Line follower robot not tracking line
Line follower robot doesnt track the line. The sensor works I've checked the values. When above a black line the bot just jerks once and steers away. I've given the code if anybody wants to review it.
#include "U8glib.h"
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_DEV_0 | U8G_I2C_OPT_NO_ACK | U8G_I2C_OPT_FAST);  // Fast I2C / TWI
// U8GLIB_SSD1306_128X64 u8g(13, 11, 8, 9, 10); // SPI connection
// for I2C connection, use this wiring:
// GND > GND
// VCC > 3.3V
// SCL > A5
// SDA > A4
#include <EEPROM.h>
//motorpins
#define right_motor_forward A2  //IN1(L298) || TB6612 -- AIN2
#define right_motor_backward 4  //IN2(L298) || TB6612 -- AIN1
#define left_motor_forward 5    //IN3(L298)  || TB6612 --- BIN1
#define left_motor_backward 6   //IN4(L298)  || TB6612 --- BIN2
//speed control pins (PWM)
#define right_motor_speed 3  //EnA (L298) //TB6612 --- PWMA
#define left_motor_speed 9   //EnB (L298) //TB6612 --- PWMB
//MUX PIN
#define S0 11
#define S1 10
#define S2 8
#define S3 7
#define SIG_PIN A7
//Sensor Variables
#define sensorNumber 6
int sensorADC[sensorNumber];
int sensorDigital[sensorNumber];
int bitWeight[sensorNumber] = { 1, 2, 4, 8, 16, 32 };
int WeightValue[sensorNumber] = { 10, 20, 30, 40, 50, 60 };
int threshold = 300;
int sumOnSensor;
int sensorWeight;
int bitSensor;
int Max_ADC[sensorNumber];
int Min_ADC[sensorNumber];
int Reference_ADC[sensorNumber];
//PID Variables
float line_position;
float error;
float center_position = 35;
float derivative, previous_error;
int base_speed = 150;
int kp = 12;
int kd = 100;
//turns variable
String direction = "straight";  //default value straight
#define delay_before_turn 100
#define turnSpeed 200
//timers
#define stop_time 20
//inverse parameter
bool inverseON = 0;  //0 = normal line, 1 = inverse line
//distance calibration parameters
uint16_t test_time = 500;  //need to be adjusted for measured distance
int measured_distance = 30;
//led
#define led 13
const unsigned char upir_logo[] PROGMEM = {  // this is another way how to define images, using binary notation
  B00010101, B11010111,
  B00010101, B01000101,
  B00010101, B10010110,
  B00011001, B00010101
// 'scrollbar_background', 8x64px
const unsigned char bitmap_scrollbar_background[] PROGMEM = {
  0x00, 0x02, 0x00, 0x02, 0x00, 0x02, 0x00, 0x02, 0x00, 0x02, 0x00, 0x02, 0x00, 0x02, 0x00, 0x02,
  0x00, 0x02, 0x00, 0x02, 0x00, 0x02, 0x00, 0x02, 0x00, 0x02, 0x00, 0x02, 0x00, 0x02, 0x00, 0x00
// 'item_sel_outline', 128x21px
const unsigned char bitmap_item_sel_outline[] PROGMEM = {
  0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0,
  0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20,
  0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30,
  0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe0,
// ------------------ end generated bitmaps from image2cpp ---------------------------------
const int NUM_ITEMS = 5;         // number of items in the list and also the number of screenshots and screenshots with QR codes (other screens)
const int MAX_ITEM_LENGTH = 20;  // maximum characters for the item name
char menu_items[NUM_ITEMS][MAX_ITEM_LENGTH] = {
  // array with item names
  { "Line Follow" },
  { "Calibration" },
  { "Analog Value" },
  { "Digital Value" },
  { "Motor Test" },
// note - when changing the order of items above, make sure the other arrays referencing bitmaps
// also have the same order, for example array "bitmap_icons" for icons, and other arrays for screenshots and QR codes
#define BUTTON_UP_PIN A0      // pin for UP button
#define BUTTON_SELECT_PIN 12  // pin for SELECT button
#define BUTTON_DOWN_PIN A1    // pin for DOWN button
int button_up_clicked = 0;      // only perform action when button is clicked, and wait until another press
