Hello, I'm setting up a cnc machine and I want to use the spindle enable pin to turn on/of a 5V relay (picture attached.
I'm using GRBL 0.9j, which has a PWM feature on the Spindle enable pin...I downloaded a HEX file with the Variable_Spindle disabled so my GRBL shoud behave like previous versions (No PWM stuff activated...).
Now, if I connect a simple LED to the Pin 12, pretending it's my relay, everything works great, I power Arduino and the LED is down, and I can turn it on with M3 command and shut it back down with M5.
If I use a Relay, actually, always on Pin 12, as I power up Arduino it triggers the relay, so whatever is connected to the relay is On. Commands M3 and M5 are switched, M3 shuts it down and M5 triggers it.
I need the relay to be down when I turn on Arduino.
Any chance the relay board might be the problem?
Can you help me?
THANKS
