I'm doing a project for a computer programming class, but I'm having a problem with it I can't figure out how to fix. Basically, there's a red LED that will start at a random brightness, then it will reset. You then use a potentiometer to control the brightness of the LED to get it as close as you can to the original brightness. Then, you press a button, and green LEDs will light up to indicate how close you were. The problem is, the first two green LEDs start turned on, and I can't fix it. Weirdly, the first LED is less bright than the second one, even though they're connected to digital pins. I'm guessing this is a wiring issue, but I don't know what exactly is wrong. I'm doing all this in Tinkercad, so I will put an image of the wiring and the project link. Please help!
I would like to help but not enough to sign up for an external app. If you want help here, post your well formatted code here in a code block as described in the "how to use the forum" post at the top of every forum section.
Pins 0 and 1 belong to the hardware serial port so you should not use those pins as GPIO.
Don’t use D1 or D0 as they are used for serial communications.
In the Arduino IDE, use Ctrl T or CMD T to format your code then copy the complete sketch.
Use the </> icon from the ‘posting menu’ to attach the copied sketch.
Oh. I changed the pins and now it works. Thanks.