int button_select_clicked = 0;  // same as above
int button_down_clicked = 0;    // same as above
int item_selected = 0;          // which item in the menu is selected
int item_sel_previous;          // previous item - used in the menu screen to draw the item before the selected one
int item_sel_next;              // next item - used in the menu screen to draw next item after the selected one
int current_screen = 0;         // 0 = menu, 1 = screenshot, 2 = qr
//************************************SETUP***************************************
  u8g.setColorIndex(1);  // set the color to white
  pinMode(S0, OUTPUT);
  pinMode(S1, OUTPUT);
  pinMode(S2, OUTPUT);
  pinMode(S3, OUTPUT);
  pinMode(BUTTON_UP_PIN, INPUT_PULLUP);
  pinMode(BUTTON_DOWN_PIN, INPUT_PULLUP);
  pinMode(BUTTON_SELECT_PIN, INPUT_PULLUP);
  pinMode(led, OUTPUT);
  pinMode(left_motor_forward, OUTPUT);
  pinMode(left_motor_backward, OUTPUT);
  pinMode(right_motor_forward, OUTPUT);
  pinMode(right_motor_backward, OUTPUT);
  pinMode(left_motor_speed, OUTPUT);
  pinMode(right_motor_speed, OUTPUT);
  LoadCalibration();  //load calibration value from eeprom whenever the arduino is start or reset
//************************************LOOP***************************************
  //front page
  while (1) {
    read_black_line();
    u8g.firstPage();
    do {
      u8g.setFont(u8g_font_7x14B);
      u8g.drawStr(40, 15, "TRINITY");  //Set Your Team Name
      u8g.setFont(u8g_font_profont12);
      u8g.drawStr(35, 60, "Sensor View");  //Set Your Team Name
      u8g.setPrintPos(10, 60);
      u8g.print(sensorDigital[0]);
      u8g.setPrintPos(20, 45);
      u8g.print(sensorDigital[1]);
      u8g.setPrintPos(35, 35);
      u8g.print(sensorDigital[2]);
      u8g.setPrintPos(55, 35);
      u8g.print(sensorDigital[3]);
      u8g.setPrintPos(75, 35);
      u8g.print(sensorDigital[4]);
      u8g.setPrintPos(95, 35);
      u8g.print(sensorDigital[5]);
    } while (u8g.nextPage());
    while (button(BUTTON_DOWN_PIN) == 1) menu();
void PID_Controller(int base_speed, int p, int d) {
  while (1) {
a:
    read_black_line();
    if (sumOnSensor > 0 ) line_position = sensorWeight / sumOnSensor;
    error = center_position - line_position;
    switch (bitSensor) {
      //left side detection
      case 0b111100: direction = "left"; break;
      case 0b111000: direction = "left"; break;
      case 0b111110: direction = "left"; break;
      //right side detection
      case 0b001111: direction = "right"; break;
      case 0b000111: direction = "right"; break;
      case 0b011111: direction = "right"; break;
    //turn execution when all the sensor on the white surface.
    if (bitSensor == 0) {
      error = 0;
      if (direction != "straight") {  //if the direction is either left or right
        //digitalWrite(led, HIGH);      //turning on led as indicator when left or right turn is detected.
        delay(delay_before_turn);
        if (direction == "right") {
          //right turn logic
          turnRight(turnSpeed, turnSpeed);
          //left turn logic
          turnLeft(turnSpeed, turnSpeed);
        //digitalWrite(led, LOW);  //after execution of turns the led will off
        //hard_stop(); //after executing turns the robot will stop. this is only for turn test
    } else if (bitSensor == 63) {  //Stop Point, T, Cross Intersections
      digitalWrite(led, HIGH);      //led on when all black
      distance(5);                  //move 10cm forward.
      read_black_line();            //then read sensor value
      while (bitSensor == 63) {    //if sensor value still on black line. that means its stop point
        stop();                     //then robot stop
        read_black_line();          //update sensor if it's changing or not.
        direction = "right";  //turn for T intersection.
