: 'class LiquidCrystal_I2C' has no member named 'init'
   lcd.init();      // Initialize the I2C LCD
C:\Users\George\Desktop\GPS-Si5351-VFO-QEX-JUL-AUG-2015-master(1)\GPS-Si5351-VFO-QEX-JUL-AUG-2015-master\Si5351_vfo_v5_3c_I2C\Si5351_vfo_v5_3c_I2C.ino: In function 'uint8_t Si5351_write(uint8_t, uint8_t)':
C:\Users\George\Desktop\GPS-Si5351-VFO-QEX-JUL-AUG-2015-master(1)\GPS-Si5351-VFO-QEX-JUL-AUG-2015-master\Si5351_vfo_v5_3c_I2C\Si5351_vfo_v5_3c_I2C.ino:870:3: error: 'Wire' was not declared in this scope
   Wire.beginTransmission(Si5351A_addr);
C:\Users\George\Desktop\GPS-Si5351-VFO-QEX-JUL-AUG-2015-master(1)\GPS-Si5351-VFO-QEX-JUL-AUG-2015-master\Si5351_vfo_v5_3c_I2C\Si5351_vfo_v5_3c_I2C.ino:870:3: note: suggested alternative: 'time'
   time
exit status 1
Compilation error: 'Wire' was not declared in this scope
please im new to the arduino, and i need this project for my lab. This is a 10Mhz reference for calibration use.
project was found here GitHub - W3PM/GPS-Si5351-VFO-QEX-JUL-AUG-2015: Si5351 Arduino Controlled GPS Corrected VFO (QEX July/August 2015)
dont know what else to leave here or if im asking to the correct place
Thank you
George
here is the code, if this is easier to read,
 Arduino Controlled GPS Corrected Dual Output Si5351A VFO
 A VFO project that uses an Arduino Uno or Nano to control a SI5351A clock
 generator breakout board. The VFO may be used in stand-alone mode or with
 a GPS receiver to software calibrate the output frequency.
 Permission is granted to use, copy, modify, and distribute this software
 and documentation for non-commercial purposes.
 Copyright (C) 2014,  Gene Marcus W3PM GM4YRE
 16 December,2014
 v5          12 July, 2015     Corrected band select algorithm
 v5_1        13 July, 2015     Changed "KHz" to "kHZ" in the LCD frequency display
 v5_2        20 September,     2016 Modified debounce function to be compatible with
                               Arduino IDE 1.6.11
 v5_3        28 January,2017   Modified coding to enhance 9600 operation. The modifcation
                               is courtesy of Jan, PE1CID.
 v5_3a       11 March, 2021    The variable "validGPSflag" can now equal 1 or 2 to proceed
                               with normal operation
 v5-3b       14 December 2021  Newer batches of Si5351's default to spread spectrum if
                               not set to disable. This version includes code to disable
                               the spread spectrum mode.
 v5-3b-i2c   15 December 2021  i2C Display Version
 v5-3b-i2c   31 July 2023     Included capability to subract CLK2 from CLK1 within the
                              'Freq_array' configuration.
 Acknowledgements:
 Special thanks to Jan, PE1CID for his effort to streamline the code and improve
 operation at 9600 baud. Portions of the GPS receive code were influenced by
 Igor Gonzalez Martin's Arduino tutorial. Thanks to N2END for finding compatibility
 bug with Arduino 1.6.11 and testing revision v5_2.
 Nano Digital Pin Allocation
 D0/RX  GPS RX (this pin may differ on the Nano board)
 D1
 D2  GPS 1pps input
 D3  Rotary encoder pin A
 D4  Rotary encoder pin B
 D5  2.5 MHz input from Si5351 CLK0 pin
 D6  Frequency resolution button
 D7
 D8
 D9
 D10
 D11
 D12
 D13
 A0/D14 Decrease frequency button
 A1/D15 Increase frequency button
 A2/D16 Offset enable
 A3/D17 Band Select button
 A4/D18 Si5351 SDA  i2c Display Connection
 A5/D19 Si5351 SCL  i2c Display Connection
_________________________________________________________________
 Band Select frequency format:
 Column 1 = CLK1 VFO start frequency in Hz
 Column 2 = CLK2 LO frequency in Hz
 Column 3 = LCD display arithmetic operation
 0 = no change
 1 = Add CLK1 and CLK2
 2 = Subtract CLK1 from CLK2
 3 = Subtract CLK2 from CLK1  CLK 2 must be HIGHER in frequency
 Example: {5286500,8998500,1}, will result in
 LCD display: 14.285000 MHz
 CLK1 output: 5.286500 MHz
 CLK2 output: 8.998500 MHz
 Enter any number of Band Select frequencies.
