yes. That would both prove that the GPS communications are working, and let us make sure the data looks correct.
Yes. Just echo whatever the GPS sends to Serial - it's a common first test which you should be able to copy from other folks efforts.
Have you tried one of the example sketches that comes with the gps library?
Forget about displays etc, these examples send data to the IDE monitor.
Just run the raw example.
If you look at an example there are some timing tricks that need to be done to get consistent readings from the GPS.
Tom..
A GPS system is not simple. It's unfortunate that Mikail Hart's examples present it as simple. His library is great, but his examples lead new people to think their efforts will produce success immediately. There are many elements to get right.
That said, I think a GPS project is a terrific opportunity for new players to learn a great deal about many aspects of Arduino, programming, serial comms and methodical project design and troubleshooting.
You'll get there and you'll learn so much. Then you can guide other new players.
I tried to upload sketch from the library files. I attach the result down. I let it run almost an hour and I still have the same result. I understand it well that I don't have a GPS signal?
23:21:05.114 -> FullExample.ino
23:21:05.161 -> An extensive example of many interesting TinyGPSPlus features
23:21:05.214 -> Testing TinyGPSPlus library v. 1.0.2
23:21:05.214 -> by Mikal Hart
23:21:05.214 ->
23:21:05.214 -> Sats HDOP Latitude Longitude Fix Date Time Date Alt Course Speed Card Distance Course Card Chars Sentences Checksum
23:21:05.314 -> (deg) (deg) Age Age (m) --- from GPS ---- ---- to London ---- RX RX Fail
23:21:05.415 -> ----------------------------------------------------------------------------------------------------------------------------------------
23:21:05.462 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 63 0 0
23:21:06.665 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 312 0 0
23:21:07.923 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 565 0 0
23:21:09.328 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 1034 0 0
23:21:10.679 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 1362 0 0
23:21:11.936 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 1645 0 0
23:21:13.388 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 2177 0 1
23:21:14.746 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 2483 0 1
23:21:16.050 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 2845 0 2