        if (bitSensor > 0 && bitSensor < 255) {
          direction = "straight";  //for Cross intersection
    } else if (bitSensor == 39 || bitSensor == 51 || bitSensor == 55|| bitSensor == 51 || bitSensor == 59 || bitSensor == 57){
      inverseON = !inverseON;
      digitalWrite(led, inverseON);
      Bit_Sensor_Show();
      continue;
    //show sensor pattern
    //Bit_Sensor_Show();
    derivative = error - previous_error;
    int right_motor_correction = base_speed + (error * p + derivative * d);
    int left_motor_correction = base_speed - (error * p + derivative * d);
    previous_error = error;
    //Drive Motor According to PID Value
    motor(left_motor_correction, right_motor_correction);
void calibrateSensor() {
  u8g.setFont(u8g_font_7x14B);  // Set the font
  u8g.firstPage();
  do {
    u8g.drawStr(5, 35, "Calibrating...");
  // Initialize calibration limits
  for (int i = 0; i < sensorNumber; i++) {
    Max_ADC[i] = 0;     // Set the maximum ADC value for each sensor to 0 (lowest possible)
    Min_ADC[i] = 1024;  // Set the minimum ADC value for each sensor to 1024 (highest possible, since ADC range is 0–1023)
  // Define rotation directions for calibration sweeps
  int rotationDirections[][2] = {
    { -1, 1 },  // Rotate robot slightly to the left
    { 1, -1 },  // Rotate robot slightly to the right
    { 1, -1 },  // Repeat rotation to the right for better calibration coverage
    { -1, 1 }   // Rotate left again to cover the full sensor range
  // Perform calibration sweeps (4 passes)
  for (int step = 0; step < 4; step++) {
    // Rotate the robot slowly in the defined direction for this step
    motor(base_speed * 0.4 * rotationDirections[step][0],
          base_speed * 0.4 * rotationDirections[step][1]);
    // Sweep through several readings while rotating
    for (int sweep = 0; sweep < 500; sweep++) {
      // Read each sensor one by one
        selectChannel(i);                    // Select which sensor channel to read (if using multiplexer)
        sensorADC[i] = analogRead(SIG_PIN);  // Read the analog value from the sensor
        // Update the maximum and minimum ADC values recorded for this sensor
        Max_ADC[i] = max(Max_ADC[i], sensorADC[i]);
        Min_ADC[i] = min(Min_ADC[i], sensorADC[i]);
    motor(0, 0);  // Stop the motors after each rotation step
    delay(200);   // Small pause before changing rotation direction
  // Store calibrated Reference, Max, and Min values in EEPROM
    Reference_ADC[i] = (Max_ADC[i] + Min_ADC[i]) / 2.0;  // Calculate mid-point (reference) value
    EEPROM.write(i, Reference_ADC[i] / 4);           // Store reference value (divided by 4 because EEPROM stores 0–255)
    delay(5);                                        // Small delay for EEPROM write stability
    EEPROM.write(i + sensorNumber, Max_ADC[i] / 4);  // Store maximum calibrated value
    delay(5);
    EEPROM.write(i + (sensorNumber * 2), Min_ADC[i] / 4);  // Store minimum calibrated value
    delay(5);
  show_calibration();
// Function to load calibration data from EEPROM
void LoadCalibration() {
  // Print header labels for serial monitor (sensor indices)
  Serial.print("S0: ");
  Serial.print(", S1: ");
  Serial.print(", S2: ");
  Serial.print(", S3: ");
  Serial.print(", S4: ");
  Serial.print(", S5: ");
  // Load the stored calibration data for each sensor
    Reference_ADC[i] = EEPROM.read(i) * 4;                 // Read and restore reference value
    Max_ADC[i] = EEPROM.read(i + sensorNumber) * 4;        // Read and restore maximum value
    Min_ADC[i] = EEPROM.read(i + (sensorNumber * 2)) * 4;  // Read and restore minimum value
    Serial.print(String(Reference_ADC[i]) + ",  ");  // Print loaded reference value
  Serial.println();  // Move to new line after printing all sensor values
//function for displaying calibration value
void show_calibration() {
  while (1) {
    // Set the font
    u8g.firstPage();
    do {
      //title print
      u8g.drawStr(15, 10, "MIN");
      u8g.drawStr(55, 10, "MID");
      u8g.drawStr(95, 10, "MAX");
      //value print
      u8g.setPrintPos(15, 30);
      u8g.print(Min_ADC[0]);
      u8g.setPrintPos(15, 45);
      u8g.print(Min_ADC[4]);
      u8g.setPrintPos(15, 60);
      u8g.print(Min_ADC[5]);
      u8g.setPrintPos(55, 30);
      u8g.print(Reference_ADC[0]);
      u8g.setPrintPos(55, 45);
      u8g.print(Reference_ADC[3]);
      u8g.setPrintPos(55, 60);
      u8g.print(Reference_ADC[5]);
      u8g.setPrintPos(95, 30);
      u8g.print(Max_ADC[0]);
      u8g.setPrintPos(95, 45);
      u8g.print(Max_ADC[3]);
      u8g.setPrintPos(95, 60);
      u8g.print(Max_ADC[5]);
    while (button(BUTTON_DOWN_PIN) == 1) return menu();
void turnRight(int L, int R) {
  while (sensorDigital[2] != 1) {  //loop will break when sensor number 4 detects line.
