Gravity throw-in liquid sensor (DF Robot) variable readings
Hi, @olefella
From datasheet;
Have you worked out how much power you will be dissipating in the regulator?
Thanks... Tom.. :grinning: :+1: :coffee: :australia:
I was testing with a large (470uF) and a small ceramic capacitor on both sides of the 7815, but they didn't make any difference to the errors.
Thanks for pointing this out - I'll make sure I put the correct bypass capacitors in when I put it all together for the tanks.
The depth sensor operates at only max 25mA and the input voltage to the regulator is 18v so I doubt it will exceed the power dissipation.