 Use (0,0,0) as the last entry.
 Restrict frequency entries to > 1 MHz and < 80 MHz
 ___________Enter Band Select frequencies below_____________________
const unsigned long Freq_array [] [3] = {
  {  7030000,0,0      },            // CLK1=7.030 MHz, CLK2=0 MHz, Display=7,030.000 kHz
  {  1810000,0,0      },
  {  3560000,0,0      },
  {  7040000,0,0      },
  { 10106000,0,0      },
  { 14060000,0,0      },
  { 18096000,0,0      },
  { 21060000,0,0      },
  { 24906000,0,0      },
  { 28060000,0,0      },
  { 50060000,0,0      },
  { 5286500,8998500,1 },      // CLK1:5.2865 MHz, CLK2:8.9985 MHz, Display:14,285.000 kHz
  { 5016500,9001500,2 },      // CLK1:5.0165 MHz, CLK2:9.0015 MHz, Display:3,985.00 kHz
  (0,0,0)
//_________________________Enter offset frequency (Hz) below:__________________________________
int fOffset = -600;        // -600 Hz offset
//_________________________GPS 1pps calibrate? (0 = NO, 1 = YES)_________________________________
int GPSflag = 1;
//___________________________Enter stand-alone calibration factor:______________________________
//    This entry is not required if GPS calibration is selected.
//  - Connect VFO to a frequency counter
//  - Set VFO to 25 MHz
//  - Annotate counter frequency in Hz
//  - Subtract 25 MHz from counter reading
//  - Enter the difference in Hz (i.e. -245)
int CalFactor = 0;
// include the library code:
#include <LiquidCrystal_I2C.h>    // <Wire.h> Included Already
#include <string.h>
#include <ctype.h>
#include <avr/interrupt.h>
#include <avr/io.h>
// Set up MCU pins
#define ppsPin                   2
#define encoderPinA              3
#define encoderPinB              4
#define Resolution               6
#define RS                       7
#define E                        8
#define DB4                      9
#define DB5                     10
#define DB6                     11
#define DB7                     12
#define FreqDown                A0
#define FreqUp                  A1
#define Offset                  A2
#define BandSelect              A3
// Set sI5351A I2C address
#define Si5351A_addr          0x60
// Define Si5351A register addresses
#define CLK_ENABLE_CONTROL       3
#define CLK0_CONTROL            16
#define CLK1_CONTROL            17
#define CLK2_CONTROL            18
#define SYNTH_PLL_A             26
#define SYNTH_PLL_B             34
#define SYNTH_MS_0              42
#define SYNTH_MS_1              50
#define SYNTH_MS_2              58
#define SSC_EN                 149
#define PLL_RESET              177
#define XTAL_LOAD_CAP          183
// initialize the library with the numbers of the interface pins
LiquidCrystal_I2C lcd(0x27, 20, 4); // I2C address 0x27, 20 column and 4 rows
// configure variables
byte fStepcount,offsetFlag=0,band;
String resolution = "1 Hz  ";
char GPSlocator[7],StartCommand[7] = "$GPGGA",StartCommand2[7] = "$GPRMC",buffer[300] = "",EW,NS;
int IndiceCount=0,StartCount=0,counter=0,indices[13];
int Lat10,Lat1,Lon100,Lon10,Lon1,validGPSflag;
int dLon1,dLon2,dLat1,dLat2,dlon;
int byteGPS=-1,second=0,minute=0,hour=0;
unsigned int tcount=2,encoderA,encoderB,encoderC=1;
unsigned long time,fStep=1,XtalFreq=25000000;
unsigned long mult=0,Freq_1,Freq_2,debounce,DebounceDelay=500000;
static bool s_GpsOneSecTick = false;
// Clock - interrupt routine used as master timekeeper
// Called every second by GPS 1PPS on MCU pin 2
void PPSinterrupt()
  s_GpsOneSecTick = true;                        // New second by GPS.
