hey guys i am making a grid solving robot ...... it has to map a grid that is 59 (rowcol.) and some points of intersection has nodes that the bot must read and then deletes them from the grid .............. i am gonna show you the code but there is a proplem that it starts but after the first node it got stuck in the loop
here is the code :
#include <Servo.h>
define row 9
define col 5
// 2 servo moto
// 5 line track sensor
Servo lm;
Servo rm;
byte ros = 2;
byte ris = 3;
byte cs = 4;
byte lis = 5;
byte los = 6;
boolean counter = 0;
boolean flag = false;
boolean flag1 = false;
int array[row][col];
// Input & Output
lm.attach(9); // left servo motor
rm.attach(8); // right servo motor
pinMode(ros, INPUT); // right outter sensor
pinMode(ris, INPUT); //right inner sensor
pinMode(cs, INPUT); // center sensor
pinMode(lis, INPUT); // left inner sensor
pinMode(los, INPUT); // left outter sensor
int i = 0;
for (int y = 0; y < row; y++) {
for (int x = 0; x < col; x++) {
i++;
array[y][x] = i;
// basic motions
// max clkw 1700 , stop 1500 & max anti clkw 1300
void forward() {
lm.writeMicroseconds(1700);
rm.writeMicroseconds(1300);
void reverse() {
lm.writeMicroseconds(1300);
rm.writeMicroseconds(1700);
void TurnRight90() {
void TurnRight() {
rm.writeMicroseconds(1500);
void TurnLeft90() {
void TurnLeft() {
lm.writeMicroseconds(1500);
void stopRobot() {
// grid genration
void delete_node() {
if (counter == array[y][x]) {
array[y][x] = 0;
// fixed line track " 3ala el wae2f"
void move_track() {
if ((digitalRead(los) == HIGH && digitalRead(lis) == HIGH && digitalRead(cs) == LOW && digitalRead(ris) == LOW && digitalRead(ros) == LOW) ||
(digitalRead(los) == HIGH && digitalRead(lis) == LOW && digitalRead(cs) == LOW && digitalRead(ris) == LOW && digitalRead(ros) == LOW)) {
TurnLeft();
flag = false;
if ((digitalRead(los) == LOW && digitalRead(lis) == HIGH && digitalRead(cs) == HIGH && digitalRead(ris) == HIGH && digitalRead(ros) == HIGH) ||
(digitalRead(los) == LOW && digitalRead(lis) == LOW && digitalRead(cs) == HIGH && digitalRead(ris) == HIGH && digitalRead(ros) == HIGH)) {
TurnRight();
flag = false;
if (digitalRead(los) == HIGH && digitalRead(lis) == HIGH && digitalRead(cs) == HIGH && digitalRead(ris) == HIGH && digitalRead(ros) == HIGH && flag == false) {
counter++;
forward();
flag = true;
if (digitalRead(los) == LOW && digitalRead(lis) == LOW && digitalRead(cs) == LOW && digitalRead(ris) == LOW && digitalRead (ros) == LOW ) {
stopRobot();
flag = false;
if (digitalRead(los) == HIGH && digitalRead(cs) == LOW && digitalRead(ros) == HIGH && flag == false) {
counter++;
delete_node();
forward();
flag = true;
void dry_run() {
if ((counter == 1 || counter == 10 || counter == 11 || counter == 20 || counter == 21 || counter == 30 || counter == 31 || counter == 40 || counter == 41) && flag1 == false) {
TurnRight();
flag1 == true;
else if ((counter == 5 || counter == 6 || counter == 15 || counter == 16 || counter == 25 || counter == 26 || counter == 35 || counter == 36 ) && flag1 == false) {
TurnLeft();
flag1 == true;
else if (counter == 45 && flag1 == false) {
forward();
delay(3000);
stopRobot();
delay(10000);
else move_track();
void loop () {
dry_run();