23:21:17.556 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 3314 0 2
23:21:18.807 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 3592 0 3
23:21:20.165 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 4000 0 3
23:21:21.616 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 4436 0 7
23:21:22.850 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 4718 0 7
23:21:24.255 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 5182 0 7
23:21:25.660 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 5564 0 7
23:21:26.917 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 5842 0 7
23:21:28.369 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 6361 0 9
23:21:29.727 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 6682 0 9
23:21:31.031 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 7007 0 9
23:21:32.483 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 7479 0 10
23:21:33.740 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 7735 0 10
23:21:34.991 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 8043 0 10
23:21:36.496 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 8508 0 10
23:21:37.753 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 8776 0 10
23:21:39.004 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 9101 0 10
23:21:40.509 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 9568 0 13
23:21:41.766 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 9828 0 13
23:21:43.017 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 10138 0 13
23:21:44.475 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 10626 0 15
23:21:45.779 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 10910 0 16
Looks like you have no signal. Are you testing indoors?
So what do your raw NMEA sentences look like?
Yes, I did the test outside with a direct view of the sky. I will try again today and for more than one hour.
I only tried the sketch that was at the library. I'll download the NMEA sketch and do a test.
This is all you need, courtesy of jremington:
while (mySerial.available()) {
Serial.write(mySerial.read());
Well thank you. And should I put this in a new sketch or should I add it to the test one I did now?
Three hours in the free sky and still without a signal