  tcount++;
  if (tcount == 4)                               // Start counting the 2.5 MHz signal from Si5351A CLK0
    TCCR1B = 7;                                  //Clock on rising edge of pin 5
  else if (tcount == 44)                              //The 40 second gate time elapsed - stop counting
    TCCR1B = 0;                                  //Turn off counter
    XtalFreq = mult * 0x10000 + TCNT1;           //Calculate correction factor
    TCNT1 = 0;                                   //Reset count to zero
    mult = 0;
    tcount = 0;                                  //Reset the seconds counter
// Timer 1 overflow intrrupt vector.
ISR(TIMER1_OVF_vect)
  mult++;                                          //Increment multiplier
  TIFR1 = (1<<TOV1);                               //Clear overlow flag
  si5351aStart();
  //Set up Timer1 as a frequency counter - input at pin 5
  TCCR1B = 0;                                    //Disable Timer5 during setup
  TCCR1A = 0;                                    //Reset
  TCNT1  = 0;                                    //Reset counter to zero
  TIFR1  = 1;                                    //Reset overflow
  TIMSK1 = 1;                                    //Turn on overflow flag
  // Inititalize GPS 1pps input
  pinMode(ppsPin, INPUT);
  // Set 1PPS pin 2 for external interrupt input
  attachInterrupt(digitalPinToInterrupt(ppsPin), PPSinterrupt, RISING);
  // Add CalFactor to the Si5351 crystal frequency for non-GPS frequency updates
  if(GPSflag == 0)
    XtalFreq += CalFactor;
    detachInterrupt(digitalPinToInterrupt(ppsPin)); // Disable the 1pps interrupt
  // Make XtalFreq compatable with GPS correction variable
  XtalFreq *= 4;
  // Set up rotary encoder
  pinMode(encoderPinA, INPUT);
  digitalWrite(encoderPinA, HIGH);         // internal pull-up enabled
  pinMode(encoderPinB, INPUT);
  digitalWrite(encoderPinB, HIGH);         // internal pull-up enabled
  // Set up push buttons
  pinMode(Resolution, INPUT);
  digitalWrite(Resolution, HIGH);         // internal pull-up enabled
  pinMode(BandSelect, INPUT);
  digitalWrite(BandSelect, HIGH);         // internal pull-up enabled
  pinMode(FreqDown, INPUT);
  digitalWrite(FreqDown, HIGH);           // internal pull-up enabled
  pinMode(Offset, INPUT);
  digitalWrite(Offset, HIGH);             // internal pull-up enabled
  pinMode(FreqUp, INPUT);
  digitalWrite(FreqUp, HIGH);             // internal pull-up enabled
  Serial.begin(9600);                     // connect to the port @ 9600 baud
  lcd.backlight(); // Initialize I2C Backlight
  lcd.clear();     // Clear LCD Screen
  lcd.setCursor(0,1);
  if (GPSflag == 1)
    lcd.print("Waiting for GPS");         // This will continue to display until valid
  }                                       // GPS NMEA data is detected
    lcd.print("Step:");                   // Frequency step resolution will display only
    lcd.setCursor(6,1);                   // after valid GPS data is detected or if
    lcd.print(resolution);                // stand-aloneoperation is selected.
  Freq_1 = Freq_array [0] [0];            // At start up load the first band in the the
  Freq_2 = Freq_array [0] [1];            // Freq_array variable.