    motor(L, -R);                  //right motor forward and left motor backward.
    read_black_line();             //observing continous change of sensor value.
    direction = "straight";        //set the direction value to default
void turnLeft(int L, int R) {
  while (sensorDigital[3] != 1) {  //loop will break when sensor number 4 detects line.
    motor(-L, R);                  //right motor forward and left motor backward.
void hard_stop() {
  while (1) motor(0, 0);
void stop() {
  motor(0, 0);
void distance_calibration(uint16_t test_time) {
  unsigned long startTime = millis();
  while (millis() - startTime < test_time) {
    motor(base_speed, base_speed);  //forward movement
  motor(0, 0);  //stop after completing the measured distance.
void distance(uint16_t dist) {
  int time_per_cm = test_time / measured_distance;
  unsigned long moveTime = dist * time_per_cm;
  while (millis() - startTime < moveTime) {
uint8_t button(uint8_t buttonNumber) {
  uint16_t t = 0;
  if (!digitalRead(buttonNumber)) {
    delay(50);
    while (!digitalRead(buttonNumber)) {
      delay(50);
      t += 50;
      if (t > 500) digitalWrite(led, 1);
    digitalWrite(led, 0);
    if (t > 0) return 1;
  return 0;
void menu() {
  while (1) {
    if (current_screen == 0) {  // MENU SCREEN
      // up and down buttons only work for the menu screen
      if ((digitalRead(BUTTON_UP_PIN) == LOW) && (button_up_clicked == 0)) {  // up button clicked - jump to previous menu item
        item_selected = item_selected - 1;                                    // select previous item
        button_up_clicked = 1;                                                // set button to clicked to only perform the action once
        if (item_selected < 0) {                                              // if first item was selected, jump to last item
          item_selected = NUM_ITEMS - 1;
      } else if ((digitalRead(BUTTON_DOWN_PIN) == LOW) && (button_down_clicked == 0)) {  // down button clicked - jump to next menu item
        item_selected = item_selected + 1;                                               // select next item
        button_down_clicked = 1;                                                         // set button to clicked to only perform the action once
        if (item_selected >= NUM_ITEMS) {                                                // last item was selected, jump to first menu item
          item_selected = 0;
      if ((digitalRead(BUTTON_UP_PIN) == HIGH) && (button_up_clicked == 1)) {  // unclick
      if ((digitalRead(BUTTON_DOWN_PIN) == HIGH) && (button_down_clicked == 1)) {  // unclick
    if ((digitalRead(BUTTON_SELECT_PIN) == LOW) && (button_select_clicked == 0)) {  // select button clicked, jump between screens
      button_select_clicked = 1;                                                    // set button to clicked to only perform the action once
      if (current_screen == 0) { current_screen = 1; }                              // menu items screen --> screenshots screen
      else if (current_screen == 1) {
        current_screen = 2;
      }                             // screenshots screen --> qr codes screen
      else { current_screen = 0; }  // qr codes screen --> menu items screen
    if ((digitalRead(BUTTON_SELECT_PIN) == HIGH) && (button_select_clicked == 1)) {  // unclick
    // set correct values for the previous and next items
    item_sel_previous = item_selected - 1;
    if (item_sel_previous < 0) { item_sel_previous = NUM_ITEMS - 1; }  // previous item would be below first = make it the last
    item_sel_next = item_selected + 1;
    if (item_sel_next >= NUM_ITEMS) { item_sel_next = 0; }  // next item would be after last = make it the first
    //execute specific task when select button is clicked
    if (item_selected == 0 && button_select_clicked == 1) {
      current_screen = 0;
      PID_Controller(base_speed, kp, kd);
    if (item_selected == 1 && button_select_clicked == 1) {
      current_screen = 0;
      calibrateSensor();
    if (item_selected == 2 && button_select_clicked == 1) {