It should be a new sketch--just that simple statement that will read a byte from the software serial buffer and send it to the monitor. Earlier you said you thought this project would be simple. Well, this part is simple. The aim here is not to get satellite data, but just to see that the GPS is working. As soon as you give it power, it emits NMEA sentences on the TX pin. The aim here is to read those sentences.
You need to use the name of your software serial (was it "ss"?) rather than "mySerial".
My sketch for test:
#include <TinyGPSPlus.h>
#include <SoftwareSerial.h>
static const int RXPin = 6, TXPin = 7;
static const uint32_t GPSBaud = 4800;
// The TinyGPSPlus object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
ss.begin(GPSBaud);
while (ss.available()) {
Serial.write(ss.read());
Result:
11:25:52.247 -> ,⸮⸮⸮hd⸮j$⸮d*h⸮)&E⸮⸮⸮⸮⸮͊⸮⸮ª⸮⸮⸮⸮⸮⸮⸮+i).-⸮⸮⸮⸮ ⸮⸮⋪⸮͊⸮⸮⸮⸮⸮ˉ⸮⸮⸮⸮⸮+i!&/⸮⸮A⸮⸮⸮a⸮⸮⸮i ⸮Z⸮
%⸮ʊ⸮⸮⸮˺⸮⸮⸮a⸮⸮⸮ɪ⸮ ⸮⸮⸮⫉⸮⸮A⸮⸮⸮⸮⸮⸮a!. ⸮⸮ˊ⸮⸮©ʂ⸮⸮⸮ɉꪉ⸮⸮⸮
11:25:53.049 -> a!..⸮⸮⸮ꊉʪ⸮£⸮⸮ɂ⸮ˊʢ⸮˪⸮⸮⸮+i!.&⸮⸮⸮⸮©ʂʢ⸮ʂ⸮⸮ɪ⸮êʢ⸮ª⸮⸮⸮
11:25:53.196 -> ⸮i!&&⸮⸮⸮⸮ʂ¢⸮ʚ⸮Éʂ⸮ªˢ⸮C⸮
M⸮˪⸮⸮⸮i⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮\⸮).-⸮⸮⸮⸮ ⸮⸮⋪⸮͊⸮⸮ª⸮⸮⸮⸮ʁ⸮⸮⸮⸮⸮i!&/⸮/A⸮⸮⸮a⸮⸮⸮i ⸮B⸮
-⸮ʊ⸮⸮⸮ˢ⸮⸮⸮a⸮⸮⸮⸮⸮⸮ ⸮⸮⸮ꣁ⸮⸮Y⸮⸮⸮⸮⸮i)&⸮⸮ˊ⸮⸮ʩ⸮⸮⸮⸮⸮ꢁ⸮ʂ⸮⸮*a!..⸮⸮⸮ʊ⸮ʊʪ⸮«⸮⸮Ɋ⸮Êʪ⸮˪⸮⸮⸮i).&⸮⸮⸮⸮ʡ⸮ʪ⸮ʊ⸮⸮⸮⸮⸮ˢª⸮ʢ⸮⸮⸮⸮a)..⸮⸮⸮ʊ⸮ʪ⸮ʊ⸮Éʊ⸮ʪâ⸮K⸮M⸮â⸮⸮⸮a⸮⸮⸮⸮⸮⸮⸮⸮⸮㊙ ⸮M⸮!&-⸮⸮⸮⸮ ⸮⸮ꋚ⸮͊⸮⸮ʫ⸮⸮⸮ʁ⸮⸮⸮⸮⸮a!./⸮⸮I⸮⸮⸮i⸮⸮⸮i ⸮J⸮
-⸮ʊ⸮⸮⸮ˢ⸮⸮⸮a⸮⸮⸮⸮⸮⸮ ⸮⸮⸮⢉⸮⸮A⸮⸮⸮⸮⸮a!.⸮⸮˂⸮⸮ʡ⸮⸮⸮ɉ⸮⸮⸮j⸮⸮⸮i!..⸮⸮⸮ʂ⸮ʊʚ⸮ʫ⸮⸮ɂ⸮Ê¢⸮ˢ⸮⸮⸮a)..⸮⸮⸮⸮ʩʊ⸮ʂ⸮⸮ɢ⸮˪⸮ʉʢ⸮⸮⸮⸮i)&&⸮⸮⸮⸮ª⸮⸮ˉ⸮ʪ⸮M⸮E⸮˪⸮⸮⸮i⸮⸮⸮Ɋ⸮⸮⸮⸮⸮ ⸮C⸮).-⸮⸮⸮⸮⸮⸮⃢⸮͂⸮⸮⸮⸮⸮⸮⸮É⸮⸮⸮⸮⸮a).'⸮⸮I⸮⸮⸮i⸮⸮⸮a⸮[⸮%⸮⸮⸮⸮ê⸮⸮⸮i⸮⸮⸮Ɋ⸮⸮⸮⸮ꪁ⸮⸮I⸮⸮⸮⸮⸮i)& ⸮⸮ˊ⸮⸮©ʂ⸮⸮Ɂ⸮⸮ꢁ⸮⸮"a).&⸮⸮⸮⸮ʊ⸮£⸮⸮⸮⸮⸮˂⸮˪⸮⸮⸮i)..⸮⸮⸮⸮⸮Iʂ⸮ʊ⸮⸮ɪ⸮˪⸮ʉʢ⸮⸮⸮⸮i)&&⸮⸮⸮ʊ⸮ʂʪ⸮⸮Áʊ⸮ʪ⸮K⸮E⸮ˢ⸮⸮⸮a⸮⸮⸮⸮⸮⸮ ⸮⸮⸮⸮ ⸮B⸮!.-⸮⸮⸮⸮ ⸮⸮⃫⸮͊⸮⸮ʋ⸮⸮⸮ˉ⸮⸮⸮⸮⸮a)./⸮⸮I⸮⸮⸮a⸮⸮⸮i ⸮L⸮-⸮ʊÁ⸮˪⸮⸮⸮i⸮⸮⸮ɪ⸮ ⸮⸮⸮ꪉ⸮⸮I⸮⸮⸮⸮⸮a)& ⸮⸮ˊ⸮⸮¡ʊ⸮⸮⸮⸮⸮⸮⪩⸮⸮"i)..⸮⸮⸮ʊ⸮ʚ⸮«⸮⸮Ɋ⸮Êʂ⸮˪⸮⸮⸮+a!..⸮⸮⸮⸮¡ʚ⸮ʂ⸮⸮ɢ⸮ˢ⸮ʉ¢⸮⸮⸮⸮+i)&.⸮Y⸮ʊ⸮ʢ⸮ʊ⸮Éʂ⸮ʪ⸮[⸮M⸮â⸮⸮⸮i⸮⸮⸮ɪ⸮⸮⸮⸮⸮ ⸮K⸮).-⸮⸮⸮⸮ ⸮⸮ꋋ⸮Ŋ⸮⸮⸮⸮⸮⸮⸮⸮ʉ⸮⸮⸮⸮⸮#a).'⸮ʉ⸮⸮I⸮⸮⸮a⸮⸮⸮i ⸮B⸮
%⸮ʊˉ⸮ê⸮⸮⸮a⸮⸮⸮٢⸮ ⸮⸮⸮ꪁ⸮⸮I⸮⸮⸮⸮⸮a!. ⸮⸮Ú⸮⸮©ʊ⸮⸮ɩ⸮⸮⪩⸮⸮i).&⸮⸮⸮⸮ʊ⸮ʫ⸮⸮⸮⸮⸮Âʪ⸮â⸮⸮⸮⸮a)..⸮⸮⸮⸮ʩʊ*⸮⸮ʊ⸮⸮ɪ⸮êʂ⸮ʢ⸮⸮⸮⸮a).&⸮⸮⸮⸮ʂʪ⸮⸮ˁʊ⸮ª⸮ʀC⸮E⸮ˢ⸮⸮⸮i⸮⸮⸮ɢ⸮ ⸮⸮⸮⸮ ⸮K⸮!&-⸮⸮⸮⸮ ⸮⸮ꋣ⸮͊⸮⸮ʻ⸮⸮⸮ˣ⸮⸮⸮⸮ ⸮L⸮aͫ⸮⸮⸮I⸮⸮⸮i⸮⸮⸮i ⸮J⸮%⸮ʢ⸮⸮⸮â⸮{⸮i⸮⸮⸮⸮⸮⸮⸮⸮⸮⢉⸮⸮A⸮⸮⸮⸮⸮#a!.⸮⸮˂⸮⸮ʡ⸮⸮⸮⸮⸮⸮ꪡ⸮⸮
11:25:59.097 -> i!..⸮⸮⸮ʂ⸮ʊʊ⸮ʣ⸮⸮ɂ⸮ˊ⸮ˢ⸮⸮⸮a).&⸮⸮⸮⸮ʩʊʊ⸮⸮⸮⸮⸮⸮ˢʪ⸮ª⸮⸮⸮⸮a!..⸮⸮⸮ʂ⸮ʊʪ⸮ʂ⸮ˉʂ⸮ʪ⸮ʈC⸮
M⸮˪⸮⸮⸮i⸮⸮⸮ɪ⸮⸮⸮⸮⸮ ⸮L⸮)&%⸮⸮⸮⸮⸮⸮ꋣ⸮͊⸮⸮ʚ⸮⸮⸮ʃ⸮⸮⸮⸮⸮L⸮a͋⸮⸮⸮Y⸮⸮⸮i⸮⸮⸮i⸮J⸮%⸮ʢ⸮⸮⸮ˢ⸮⸮⸮a⸮⸮⸮⸮ʊ⸮⸮⸮⢉⸮⸮A⸮⸮⸮⸮⸮⸮a!.⸮⸮ʢ⸮ʊ⸮⸮⸮⸮⸮⸮⸮⸮⢉⸮⸮"i)&&⸮⸮⸮⸮ʊ⸮ʫ⸮⸮Ɋ⸮ˊ⸮ʁ˪⸮⸮⸮i)..⸮⸮⸮⸮¡ʊʊ⸮ʂ⸮⸮ɢ⸮˪ª⸮¢⸮⸮⸮⸮i⸮&.⸮⸮⸮ʊ⸮ʺ⸮ʊ⸮ˉ⸮ʪ⸮ʈC⸮
M⸮ê⸮⸮⸮i⸮⸮⸮⸮ʂ ⸮⸮⸮⸮ ⸮J⸮).-⸮⸮⸮⸮⸮⸮ꃣ⸮͚⸮⸮ʚ⸮⸮⸮Ã⸮⸮ʂ⸮⸮ ⸮Z⸮
̓⸮⸮⸮I⸮٣i⸮⸮⸮a⸮M⸮%⸮ʪ⸮⸮⸮ˢ⸮⸮⸮i⸮⸮⸮⸮ʫ⸮⸮⸮ꪁÉI⸮⸮⸮⸮⸮a!. ⸮⸮ª⸮ʂ⸮⸮⸮⸮⸮⸮⸮⸮ꢁ⸮⸮*i!&.⸮⸮⸮⸮ʊ¢⸮ʫ⸮⸮Ɋ⸮˂⸮ʉâY⸮⸮i!..⸮⸮⸮⸮ʩʊ⸮⸮⸮ɢ⸮êʂ⸮ʪ⸮⸮⸮⸮i)&&⸮⸮⸮⸮ʊʢ⸮ʊ⸮Éˊ⸮ʪˊ⸮C⸮
M⸮â⸮⸮⸮a⸮⸮⸮⸮£⸮⸮⸮⸮ ⸮C⸮!&-⸮⸮⸮⸮⸮⸮ꋂ⸮͊⸮⸮ʊ⸮⸮⸮⸮⸮ʂ⸮⸮⸮K⸮
⸮ʉ⸮⸮I⸮⸮⸮i⸮⸮⸮i ⸮D⸮