  // Set CLK0 to 2.5 MHz
  si5351aSetFreq(SYNTH_MS_0,2500000);
  if(Freq_2 == 0)
    Si5351_write(CLK_ENABLE_CONTROL,0b00000100); // Turn OFF CLK2
    Si5351_write(CLK_ENABLE_CONTROL,0b00000000); // Turn ON CLK2
    Freq_2 = Freq_array [band] [1];              // Load CLK2
    si5351aSetFreq(SYNTH_MS_2, Freq_2);          // Set CLK2 frequency
  setfreq();                                     // Now display and set CLK1 frequency
// Loop starts here:
// Loops consecutively to check MCU pins for activity
  if (s_GpsOneSecTick)
    if (validGPSflag == 1 | validGPSflag == 2)
      updateAndDisplayUtcTime();
      if ((millis() > time) && (millis() <= time + 1000)) // Test to see if it is time to
      {                                                   // print grid square to the LCD
        lcd.setCursor(0,1);
        lcd.print(GPSlocator);
        lcd.print(" ");
    if (tcount == 1)
      // Update the SI5351A after every GPS correction
      si5351aSetFreq(SYNTH_MS_1, Freq_1);
      if (Freq_2 > 0)
  if (GPSflag == 1 && validGPSflag == 0)
    GPSprocess( ); //If GPS is selected, wait for valid NMEA data
    // Rotary encoder algorithm begins here
    byte encoderA = digitalRead(encoderPinA);
    byte encoderB = digitalRead(encoderPinB);
    if ((encoderA == HIGH) && (encoderC == LOW))
      if (encoderB == LOW)
        // Decrease frequency
        Freq_1 -= fStep;
        // Increase frequency
        Freq_1 += fStep;
      setfreq();         //Update and display new frequency
      resDisplay();      //Update resolution display and set display timer
    encoderC = encoderA;
    // The frequency step resolution selection begins here:
    if(digitalRead(Resolution) == LOW)
      // This function is used in lieu of "delay" to prevent timer/interrupt conflicts
      for(debounce=0; debounce < DebounceDelay; debounce++){__asm__ __volatile__ ("nop");};
      fStepcount++;
      if(fStepcount>6)fStepcount=0;
      setResolution();     // Call the set resolution subroutine
    // Band selection begins here:
    if(digitalRead(BandSelect) == LOW)
      band=band+1;                        // Increment band selection
      if(Freq_array [band] [0]==0)band=0; // Check for end of frequency array
      if(Freq_array [band] [1] == 0)      // Is CLK2 = 0?
        Freq_2 = Freq_array [band] [1];              // Load CLK2 frequency
      Freq_1 = Freq_array [band] [0];                // Load CLK1 frequency
      setfreq();                                     // Display and set CLK1 frequency
    // Frequency offset algorithm begins here:
    if(digitalRead(Offset) == LOW && offsetFlag == 0) // Check for offset pin A2 LOW
      offsetFlag = 1;                                 // Set flag
      Freq_1 += fOffset;                              // Add offset frequency
      lcd.setCursor(15,0);                            // Display a "*" on the LCD
      lcd.print("*");
      setfreq();                                      // Display and set CLK1 frequency + offset
    if(digitalRead(Offset) == HIGH && offsetFlag == 1) // Check for offset pn A2 HIGH
      offsetFlag = 0;                                  // Reset flag
      Freq_1 -= fOffset;                               // Subtract the offset frequency
      lcd.setCursor(15,0);                             // Clear the "*" on the LCD
      lcd.print(" ");
      setfreq();                                       // Display and set CLK1 frequency - offset
    // Frequency Up/Down pushbutton algorithm begin here:
    if(digitalRead(FreqUp) == LOW)  // Check for frequency up pushbutton A1 LOW
      // Increase frequency by the selected frequency step
      Freq_1 += fStep;                                // Increase CLK1 by frequency step
      setfreq();                                      // Set and display new frequency
      resDisplay();                                   // Call the resolution display subroutine
    if(digitalRead(FreqDown) == LOW) // Check for frequency up pushbutton A1 LOW
      // Decrease frequency by the selected frequency step and check for 1-80 MHz limits
      Freq_1 -= fStep;                               // Decrease CLK1 by frequency step
// Add one second to the UTC time and update on the display
void updateAndDisplayUtcTime(void)
  second++;
  if (second == 60)                            //Set time using GPS NMEA data
    minute++ ;
    second = 0 ;
  if (minute == 60)
    hour++;
    minute = 0 ;
  if (hour == 24)
    hour = 0 ;
  //Output the UTC time to the LCD
  lcd.setCursor(8,1);
  if (hour < 10)
    lcd.print ("0");
  lcd.print (hour);
  lcd.print (":");
  if (minute < 10)
    lcd.print ("0");
  lcd.print (minute);
  lcd.print (":");
  if (second < 10)
    lcd.print ("0");
  lcd.print (second);
  lcd.print (" ");
// Display and set the Si5351A frequency
void setfreq()
  unsigned long  Freq_temp = Freq_1; // Temporarily store Freq_1
  switch(Freq_array [band] [2])      // Get math function from frequency array
  case 1:  // If math function is 1 then add Freq_1 and Freq_2 for display
    Freq_temp = Freq_1 + Freq_2;
  case 2:  // If math function is 2 then subtract Freq_1 from Freq_2 for display
    Freq_temp = Freq_2 - Freq_1;
  case 3: // If math function is 2 then subtract Freq_2 from Freq_1, for the correct display Freq_1 must be HIGHER than Freq_2!
    Freq_temp = Freq_1 - Freq_2;
  char buf[10];
  // Print frequency to the LCD
  lcd.setCursor(0,0);
  ltoa(Freq_temp,buf,10);
  if (Freq_temp < 1000000)
    lcd.print(buf[0]);
    lcd.print(buf[1]);
    lcd.print(buf[2]);
    lcd.print('.');
    lcd.print(buf[3]);
    lcd.print(buf[4]);
    lcd.print(buf[5]);
    lcd.print(" kHz     ");
  if (Freq_temp >= 1000000 && Freq_temp < 10000000)
    lcd.print(buf[0]);
    lcd.print(',');
    lcd.print(buf[1]);
    lcd.print(buf[2]);
    lcd.print(buf[3]);
    lcd.print('.');
    lcd.print(buf[4]);
    lcd.print(buf[5]);
    lcd.print(buf[6]);
    lcd.print(" kHz   ");
  if (Freq_temp >= 10000000 && Freq_temp < 100000000)
    lcd.print(buf[0]);
    lcd.print(buf[1]);
    lcd.print(',');
    lcd.print(buf[2]);
    lcd.print(buf[3]);
    lcd.print(buf[4]);
    lcd.print('.');
    lcd.print(buf[5]);
    lcd.print(buf[6]);
    lcd.print(buf[7]);
    lcd.print(" kHz  ");
  if (Freq_temp >= 100000000)
    lcd.print(buf[0]);
    lcd.print(buf[1]);
    lcd.print(buf[2]);
    lcd.print(',');
    lcd.print(buf[3]);
    lcd.print(buf[4]);
    lcd.print(buf[5]);
    lcd.print('.');
    lcd.print(buf[6]);
    lcd.print(buf[7]);
    lcd.print(buf[8]);
    lcd.print(" kHz ");
  si5351aSetFreq(SYNTH_MS_1, Freq_1); // Set CLK1 frequency
// Set the frequency step resolution
void setResolution()
  switch(fStepcount)
  case 0:
    fStep=1;
  case 1:
    fStep=10;
    resolution = "10 Hz  ";
  case 2:
    fStep=100;
    resolution = "100 Hz ";
  case 3:
    fStep=1000;
    resolution = "1 kHz  ";
  case 4:
    fStep=10000;
    resolution = "10 kHz ";
  case 5:
    fStep=100000;
    resolution = "100 kHz";
  case 6:
    fStep=1000000;
    resolution = "1 MHz  ";
