Hello Everybody,
I am trying to build GPS data logger using Quectel L80 module with Arduino Mega, I can successfully log data into the Sd card, I assigned filename as 000.tcx, eveytime I have to delete the file from SD and log data again..
I want to create a file name as the time and date and log that data into it.
Here is my code.
#include <Arduino.h>
#include <NMEAGPS.h>
#include <SPI.h>
#include <SdFat.h>
NMEAGPS gps; // This parses the GPS characters
gps_fix fix; // This contains all the GPS fields
#define gps_port Serial1
SdFat SD;
File dataFile;
char filename[] = "000.tcx";
const int xpin = A0; // x-axis of the accelerometer
const int ypin = A1; // y-axis
const int zpin = A2; // z-axis
int x, y, z, total;
Serial.flush();
gps_port.begin( 9600 );
gps.send_P( &gps_port, F("PMTK251,115200") ); // set baud rate
gps_port.flush(); // wait for the command to go out
delay( 100 ); // wait for the GPS device to change speeds
gps_port.end(); // empty the input buffer, too
gps_port.begin( 115200 ); // use the new baud rate
gps.send_P( &gps_port, F("PMTK220,100") ); // set 10Hz update rate
pinMode(37, INPUT_PULLUP);
if (!SD.begin(4)) {
Serial.println( F("Card failed, or not present") );
// don't do anything more:
return;
Serial.println( F("card initialized.") );
Serial.println( F("Code Running") );
} // setup
void firstStage()
Serial.println( F("Co-ordinates Achieved") );
// sprintf(filename, "%02d-%02d-%02d-T-%02d-%02d-%02d.tcx", fix.dateTime.hours , fix.dateTime.minutes, fix.dateTime.hours, fix.dateTime.date , fix.dateTime.month , fix.dateTime.full_year());
dataFile = SD.open(filename , FILE_WRITE);
Serial.println(filename);
if (dataFile) {
Serial.println( F("File created\n"
"LOGGING DATA!\n") );
dataFile.println( F("<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n"
"<TrainingCenterDatabase xmlns=\""
"http://www.garmin.com/"
"xmlschemas/TrainingCenterDatabase/v2\">\n"
"<Activities>\n"
"<Activity Sport=\"Other\">") );
dataFile.println( F("<Id>") );
timing();
dataFile.println( F("0Z"
"</Id>\n"
"<Lap StartTime=\"") );
timing();
dataFile.println( F("0Z\">"
"<Track>") );
} // firstStage
void secondStage()
if (dataFile.isOpen()) {
dataFile.println( F("<Trackpoint>\n"
"<Time>") );
timing();
dataFile.print ( F("0Z"
"</Time>"
"<Position>\n"
"<LatitudeDegrees>") );
dataFile.print ( fix.latitude(), 5 );
dataFile.print ( F("</LatitudeDegrees>\n"
"<LongitudeDegrees>") );
dataFile.print ( fix.longitude(), 5 );
dataFile.print ( F("</LongitudeDegrees>\n"
"</Position>\n"
"<HeartRateBpm>\n"
"<Value>") );
dataFile.print ( '0' );
dataFile.print ( F("</Value>\n"
"</HeartRateBpm>\n"
"<SensorState>"
"Present"
"</SensorState>\n") );
analogReference(EXTERNAL);
x = analogRead(xpin);
y = analogRead(ypin);
z = analogRead(zpin);
total = sqrt( x * x + y * y + z * z );
dataFile.print ( F("<Impact>"
"<Gforce>") );
dataFile.print ( total );
dataFile.print ( F("</Gforce>\n"
"<Xaxis>") );
dataFile.print ( x );
dataFile.print ( F("</Xaxis>\n"
"<Yaxis>") );
dataFile.print ( y );
dataFile.print ( F("</Yaxis>\n"
"<Zaxis>") );
dataFile.print ( z );
dataFile.println( F("</Zaxis>\n"
"</Impact>\n"
"</Trackpoint>") );
} // secondStage
void doSomeWork() {
if (fix.valid.date && fix.valid.time && fix.valid.location)
if (!dataFile.isOpen())
firstStage();
secondStage();
else {
// No valid location data yet!
Serial.print ( '?' );
} // doSomeWork
void GPSloop()
while (gps.available( gps_port) ) {
fix = gps.read();
doSomeWork();
} // GPSloop
GPSloop();
// Testing the button could go almost anywhere.
// Putting it here will close dataFile the fastest,
// because it won't have to wait for the next
// GPS update.
if (digitalRead(37) == LOW) {
endtask();
// stop here!
while (1);
} // loop
void endtask()
dataFile.println( F("</Track>\n"
"</Lap>\n"
"</Activity>\n"
"</Activities>\n"
"</TrainingCenterDatabase>") );
dataFile.close();
Serial.println( F("file closed") );
Serial.println( F("(file never opened)") );
} // endtask
void timing () {
if ( fix.dateTime.full_year() < 10 )
dataFile.print( '0' );
dataFile.print ( fix.dateTime.full_year() );
dataFile.print ( '-' );
if ( fix.dateTime.month < 10 )
dataFile.print ( fix.dateTime.month );
if ( fix.dateTime.date < 10 )
dataFile.print ( fix.dateTime.date );
dataFile.print ( 'T' );
if ( fix.dateTime.hours < 10 )
dataFile.print ( fix.dateTime.hours );
dataFile.print ( ':' );
if ( fix.dateTime.minutes < 10 )
dataFile.print ( fix.dateTime.minutes );
if ( fix.dateTime.seconds < 10 )
dataFile.print ( fix.dateTime.seconds );
dataFile.print ( '.' );
if ( fix.dateTime_cs < 10 )
dataFile.print ( fix.dateTime_cs );
Thank you