-⸮ª⸮⸮⸮ê⸮ˋi⸮⸮⸮Ɋ⸮ ⸮⸮⸮ꪉˉA⸮⸮⸮⸮⸮#i9&⸮⸮ʪ⸮⸮⸮⸮⸮ɉ⸮⸮*⸮⸮⸮⸮*i)>&⸮⸮⸮ʂ⸮ʊʪ⸮ʫ⸮⸮⸮Ê⸮Â⸮ʉâ⸮⸮⸮i!..⸮⸮⸮⸮ʩʊ⸮⸮⸮ɢ⸮˪ʊ⸮ª⸮⸮⸮⸮i).&⸮⸮⸮ʂ⸮ʊʢ⸮ʊ⸮ˁ˚⸮¢ˊ⸮C⸮M⸮ê⸮ˋi⸮⸮⸮ɂ⸮ ⸮⸮⸮⸮ ⸮B⸮).-⸮⸮⸮⸮ ⸮⸮⋪⸮͂⸮⸮ʪ⸮⸮⸮⸮ʋ⸮⸮⸮⸮ ⸮K⸮̓⸮⸮⸮A⸮⸮⸮a⸮ɫa⸮J⸮-⸮¢⸮⸮⸮ê⸮⸮⸮i⸮⸮⸮Ɋ⸮⸮⸮⸮⊉ÉI⸮⸮⸮⸮⸮⸮i!& ⸮⸮¢⸮ʊ⸮⸮⸮⸮Ɂy⸮ꪉ⸮⸮*i9&&⸮⸮⸮ʊ⸮ʂ¢⸮ʣ⸮⸮⸮ʂ⸮ˊ⸮ʁ˪⸮⸮⸮i)&&⸮⸮⸮⸮ʩʊ⸮⸮⸮ɢ⸮ˢʊ⸮¢⸮⸮⸮⸮i9&.⸮⸮⸮ʊ⸮⸮ʩʊ⸮Éˊ⸮ʢˊ⸮D⸮
M⸮Ú⸮⸮⸮i⸮⸮⸮Ɋ⸮⸮⸮⸮⸮ ⸮K⸮)&-⸮⸮⸮⸮ ⸮⸮ꃣ⸮͂⸮⸮⸮⸮⸮⸮⸮Á⸮⸮⸮⸮⸮+i!./⸮⸮I⸮⸮⸮i⸮⸮⸮i ⸮K⸮%⸮ʢ⸮⸮⸮ây⸮⸮a⸮⸮⸮⸮ڪ ⸮⸮⸮⢉ˉI⸮⸮⸮⸮⸮i!.⸮⸮ʂ⸮⸮ʡʊ⸮⸮⸮⸮⸮⸮ꪉ⸮⸮*i)..⸮⸮⸮ʂ⸮ʊ¢⸮ʻ⸮⸮⸮⸮˂⸮ʉˢ⸮⸮⸮i)&&⸮⸮⸮⸮ʩʂ⸮⸮⸮ɪ⸮êʊ⸮ª⸮⸮⸮⸮i)..⸮⸮⸮ʊ⸮ʂ⸮ʩ⸮ˉˊ⸮ʪÊ⸮L⸮M⸮˪⸮⸮⸮i⸮⸮⸮⸮Z⸮⸮⸮⸮⸮ ⸮J⸮).%⸮⸮⸮⸮⸮⸮⸮⸮⸮͂⸮⸮ʂ⸮⸮⸮É⸮⸮⸮⸮⸮i)&'⸮⸮A⸮⸮⸮a⸮⸮⸮i⸮J⸮-⸮¢⸮⸮⸮˪⸮⸮⸮i⸮⸮⸮⸮⸮⸮ ⸮⸮⸮ꪉK⸮I⸮⸮⸮⸮⸮i)& ⸮⸮ʊ⸮⸮ʩ⸮⸮⸮⸮⸮⸮⢩⸮⸮"i)&&⸮⸮⸮⸮ʪ⸮«⸮⸮⸮ʊ⸮ˊ⸮˪⸮⸮⸮i!.&⸮⸮⸮⸮©ʊʊ⸮ʊ⸮⸮ɪ⸮˪ʊ⸮ª⸮⸮⸮⸮i!..⸮⸮⸮ʊ⸮⸮¡ʊ⸮É˂⸮ʪ˂⸮L⸮E⸮ˢ⸮⸮⸮a⸮⸮⸮⸮⸮⸮ ⸮⸮⸮⸮ ⸮C⸮).%⸮⸮⸮⸮i⸮⸮⸮⸮Ŋ⸮⸮¢⸮⸮⸮ʉ⸮⸮⸮⸮⸮i)&'⸮⸮Y⸮⸮⸮i⸮⸮⸮i ⸮\⸮
-⸮¢⸮⸮⸮â⸮⸮⸮a⸮⸮⸮⸮⸮⸮⸮⢉˩A⸮⸮⸮⸮⸮i).⸮⸮ʚ⸮⸮ʩ⸮⸮ɉ⸮⸮ꪁ⸮⸮*a!..⸮⸮⸮ʊ⸮ʊ¢⸮ʣ⸮⸮⸮⸮˂⸮ʉâ⸮⸮⸮a9.&⸮⸮⸮⸮©ʊʊ⸮ʂ⸮⸮ɢ⸮ˢª⸮¢⸮⸮⸮⸮i!&.⸮⸮⸮ʊ⸮⸮ʩʊ⸮Éˊ⸮*⸮ˊ⸮L⸮M⸮˪⸮⸮⸮a⸮⸮⸮⸮ ⸮⸮⸮⸮ ⸮D⸮!.-⸮⸮⸮⸮ ⸮⸮⸮͂⸮⸮ʊ⸮⸮⸮⸮ˉ⸮⸮⸮⸮⸮a)./⸮⸮A⸮⸮⸮i⸮⸮⸮i⸮D⸮
%⸮ʪʁ⸮ê⸮{⸮a⸮⸮⸮⸮ ⸮⸮⸮⸮ʉˡI⸮⸮⸮⸮⸮i). ⸮⸮ʂ⸮ʪ⸮⸮ʪ⸮⸮⸮⸮⸮⸮¡⸮⸮i!..⸮⸮⸮⸮ʂ⸮ʫ⸮⸮⸮⸮˂⸮â⸮⸮⸮i9&&⸮⸮⸮⸮ʩ⸮ʁ⸮⸮⸮⸮⸮â⸮ª⸮⸮⸮⸮⸮i!&.⸮⸮⸮ʊ⸮ʚ⸮¡ʊ⸮ˉ˚⸮ʪˊ⸮M⸮M⸮˪⸮⸮⸮a⸮⸮⸮⸮ʋ ⸮⸮⸮⸮ ⸮B⸮!&-⸮⸮⸮⸮⸮⸮ꃫ⸮͂⸮⸮ʊ⸮⸮⸮⸮É⸮⸮⸮⸮⸮I)./⸮⸮I⸮⸮⸮i⸮⸮⸮i ⸮K⸮
%⸮ʪʉ⸮˪⸮{⸮i⸮⸮⸮ɂ⸮ ⸮⸮⸮⸮ځ⸮⸮I⸮⸮⸮⸮⸮#i)& ⸮⸮⸮¢⸮ʂ⸮ʪ⸮⸮⸮⸮⸮⸮ʩ⸮⸮i!..⸮⸮⸮ʊ⸮ʂ⸮ʫ⸮⸮⸮ʂ⸮ˊ⸮ˢ⸮⸮⸮i).&⸮⸮⸮⸮ʩ⸮ʁ⸮⸮ɪ⸮êʢ⸮ʪ⸮⸮⸮⸮a)..⸮⸮⸮ʊ⸮ʂ⸮ʡʂ⸮ˁˊ⸮ʪˢ⸮M⸮E⸮ˢ⸮⸮⸮a⸮⸮⸮⸮⸮⸮ ⸮⸮⸮⸮ ⸮B⸮!-⸮⸮⸮⸮⸮⸮ꃃ⸮͊⸮⸮ʊ⸮⸮⸮ʉ⸮⸮⸮⸮⸮i!./⸮⸮I⸮⸮⸮i⸮⸮⸮i ⸮C⸮
-⸮ª⸮⸮⸮˪⸮⸮⸮i⸮⸮⸮Ɋ⸮ ⸮⸮⸮ꪁ⸮⸮I⸮⸮⸮⸮⸮a). ⸮⸮ʂ⸮ʢ⸮ʊ⸮ª⸮⸮⸮⸮⸮⢩⸮⸮"a)⸮&⸮⸮⸮⸮ʂ⸮£⸮⸮⸮⸮Êʊ⸮ê⸮⸮⸮i)..⸮⸮⸮⸮ʩ⸮⸮⸮ɪ⸮ˢʚ⸮ʪ⸮⸮⸮⸮⸮a!..⸮⸮⸮ʂ⸮ʊ⸮©ʊ⸮É˂⸮ʪÂ⸮J⸮M⸮â⸮⸮⸮a⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮ ⸮C⸮!&%⸮⸮⸮⸮ ⸮⸮⃫⸮͂⸮⸮ʊ⸮⸮⸮ʁ⸮⸮⸮⸮⸮a).'⸮⸮I⸮⸮⸮⸮⸮⸮⸮a ⸮J⸮
%⸮ʢ⸮⸮⸮ˢ⸮⸮⸮i⸮⸮⸮Ɋ⸮⸮⸮⸮⪉⸮⸮A⸮⸮⸮⸮⸮i)>⸮⸮⸮ꪉ⸮ʢ⸮⸮⸮⸮⸮⪩⸮⸮"a).&⸮⸮⸮ʂ⸮ʂ⸮ʫ⸮⸮⸮⸮Âʊ⸮â⸮⸮⸮a)..⸮⸮⸮⸮©⸮ʁʊ⸮⸮⸮⸮⸮˪ʂ⸮ʪ⸮⸮⸮⸮#I!..⸮⸮⸮ʊ⸮⸮ʡ⸮ˉÂ⸮ʢÊ⸮J⸮
E⸮ˢ⸮⸮⸮i⸮⸮⸮Ɋ⸮ ⸮⸮⸮⸮ ⸮C⸮).%⸮⸮⸮⸮⸮⸮ꃣ⸮͚⸮⸮ʪ⸮⸮⸮ˁ⸮⸮⸮⸮⸮⸮i).'⸮⸮I⸮⸮⸮i⸮⸮⸮i ⸮D⸮
-⸮¢⸮⸮⸮ê⸮⸮⸮i⸮⸮⸮ɂ⸮ ⸮⸮⸮ꪉ⸮⸮Y⸮⸮⸮⸮⸮a).⸮⸮ʊ⸮ª⸮ʊ⸮ʪ⸮⸮⸮⸮⸮⪩⸮⸮"i)..⸮⸮⸮ʊ⸮ʊ⸮ʫ⸮⸮⸮ʊ⸮Êʂ⸮ê⸮⸮⸮i)&&⸮⸮⸮⸮©ʚ⸮ʂ⸮⸮ɢ⸮êʊ⸮ʪ⸮⸮⸮⸮+i!..⸮⸮⸮*⸮⸮ʂ⸮ʩ⸮ˉÂ⸮ʪÂ⸮J⸮E⸮ˢ⸮⸮⸮i⸮⸮⸮ɂ⸮⸮⸮⸮⸮ ⸮B⸮!&-⸮⸮⸮⸮⸮⸮ꋃ⸮⸮Z⸮⸮ʪ⸮⸮⸮⸮⸮⸮⸮⸮i!./⸮⸮A⸮⸮⸮i⸮⸮⸮a ⸮K⸮-⸮¢⸮⸮⸮â⸮⸮⸮a⸮⸮⸮Ɋ⸮ ⸮⸮⸮ꪉ⸮⸮I⸮⸮⸮⸮⸮+i!& ⸮⸮ʊ⸮¢⸮ʊ⸮⸮⸮ɩ⸮⸮⪩⸮⸮*i)&.⸮⸮⸮ʂ⸮ʂʊ⸮ʣ⸮⸮⸮ʊ⸮Âʊ⸮˪⸮⸮⸮i)&.⸮⸮⸮⸮ʡʊ⸮ʊ⸮⸮ɪ⸮âʊ⸮ª⸮⸮⸮⸮a)..⸮⸮⸮ʂ⸮ʊ⸮©ʂ⸮⸮ɂ⸮ʪÂ⸮M⸮⸮M⸮â⸮⸮⸮a⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮ ⸮K⸮).-⸮⸮⸮⸮⸮⸮ꃣ⸮͂⸮⸮ʢ⸮⸮⸮⸮⸮⸮⸮⸮a!./⸮⸮I⸮⸮⸮i⸮⸮⸮i ⸮B⸮
%⸮ʪ⸮⸮⸮ˢ⸮⸮⸮a⸮⸮⸮ɂJ ⸮⸮⸮ꪉ⸮⸮I⸮⸮⸮⸮⸮i)& ⸮⸮⸮ʪ⸮ʊ⸮⸮⸮ɩ⸮⸮ꪩ⸮⸮*a!..⸮⸮⸮ʊ⸮ʊ⸮ʁʫ⸮⸮⸮ʊ⸮Êʪ⸮â⸮⸮⸮⸮a).&⸮⸮⸮⸮ʩʊ⸮⸮⸮⸮⸮⸮˪¢⸮ʢ⸮⸮⸮⸮#a)..⸮⸮⸮ʊ⸮⸮ʩ⸮⸮⸮⸮⸮¢ˊ⸮E⸮
M⸮ê⸮⸮⸮i⸮⸮⸮Ɋ⸮⸮⸮⸮⸮ ⸮⸮L⸮!.-⸮⸮⸮⸮⸮⸮ꋋ⸮͊⸮⸮ʊ⸮⸮⸮⸮⸮⸮⸮⸮i!&/⸮⸮A⸮⸮⸮a⸮⸮⸮a ⸮C⸮
-⸮ª⸮⸮⸮˪⸮⸮⸮i⸮⸮⸮Ɋ⸮⸮⸮⸮⪉⸮⸮I⸮⸮⸮⸮⸮+i!. ⸮⸮ʂ⸮ʪ⸮ʊ⸮⸮⸮ɩ⸮⸮⪩⸮⸮*i)..⸮⸮⸮ʊ⸮ʊ⸮ʉ«⸮⸮⸮ʊ⸮Êʪ⸮˪Y⸮⸮⸮i!..⸮⸮⸮⸮ʡ⸮ʁʊ⸮⸮⸮⸮⸮âʊ⸮¢⸮⸮⸮⸮+i)&.⸮⸮⸮ʊ⸮⸮ʩ⸮⸮⸮⸮⸮ʪ˂⸮M⸮E⸮˚⸮⸮⸮i⸮⸮⸮⸮⸮⸮ ⸮⸮⸮⸮⸮K⸮).-⸮⸮⸮⸮ ⸮⸮⸮⸮⸮Ŋ⸮⸮ʂ⸮⸮⸮⸮⸮⸮⸮⸮i)&/⸮⸮I⸮⸮⸮i⸮ɪi⸮L⸮
-⸮ʪ⸮⸮⸮ˢ⸮⸮⸮a⸮⸮⸮⸮⸮⸮ ⸮⸮⸮ꪁ⸮⸮I⸮⸮⸮⸮⸮i)& ⸮⸮⸮ʢ⸮*⸮⸮⸮⸮ɡ⸮⸮ꢡ⸮⸮"a).