  resDisplay();
// Display the frequency step resolution and
// set a 10 second display timer
void resDisplay()
  if (GPSflag == 0) lcd.setCursor(6,1);
  else lcd.setCursor(0,1);
  time = millis()+10000;
// Calculate the 6 digit Maidenhead Grid Square location
void calcGridSquare()
  unsigned long latitude, longitude;
  float temp3,tempLat,tempLong;
  longitude = Lon100*100000000L+Lon10*10000000L+Lon1*1000000L+dLon1*100000L+dLon2*10000L;
  latitude = Lat10*10000000L+Lat1*1000000L+dLat1*100000L+dLat2*10000L;
  tempLong=longitude;
  tempLong=1000000*int(tempLong/1000000)+ ((tempLong-1000000*int(tempLong/1000000))/0.6);
  if (EW == 'E')tempLong=(tempLong)+180000000;
  if (EW == 'W')tempLong=180000000-(tempLong);
  tempLat=latitude;
  tempLat=1000000*int(tempLat/1000000)+((tempLat-1000000*int(tempLat/1000000))/0.6);
  if (NS=='N')tempLat=tempLat+90000000;
  if (NS=='S')tempLat=90000000-tempLat;
  GPSlocator[0]=(65+int(tempLong/20000000));
  GPSlocator[1]=(65+int(tempLat/10000000));
  temp3=tempLong-(20000000*int(tempLong/20000000));
  GPSlocator[2]=(48+int(temp3*10/20/1000000));
  temp3=tempLat-(10000000*int(tempLat/10000000));
  GPSlocator[3]=(48+int(temp3/1000000));
  temp3=(tempLong/2000000)-(int(tempLong/2000000));
  GPSlocator[4]=(97+int(temp3*24));
  temp3=(tempLat/1000000)-(int(tempLat/1000000));
  GPSlocator[5]=(97+int(temp3*24));
//  GPS NMEA processing starts here
void GPSprocess()
  byte temp, pinState = 0, i;
  if (Serial.available() > 0)
    // NMEA $GPGGA data begins here
    byteGPS = Serial.read();     // Read a byte of the serial port
    buffer[counter] = byteGPS;   // If there is serial port data, it is put in the buffer
    Serial.write(byteGPS);
    counter++;
    if (byteGPS == 13){            // If the received byte is = to 13, end of transmission
      IndiceCount = 0;
      StartCount = 0;
      for (int i=1;i<7;i++){     // Verifies if the received command starts with $GPGGA
        if (buffer[i]==StartCommand[i-1]){
          StartCount++;
      if(StartCount==6){         // If yes, continue and process the data
        for (int i=0;i<300;i++){
          if (buffer[i]==','){   // check for the position of the  "," separator
            indices[IndiceCount]=i;
            IndiceCount++;
          if (buffer[i]=='*'){    // ... and the "*"
            indices[12]=i;
            IndiceCount++;
        // Load the NMEA time data
        temp = indices[0];
        hour = (buffer[temp+1]-48)*10 + buffer[temp+2]-48;
        minute = (buffer[temp+3]-48)*10 + buffer[temp+4]-48;
        second = (buffer[temp+5]-48)*10 + buffer[temp+6]-48;
        // Load latitude and logitude data
        temp = indices[1];
        Lat10 = buffer[temp+1]-48;
        Lat1 = buffer[temp+2]-48;
        dLat1 = buffer[temp+3]-48;
        dLat2 = buffer[temp+4]-48;
        temp = indices[2];
        NS = buffer[temp+1];
        temp = indices[3];
        Lon100 = buffer[temp+1]-48;
        Lon10 = buffer[temp+2]-48;
        Lon1 = buffer[temp+3]-48;
        dLon1 = buffer[temp+4]-48;
        dLon2 = buffer[temp+5]-48;
        temp = indices[4];
        EW = buffer[temp+1];
        temp = indices[5];
        validGPSflag = buffer[temp+1]-48;
      { // NMEA $GPRMC data begins here
        // Note: &GPRMC does not include satellite in view data
        IndiceCount=0;
        StartCount=0;
        for (int i=1;i<7;i++){     // Verifies if the received command starts with $GPRMC
          if (buffer[i]==StartCommand2[i-1]){
            StartCount++;