That garbage probably indicates that the baud rate for the GPS is wrong.
Ok, i correct it.
12:28:39.100 -> & ⸮b⸮⸮b⸮⸮⸮bR⸮⸮j
12:28:39.100 -> $GPGSV,3,2,12,07,01,185,,09,49,231,20,11,07,318,,17,18,236,29*79
12:28:39.200 -> $GPGSV,3,3,12,19,27,264,30,21,02,155,08,26,03,082,,31,18,040,15*7A
12:28:39.247 -> $GPGLL,4923.55162,N,01527.99907,E,102840.00,A,A*60
12:28:39.802 -> $GPRMC,102841.00,A,4923.55147,N,01527.99891,E,0.792,,081022,,,A*74
12:28:39.849 -> $GPVTG,,T,,M,0.792,N,1.466,K,A*2A
12:28:39.902 -> $GPGGA,102841.00,4923.55147,N,01527.99891,E,1,07,1.11,572.1,M,43.4,M,,*59
12:28:39.949 -> $GPGSA,A,3,03,04,01,17,19,31,09,,,,,,1.85,1.11,1.48*01
12:28:40.002 -> $GPGSV,3,1,12,01,21,158,32,03,53,093,15,04,85,152,23,06,37,308,*7B
12:28:40.103 -> $GPGSV,3,2,12,07,01,185,,09,49,231,21,11,07,318,,17,18,236,29*78
12:28:40.150 -> $GPGSV,3,3,12,19,27,264,30,21,02,155,08,26,03,082,,31,18,040,15*7A
12:28:40.203 -> $GPGLL,4923.55147,N,01527.99891,E,102841.00,A,A*68
12:28:40.805 -> $GPRMC,102842.00,A,4923.55125,N,01527.99867,E,0.968,,081022,,,A*71
12:28:40.852 -> $GPVTG,,T,,M,0.968,N,1.794,K,A*2F
12:28:40.905 -> $GPGGA,102842.00,4923.55125,N,01527.99867,E,1,07,1.11,572.5,M,43.4,M,,*53
12:28:40.952 -> $GPGSA,A,3,03,04,01,17,19,31,09,,,,,,1.85,1.11,1.48*01
12:28:41.005 -> $GPGSV,3,1,12,01,21,158,32,03,53,093,15,04,85,152,23,06,37,308,*7B
12:28:41.106 -> $GPGSV,3,2,12,07,01,185,,09,49,231,22,11,07,318,22,17,18,236,30*73
12:28:41.152 -> $GPGSV,3,3,12,19,27,264,30,21,02,155,08,26,03,082,,31,18,040,15*7A
12:28:41.206 -> $GPGLL,4923.55125,N,01527.99867,E,102842.00,A,A*66
12:28:41.807 -> $GPRMC,102843.00,A,4923.55158,N,01527.99891,E,0.175,,081022,,,A*77
12:28:41.854 -> $GPVTG,,T,,M,0.175,N,0.324,K,A*25
12:28:41.908 -> $GPGGA,102843.00,4923.55158,N,01527.99891,E,1,07,1.11,573.0,M,43.4,M,,*55
12:28:41.955 -> $GPGSA,A,3,03,04,01,17,19,31,09,,,,,,1.85,1.11,1.48*01
12:28:42.008 -> $GPGSV,3,1,12,01,21,158,32,03,53,093,15,04,85,152,21,06,37,308,*79
12:28:42.108 -> $GPGSV,3,2,12,07,01,185,,09,49,231,22,11,07,318,17,17,18,236,29*7D
12:28:42.155 -> $GPGSV,3,3,12,19,27,264,30,21,02,155,18,26,03,082,,31,18,040,14*7A
12:28:42.209 -> $GPGLL,4923.55158,N,01527.99891,E,102843.00,A,A*64
12:28:42.810 -> $GPRMC,102844.00,A,4923.55173,N,01527.99896,E,0.029,,081022,,,A*76
12:28:42.857 -> $GPVTG,,T,,M,0.029,N,0.054,K,A*29
12:28:42.911 -> $GPGGA,102844.00,4923.55173,N,01527.99896,E,1,07,1.11,572.8,M,43.4,M,,*55
12:28:42.957 -> $GPGSA,A,3,03,04,01,17,19,31,09,,,,,,1.85,1.11,1.48*01
12:28:43.011 -> $GPGSV,3,1,12,01,21,158,32,03,53,093,15,04,85,152,21,06,37,308,*79
12:28:43.111 -> $GPGSV,3,2,12,07,01,185,,09,49,231,22,11,07,318,14,17,18,236,29*7E
12:28:43.158 -> $GPGSV,3,3,12,19,27,264,30,21,02,155,16,26,03,082,,31,18,040,16*76
12:28:43.211 -> $GPGLL,4923.55173,N,01527.99896,E,102844.00,A,A*6D
12:28:43.813 -> $GPRMC,102845.00,A,4923.55204,N,01527.99922,E,0.376,,081022,,,A*73
12:28:43.860 -> $GPVTG,,T,,M,0.376,N,0.697,K,A*29
12:28:43.913 -> $GPGGA,102845.00,4923.55204,N,01527.99922,E,1,07,1.11,572.6,M,43.4,M,,*57
12:28:43.960 -> $GPGSA,A,3,03,04,01,17,19,31,09,,,,,,1.85,1.11,1.48*01
12:28:44.014 -> $GPGSV,3,1,12,01,21,158,32,03,53,093,16,04,85,152,22,06,37,308,*79
12:28:44.114 -> $GPGSV,3,2,12,07,01,185,,09,49,231,23,11,07,318,09,17,18,236,28*72
12:28:44.161 -> $GPGSV,3,3,12,19,27,264,30,21,02,155,14,26,03,082,,31,18,040,16*74
12:28:44.214 -> $GPGLL,4923.55204,N,01527.99922,E,102845.00,A,A*61
12:28:44.816 -> $GPRMC,102846.00,A,4923.55237,N,01527.99946,E,0.738,,081022,,,A*7C
12:28:44.863 -> $GPVTG,,T,,M,0.738,N,1.366,K,A*2D
12:28:44.916 -> $GPGGA,102846.00,4923.55237,N,01527.99946,E,1,07,1.11,572.5,M,43.4,M,,*55
12:28:44.963 -> $GPGSA,A,3,03,04,01,17,19,31,09,,,,,,1.85,1.11,1.48*01
12:28:45.016 -> $GPGSV,3,1,12,01,21,158,31,03,53,093,16,04,85,152,23,06,37,308,*7B
12:28:45.117 -> $GPGSV,3,2,12,07,01,185,,09,49,231,24,11,07,318,08,17,18,236,27*7B
12:28:45.164 -> $GPGSV,3,3,12,19,27,264,30,21,02,155,15,26,03,082,,31,18,040,16*75
12:28:45.217 -> $GPGLL,4923.55237,N,01527.99946,E,102846.00,A,A*60
12:28:45.819 -> $GPRMC,102847.00,A,4923.55261,N,01527.99970,E,0.569,,081022,,,A*7D
12:28:45.865 -> $GPVTG,,T,,M,0.569,N,1.053,K,A*2E
12:28:45.919 -> $GPGGA,102847.00,4923.55261,N,01527.99970,E,1,07,1.11,572.1,M,43.4,M,,*56
12:28:45.966 -> $GPGSA,A,3,03,04,01,17,19,31,09,,,,,,1.85,1.11,1.48*01
12:28:46.019 -> $GPGSV,3,1,12,01,21,158,32,03,53,093,16,04,85,152,23,06,37,308,*78
12:28:46.119 -> $GPGSV,3,2,12,07,01,185,,09,49,231,25,11,07,318,09,17,18,236,27*7B
12:28:46.166 -> $GPGSV,3,3,12,19,27,264,30,21,02,155,15,26,03,082,,31,18,040,16*75
12:28:46.220 -> $GPGLL,4923.55261,N,01527.99970,E,102847.00,A,A*67
12:28:46.821 -> $GPRMC,102848.00,A,4923.55291,N,01527.99988,E,0.468,,081022,,,A*7A
12:28:46.868 -> $GPVTG,,T,,M,0.468,N,0.867,K,A*20
12:28:46.868 -> $GPGGA,102848.00,4923.55291,N,01527.99988,E,1,07,1.11,572.0,M,43.4,M,,*50
12:28:46.969 -> $GPGSA,A,3,03,04,01,17,19,31,09,,,,,,1.85,1.11,1.48*01
12:28:47.022 -> $GPGSV,3,1,12,01,21,158,31,03,53,093,17,04,85,152,24,06,37,308,*7D
12:28:47.069 -> $GPGSV,3,2,12,07,01,185,,09,49,231,25,11,07,318,09,17,18,236,29*75
12:28:47.169 -> $GPGSV,3,3,12,19,27,264,31,21,02,155,14,26,03,082,,31,18,040,16*75
12:28:47.223 -> $GPGLL,4923.55291,N,01527.99988,E,102848.00,A,A*60
12:28:47.771 -> $GPRMC,102849.00,A,4923.55305,N,01528.00003,E,0.497,,081022,,,A*72
12:28:47.871 -> $GPVTG,,T,,M,0.497,N,0.920,K,A*22
12:28:47.871 -> $GPGGA,102849.00,4923.55305,N,01528.00003,E,1,07,1.11,572.4,M,43.4,M,,*5C
12:28:47.971 -> $GPGSA,A,3,03,04,01,17,19,31,09,,,,,,1.85,1.11,1.48*01
12:28:48.025 -> $GPGSV,3,1,12,01,21,158,32,03,53,093,19,04,85,152,25,06,37,308,*71
12:28:48.072 -> $GPGSV,3,2,12,07,01,185,,09,49,231,25,11,07,318,09,17,18,236,29*75
12:28:48.172 -> $GPGSV,3,3,12,19,27,264,30,21,02,155,13,26,03,082,,31,18,040,16*73
12:28:48.225 -> $GPGLL,4923.55305,N,01528.00003,E,102849.00,A,A*68
12:28:48.774 -> $GPRMC,102850.00,A,4923.55299,N,01527.99992,E,0.244,,081022,,,A*78
12:28:48.874 -> $GPVTG,,T,,M,0.244,N,0.453,K,A*23
12:28:48.874 -> $GPGGA,102850.00,4923.55299,N,01527.99992,E,1,07,1.11,572.3,M,43.4,M,,*59
12:28:48.974 -> $GPGSA,A,3,03,04,01,17,19,31,09,,,,,,1.85,1.11,1.48*01
12:28:49.028 -> $GPGSV,3,1,12,01,21,158,33,03,53,093,19,04,85,152,25,06,37,308,06*76
12:28:49.074 -> $GPGSV,3,2,12,07,01,185,,09,49,231,25,11,07,318,08,17,18,236,29*74
12:28:49.175 -> $GPGSV,3,3,12,19,27,264,30,21,02,155,14,26,03,082,,31,18,040,17*75
12:28:49.228 -> $GPGLL,4923.55299,N,01527.99992,E,102850.00,A,A*6A
12:28:49.776 -> $GPRMC,102851.00,A,4923.55291,N,01527.99986,E,0.047,,081022,,,A*75
12:28:49.877 -> $GPVTG,,T,,M,0.047,N,0.086,K,A*2E
12:28:49.877 -> $GPGGA,102851.00,4923.55291,N,01527.99986,E,1,07,1.11,572.3,M,43.4,M,,*55
12:28:49.977 -> $GPGSA,A,3,03,04,01,17,19,31,09,,,,,,1.85,1.11,1.48*01
12:28:50.030 -> $GPGSV,3,1,12,01,21,158,32,03,53,093,20,04,85,152,25,06,37,308,07*7C
12:28:50.077 -> $GPGSV,3,2,12,07,01,185,,09,49,231,25,11,07,318,08,17,18,236,29*74
12:28:50.177 -> $GPGSV,3,3,12,19,27,264,30,21,02,155,15,26,03,082,,31,18,040,17*74
12:28:50.231 -> $GPGLL,4923.55291,N,01527.99986,E,102851.00,A,A*66
12:28:50.779 -> $GPRMC,102852.00,A,4923.55274,N,01527.99973,E,0.441,,081022,,,A*75
12:28:50.879 -> $GPVTG,,T,,M,0.441,N,0.816,K,A*2D
12:28:50.879 -> $GPGGA,102852.00,4923.55274,N,01527.99973,E,1,08,1.11,572.4,M,43.4,M,,*5F
12:28:50.980 -> $GPGSA,A,3,03,04,01,17,19,31,09,06,,,,,1.85,1.11,1.48*07
12:28:51.033 -> $GPGSV,3,1,12,01,21,158,33,03,53,093,20,04,85,152,25,06,37,308,10*7B
12:28:51.080 -> $GPGSV,3,2,12,07,01,185,,09,49,231,25,11,07,318,08,17,18,236,30*7C
12:28:51.180 -> $GPGSV,3,3,12,19,27,264,31,21,02,155,16,26,03,082,,31,18,040,17*76
12:28:51.234 -> $GPGLL,4923.55274,N,01527.99973,E,102852.00,A,A*64
12:28:51.782 -> $GPRMC,102853.00,A,4923.55269,N,01527.99974,E,0.262,,081022,,,A*78
12:28:51.835 -> $GPVTG,,T,,M,0.262,N,0.485,K,A*2C
12:28:51.882 -> $GPGGA,102853.00,4923.55269,N,01527.99974,E,1,08,1.11,572.4,M,43.4,M,,*55
12:28:51.936 -> $GPGSA,A,3,03,04,01,17,19,31,09,06,,,,,1.85,1.11,1.48*07