              IndiceCount++;
              indices[12]=i;
              IndiceCount++;
          // Load time data
          temp = indices[0];
          temp = indices[1];
          if (buffer[temp+1] == 65){
            validGPSflag = 1;
            validGPSflag = 0;
          temp = indices[2];
          temp = indices[3];
          temp = indices[4];
          temp = indices[5];
      if(validGPSflag == 1)
        calcGridSquare();
        lcd.setCursor(0,1);
        lcd.print("  ");
      counter=0;                  // Reset the buffer
      for (int i=0;i<300;i++){    //
        buffer[i]=' ';
//  Si5351 Multisynch processing
void si5351aSetFreq(int synth, unsigned long  freq)
  unsigned long long CalcTemp;
  unsigned long  a, b, c, p1, p2, p3;
  c = 0xFFFFF;  // Denominator derived from max bits 2^20
  a = ((XtalFreq * 36) /4) / freq; // 36 is derived from 900/25 MHz
  CalcTemp = round((XtalFreq * 36) /4) % freq;
  CalcTemp *= c;
  CalcTemp /= freq ;
  b = CalcTemp;  // Calculated numerator
  // Refer to Si5351 Register Map AN619 for following formula
  p3  = c;
  p2  = (128 * b) % c;
  p1  = 128 * a;
  p1 += (128 * b / c);
  p1 -= 512;
  // Write data to multisynth registers
  Si5351_write(synth, 0xFF);
  Si5351_write(synth + 1, 0xFF);
  Si5351_write(synth + 2, (p1 & 0x00030000) >> 16);
  Si5351_write(synth + 3, (p1 & 0x0000FF00) >> 8);
  Si5351_write(synth + 4, (p1 & 0x000000FF));
  Si5351_write(synth + 5, 0xF0 | ((p2 & 0x000F0000) >> 16));
  Si5351_write(synth + 6, (p2 & 0x0000FF00) >> 8);
  Si5351_write(synth + 7, (p2 & 0x000000FF));
//  Si5351 initialization routines
void si5351aStart()
  // Initialize Si5351A
  Si5351_write(XTAL_LOAD_CAP,0b11000000);      // Set crystal load to 10pF
  Si5351_write(CLK_ENABLE_CONTROL,0b00000000); // Enable all outputs
  Si5351_write(CLK0_CONTROL,0b00001111);       // Set PLLA to CLK0, 8 mA output
  Si5351_write(CLK1_CONTROL,0b00001111);       // Set PLLA to CLK1, 8 mA output
  Si5351_write(CLK2_CONTROL,0b00101111);       // Set PLLB to CLK2, 8 mA output
  Si5351_write(PLL_RESET,0b10100000);          // Reset PLLA and PLLB
  Si5351_write(SSC_EN,0b00000000);             // Disable spread spectrum
  // Set PLLA and PLLB to 900 MHz
  a = 36;           // Derived from 900/25 MHz
  b = 0;            // Numerator
  p3  = c;
  p2  = (128 * b) % c;
  p1  = 128 * a;
  p1 -= 512;
  // Write data to PLL registers
  Si5351_write(SYNTH_PLL_A, 0xFF);
  Si5351_write(SYNTH_PLL_A + 1, 0xFF);
  Si5351_write(SYNTH_PLL_A + 2, (p1 & 0x00030000) >> 16);
  Si5351_write(SYNTH_PLL_A + 3, (p1 & 0x0000FF00) >> 8);
  Si5351_write(SYNTH_PLL_A + 4, (p1 & 0x000000FF));
  Si5351_write(SYNTH_PLL_A + 5, 0xF0 | ((p2 & 0x000F0000) >> 16));
  Si5351_write(SYNTH_PLL_A + 6, (p2 & 0x0000FF00) >> 8);
  Si5351_write(SYNTH_PLL_A + 7, (p2 & 0x000000FF));
  Si5351_write(SYNTH_PLL_B, 0xFF);
  Si5351_write(SYNTH_PLL_B + 1, 0xFF);
  Si5351_write(SYNTH_PLL_B + 2, (p1 & 0x00030000) >> 16);
  Si5351_write(SYNTH_PLL_B + 3, (p1 & 0x0000FF00) >> 8);
  Si5351_write(SYNTH_PLL_B + 4, (p1 & 0x000000FF));
  Si5351_write(SYNTH_PLL_B + 5, 0xF0 | ((p2 & 0x000F0000) >> 16));
  Si5351_write(SYNTH_PLL_B + 6, (p2 & 0x0000FF00) >> 8);
  Si5351_write(SYNTH_PLL_B + 7, (p2 & 0x000000FF));
//Write I2C data routine
uint8_t Si5351_write(uint8_t addr, uint8_t data)
  Wire.write(addr);
  Wire.write(data);
  Wire.endTransmission();
Your sketch compiled with no errors for me with either Nano or Uno selected. Several warnings (I have the warning level turned all the way up), but no errors.