12:28:52.036 -> $GPGSV,3,1,12,01,21,158,32,03,53,093,20,04,85,152,25,06,37,308,12*78
12:28:52.083 -> $GPGSV,3,2,12,07,01,185,,09,49,231,25,11,07,318,08,17,18,236,30*7C
12:28:52.136 -> $GPGSV,3,3,12,19,27,264,31,21,02,155,16,26,03,082,,31,18,040,17*76
12:28:52.236 -> $GPGLL,4923.55269,N,01527.99974,E,102853.00,A,A*6E
12:28:52.785 -> $GPRMC,102854.00,A,4923.55274,N,01527.99987,E,0.156,,081022,,,A*7B
12:28:52.885 -> $GPVTG,,T,,M,0.156,N,0.290,K,A*2A
12:28:52.885 -> $GPGGA,102854.00,4923.55274,N,01527.99987,E,1,08,1.11,572.3,M,43.4,M,,*55
12:28:52.985 -> $GPGSA,A,3,03,04,01,17,19,31,09,06,,,,,1.85,1.11,1.48*07
12:28:53.039 -> $GPGSV,3,1,12,01,21,158,32,03,53,093,21,04,85,152,24,06,37,308,14*7E
12:28:53.086 -> $GPGSV,3,2,12,07,01,185,,09,49,231,25,11,07,318,08,17,18,236,30*7C
12:28:53.186 -> $GPGSV,3,3,12,19,27,264,31,21,02,155,17,26,03,082,,31,18,040,17*77
12:28:53.239 -> $GPGLL,4923.55274,N,01527.99987,E,102854.00,A,A*69
12:28:53.787 -> $GPRMC,102855.00,A,4923.55249,N,01528.00005,E,0.371,,081022,,,A*7F
12:28:53.888 -> $GPVTG,,T,,M,0.371,N,0.687,K,A*2F
12:28:53.888 -> $GPGGA,102855.00,4923.55249,N,01528.00005,E,1,08,0.96,572.6,M,43.4,M,,*5D
12:28:53.988 -> $GPGSA,A,3,03,04,01,17,19,31,09,06,,,,,1.76,0.96,1.47*0A
12:28:54.041 -> $GPGSV,3,1,12,01,21,158,32,03,53,093,21,04,85,152,25,06,37,308,15*7E
12:28:54.088 -> $GPGSV,3,2,12,07,01,185,,09,49,231,25,11,07,318,08,17,18,236,30*7C
12:28:54.142 -> $GPGSV,3,3,12,19,27,264,31,21,02,155,17,26,03,082,,31,18,040,17*77
12:28:54.242 -> $GPGLL,4923.55249,N,01528.00005,E,102855.00,A,A*6A
12:28:54.790 -> $GPRMC,102856.00,A,4923.55239,N,01528.00000,E,0.226,,081022,,,A*7D
12:28:54.844 -> $GPVTG,,T,,M,0.226,N,0.419,K,A*29
12:28:54.891 -> $GPGGA,102856.00,4923.55239,N,01528.00000,E,1,08,1.11,572.5,M,43.4,M,,*51
12:28:54.944 -> $GPGSA,A,3,03,04,01,17,19,31,09,06,,,,,1.85,1.11,1.48*07
12:28:55.044 -> $GPGSV,3,1,12,01,21,158,32,03,53,093,21,04,85,152,25,06,37,308,15*7E
12:28:55.091 -> $GPGSV,3,2,12,07,01,185,,09,49,231,24,11,07,318,09,17,18,236,30*7C
12:28:55.144 -> $GPGSV,3,3,12,19,27,264,31,21,02,155,16,26,03,082,,31,18,040,16*77
12:28:55.245 -> $GPGLL,4923.55239,N,01528.00000,E,102856.00,A,A*6B
12:28:55.793 -> $GPRMC,102857.00,A,4923.55181,N,01527.99978,E,0.673,,081022,,,A*71
12:28:55.846 -> $GPVTG,,T,,M,0.673,N,1.246,K,A*20
12:28:55.893 -> $GPGGA,102857.00,4923.55181,N,01527.99978,E,1,08,0.96,572.5,M,43.4,M,,*57
12:28:55.947 -> $GPGSA,A,3,03,04,01,17,19,31,09,06,,,,,1.76,0.96,1.47*0A
12:28:56.047 -> $GPGSV,3,1,12,01,21,158,32,03,53,093,22,04,85,152,25,06,37,308,15*7D
12:28:56.094 -> $GPGSV,3,2,12,07,01,185,,09,49,231,24,11,07,318,09,17,18,236,30*7C
12:28:56.147 -> $GPGSV,3,3,12,19,27,264,31,21,02,155,16,26,03,082,,31,18,040,16*77
12:28:56.248 -> $GPGLL,4923.55181,N,01527.99978,E,102857.00,A,A*63
12:28:56.796 -> $GPRMC,102858.00,A,4923.55124,N,01527.99964,E,0.735,,081022,,,A*7F
12:28:56.849 -> $GPVTG,,T,,M,0.735,N,1.362,K,A*24
12:28:56.896 -> $GPGGA,102858.00,4923.55124,N,01527.99964,E,1,08,0.96,572.7,M,43.4,M,,*58
12:28:56.950 -> $GPGSA,A,3,03,04,01,17,19,31,09,06,,,,,1.76,0.96,1.47*0A
12:28:57.050 -> $GPGSV,3,1,12,01,21,158,32,03,53,093,23,04,85,152,25,06,37,308,15*7C
12:28:57.097 -> $GPGSV,3,2,12,07,01,185,,09,49,231,24,11,07,318,09,17,18,236,30*7C
12:28:57.150 -> $GPGSV,3,3,12,19,27,264,32,21,02,155,15,26,03,082,,31,18,040,16*77
12:28:57.250 -> $GPGLL,4923.55124,N,01527.99964,E,102858.00,A,A*6E
12:28:57.799 -> $GPRMC,102859.00,A,4923.55117,N,01527.99959,E,0.442,,081022,,,A*73
12:28:57.852 -> $GPVTG,,T,,M,0.442,N,0.818,K,A*20
12:28:57.899 -> $GPGGA,102859.00,4923.55117,N,01527.99959,E,1,08,1.11,572.8,M,43.4,M,,*56
12:28:57.952 -> $GPGSA,A,3,03,04,01,17,19,31,09,06,,,,,1.85,1.11,1.48*07
12:28:58.053 -> $GPGSV,3,1,12,01,21,158,32,03,53,093,23,04,85,152,25,06,37,308,14*7D
12:28:58.099 -> $GPGSV,3,2,12,07,01,185,,09,49,231,24,11,07,318,09,17,18,236,30*7C
12:28:58.153 -> $GPGSV,3,3,12,19,27,264,32,21,02,155,14,26,03,082,,31,18,040,16*76