highlight the 220 line and the 268
you didnt get this error?? how is that possible?
im using the same code, NANO as the board, IDE 2.3.2
No errors. Lots of warnings like I said, but only because I've got the warning level dialed all the way up. Compiled just fine for an Arduino Nano using arduino-cli.
arduino-cli compile -b arduino:avr:nano:cpu=atmega328 --warnings all --output-dir /home/me/tmp --no-color (in directory: /home/me/Documents/sketchbook/Nano/test)
/home/me/Documents/sketchbook/Nano/test/test.ino:106:6: warning: left operand of comma operator has no effect [-Wunused-value]
   (0,0,0)
/home/me/Documents/sketchbook/Nano/test/test.ino:106:8: warning: right operand of comma operator has no effect [-Wunused-value]
   (0,0,0)
/home/me/Documents/sketchbook/Nano/test/test.ino: In function 'void loop()':
/home/me/Documents/sketchbook/Nano/test/test.ino:318:22: warning: suggest parentheses around comparison in operand of '|' [-Wparentheses]
/home/me/Documents/sketchbook/Nano/test/test.ino: In function 'void GPSprocess()':
/home/me/Documents/sketchbook/Nano/test/test.ino:655:14: warning: unused variable 'pinState' [-Wunused-variable]
/home/me/Documents/sketchbook/Nano/test/test.ino:655:28: warning: unused variable 'i' [-Wunused-variable]
In file included from /tmp/arduino/sketches/D18B0C1C32B6ECF80C951EB8060A844A/sketch/test.ino.cpp:1:0:
/home/me/Documents/sketchbook/Nano/test/test.ino: In function 'void si5351aSetFreq(int, long unsigned int)':
/home/me/.arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/Arduino.h:96:26: warning: comparison of unsigned expression >= 0 is always true [-Wtype-limits]
 #define round(x)     ((x)>=0?(long)((x)+0.5):(long)((x)-0.5))
/home/me/Documents/sketchbook/Nano/test/test.ino:788:14: note: in expansion of macro 'round'
/home/me/Documents/sketchbook/Nano/test/test.ino:783:35: warning: variable 'p3' set but not used [-Wunused-but-set-variable]
/home/me/Documents/sketchbook/Nano/test/test.ino: In function 'void si5351aStart()':
/home/me/Documents/sketchbook/Nano/test/test.ino:831:35: warning: variable 'p3' set but not used [-Wunused-but-set-variable]
/home/me/Documents/sketchbook/Nano/test/test.ino: In function 'uint8_t Si5351_write(uint8_t, uint8_t)':
/home/me/Documents/sketchbook/Nano/test/test.ino:874:1: warning: no return statement in function returning non-void [-Wreturn-type]
Sketch uses 13886 bytes (45%) of program storage space. Maximum is 30720 bytes.
Global variables use 1136 bytes (55%) of dynamic memory, leaving 912 bytes for local variables. Maximum is 2048 bytes.
Used library      Version Path
LiquidCrystal_I2C 1.1.4   /home/me/Documents/sketchbook/libraries/LiquidCrystal_I2C
Wire              1.0     /home/me/.arduino15/packages/arduino/hardware/avr/1.8.3/libraries/Wire
Used platform Version Path
arduino:avr   1.8.3   /home/me/.arduino15/packages/arduino/hardware/avr/1.8.3
Compilation finished successfully.