12:28:58.253 -> $GPGLL,4923.55117,N,01527.99959,E,102859.00,A,A*61
12:28:58.801 -> $GPRMC,102900.00,A,4923.55085,N,01527.99965,E,0.463,,081022,,,A*78
12:28:58.855 -> $GPVTG,,T,,M,0.463,N,0.858,K,A*27
12:28:58.902 -> $GPGGA,102900.00,4923.55085,N,01527.99965,E,1,08,0.96,572.1,M,43.4,M,,*59
12:28:58.955 -> $GPGSA,A,3,03,04,01,17,19,31,09,06,,,,,1.76,0.96,1.47*0A
12:28:59.055 -> $GPGSV,3,1,12,01,21,158,32,03,53,093,23,04,85,152,25,06,37,308,16*7F
12:28:59.102 -> $GPGSV,3,2,12,07,01,185,,09,49,231,23,11,07,318,09,17,18,236,30*7B
12:28:59.156 -> $GPGSV,3,3,12,19,27,264,31,21,02,155,13,26,03,082,,31,18,040,16*72
12:28:59.256 -> $GPGLL,4923.55085,N,01527.99965,E,102900.00,A,A*69
12:28:59.804 -> $GPRMC,102901.00,A,4923.55085,N,01527.99966,E,0.590,,081022,,,A*77
12:28:59.858 -> $GPVTG,,T,,M,0.590,N,1.092,K,A*25
12:28:59.904 -> $GPGGA,102901.00,4923.55085,N,01527.99966,E,1,08,1.11,572.0,M,43.4,M,,*54
12:28:59.958 -> $GPGSA,A,3,03,04,01,17,19,31,09,06,,,,,1.85,1.11,1.48*07
12:29:00.058 -> $GPGSV,3,1,12,01,21,158,32,03,53,093,23,04,85,152,25,06,37,308,17*7E
12:29:00.105 -> $GPGSV,3,2,12,07,01,185,,09,49,231,23,11,07,318,09,17,18,236,30*7B
12:29:00.158 -> $GPGSV,3,3,12,19,27,264,32,21,02,155,14,26,03,082,,31,18,040,16*76
12:29:00.259 -> $GPGLL,4923.55085,N,01527.99966,E,102901.00,A,A*6B
I have this output
This already resembles coordinates in some lines.
Looks good. Try your earlier code with the corrected baud rate.
Ok, now i have this:
12:40:55.911 -> FullExample.ino
12:40:55.911 -> An extensive example of many interesting TinyGPSPlus features
12:40:55.911 -> Testing TinyGPSPlus library v. 1.0.2
12:40:55.958 -> by Mikal Hart
12:40:55.958 ->
12:40:55.958 -> Sats HDOP Latitude Longitude Fix Date Time Date Alt Course Speed Card Distance Course Card Chars Sentences Checksum
12:40:56.011 -> (deg) (deg) Age Age (m) --- from GPS ---- ---- to London ---- RX RX Fail
12:40:56.112 -> ----------------------------------------------------------------------------------------------------------------------------------------
12:40:56.159 -> **** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 162 0 3
12:40:57.262 -> 6 2.3 49.392574 15.466665 319 10/08/2022 10:40:58 434 558.90 0.00 0.48 N 1126 287.98 WNW 639 2 3
12:40:58.264 -> 6 2.3 49.392574 15.466665 329 10/08/2022 10:40:59 445 559.10 0.00 1.31 N 1126 287.98 WNW 1116 4 3
12:40:59.267 -> 6 2.3 49.392570 15.466664 334 10/08/2022 10:41:00 451 559.10 0.00 1.13 N 1126 287.98 WNW 1593 6 3
12:41:00.270 -> 6 2.3 49.392570 15.466665 344 10/08/2022 10:41:01 459 559.00 0.00 0.98 N 1126 287.98 WNW 2070 8 3
12:41:01.273 -> 6 2.3 49.392570 15.466665 355 10/08/2022 10:41:02 470 559.10 0.00 1.02 N 1126 287.98 WNW 2545 10 3
12:41:02.276 -> 7 1.1 49.392551 15.466652 361 10/08/2022 10:41:03 476 561.80 0.00 1.04 N 1126 287.98 WNW 3022 12 3
12:41:03.278 -> 8 2.4 49.392547 15.466652 370 10/08/2022 10:41:04 485 561.90 0.00 0.04 N 1126 287.98 WNW 3503 14 3
12:41:04.335 -> 8 2.4 49.392551 15.466653 376 10/08/2022 10:41:05 492 562.00 0.00 0.24 N 1126 287.98 WNW 3984 16 3
12:41:05.337 -> 8 2.4 49.392551 15.466654 386 10/08/2022 10:41:06 501 562.20 0.00 0.74 N 1126 287.98 WNW 4465 18 3
12:41:06.340 -> 8 2.4 49.392551 15.466656 395 10/08/2022 10:41:07 511 562.50 0.00 0.30 N 1126 287.98 WNW 4946 20 3
12:41:07.343 -> 8 1.6 49.392551 15.466656 404 10/08/2022 10:41:08 519 562.70 0.00 0.22 N 1126 287.98 WNW 5427 22 3
12:41:08.346 -> 8 1.6 49.392551 15.466656 412 10/08/2022 10:41:09 528 562.90 0.00 0.06 N 1126 287.98 WNW 5908 24 3
12:41:09.348 -> 7 1.6 49.392551 15.466656 422 10/08/2022 10:41:10 538 563.10 0.00 0.17 N 1126 287.98 WNW 6385 26 3
12:41:10.351 -> 7 1.6 49.392547 15.466657 432 10/08/2022 10:41:11 547 563.30 0.00 0.48 N 1126 287.98 WNW 6862 28 3
12:41:11.354 -> 8 1.6 49.392551 15.466658 438 10/08/2022 10:41:12 554 563.20 0.00 0.33 N 1126 287.98 WNW 7343 30 3
12:41:12.357 -> 6 2.4 49.392547 15.466658 451 10/08/2022 10:41:13 567 563.50 0.00 0.56 N 1126 287.98 WNW 7816 32 3
This is proof that GPS is functional
bullseye!
Great, what next?