      current_screen = 0;
      analog_value();
    if (item_selected == 3 && button_select_clicked == 1) {
      current_screen = 0;
      digital_value();
    if (item_selected == 4 && button_select_clicked == 1) {
      current_screen = 0;
      motor_test();
    u8g.firstPage();  // required for page drawing mode for u8g library
    do {
        // selected item background
        u8g.drawBitmapP(0, 22, 128 / 8, 21, bitmap_item_sel_outline);
        // draw previous item as icon + label
        u8g.setFont(u8g_font_7x14);
        u8g.drawStr(25, 15, menu_items[item_sel_previous]);
        //u8g.drawBitmapP( 4, 2, 16/8, 16, bitmap_icons[item_sel_previous]);
        // draw selected item as icon + label in bold font
        u8g.drawStr(25, 15 + 20 + 2, menu_items[item_selected]);
        //u8g.drawBitmapP( 4, 24, 16/8, 16, bitmap_icons[item_selected]);
        // draw next item as icon + label
        u8g.drawStr(25, 15 + 20 + 20 + 2 + 2, menu_items[item_sel_next]);
        //u8g.drawBitmapP( 4, 46, 16/8, 16, bitmap_icons[item_sel_next]);
        // draw scrollbar background
        u8g.drawBitmapP(128 - 8, 0, 8 / 8, 64, bitmap_scrollbar_background);
        // draw scrollbar handle
        u8g.drawBox(125, 64 / NUM_ITEMS * item_selected, 3, 64 / NUM_ITEMS);
        // draw upir logo
        u8g.drawBitmapP(128 - 16 - 4, 64 - 4, 16 / 8, 4, upir_logo);
    } while (u8g.nextPage());  // required for page drawing mode with u8g library
void motor(int LPWM, int RPWM) {
  if (LPWM > 0) {
    digitalWrite(left_motor_forward, HIGH);
    digitalWrite(left_motor_backward, LOW);
    digitalWrite(left_motor_forward, LOW);
    digitalWrite(left_motor_backward, HIGH);
  if (RPWM > 0) {
    digitalWrite(right_motor_forward, HIGH);
    digitalWrite(right_motor_backward, LOW);
    digitalWrite(right_motor_forward, LOW);
    digitalWrite(right_motor_backward, HIGH);
  LPWM = constrain(LPWM, -255, 255);
  RPWM = constrain(RPWM, -255, 255);
  //Serial.print(String(LPWM) + ",  " + String(RPWM) + ",  ");
  //Serial.println();
  analogWrite(left_motor_speed, abs(LPWM));
  analogWrite(right_motor_speed, abs(RPWM));
//motor test function
void motor_test() {
  while (1) {
    u8g.firstPage();
    do {
      u8g.drawStr(5, 35, "Motor Testing...");
    motor(250, 250);
    delay(3000);
    motor(0, 0);
    return;
void read_black_line() {
  sumOnSensor = 0;
  sensorWeight = 0;
  bitSensor = 0;
    selectChannel(i);
    delayMicroseconds(20);
    //map analog value x
    //analog to digital
    if (sensorADC[i] > Reference_ADC[i]) {
      if (inverseON == 0) {    //black line - normal mode.
        sensorDigital[i] = 1;  //black line =1
        sensorDigital[i] = 0;  //black line =0 (black line -inverse mode)
      if (inverseON == 0) {    //white line - normal mode
        sensorDigital[i] = 0;  //white line =0 - normal mode
        sensorDigital[i] = 1;  //white line - inverse mode.
    sumOnSensor += sensorDigital[i];
    sensorWeight += sensorDigital[i] * WeightValue[i];
    bitSensor += sensorDigital[i] * bitWeight[(sensorNumber - 1) - i];
void selectChannel(int channel) {
  digitalWrite(S0, bitRead(channel, 0));
  digitalWrite(S1, bitRead(channel, 1));
  digitalWrite(S2, bitRead(channel, 2));
  digitalWrite(S3, bitRead(channel, 3));
void sensor_value_test() {
  while (1) {
    read_black_line();
      Serial.print(String(sensorADC[i]) + "  ");
void Bit_Sensor_Show() {
    read_black_line();  //take sensor reading
    Serial.print("Bit Sensor in Decimal: " + String(bitSensor));  //Decimal Value Show
    Serial.print(" | Bit Sensor in Binary: ");
    for (int i = (sensorNumber - 1); i >= 0; i--) {  //display bitsensor data in binary
      Serial.print(String(bitRead(bitSensor, i)));
void sensor_value_check() {
    selectChannel(i);
    //map analog value
    //analog to digital
    if (sensorADC[i] > threshold) {
    Serial.print("  " + String(sensorDigital[i]));
//function for displaying analog value
void analog_value() {
  while (1) {
    for (int channel = 0; channel < sensorNumber; channel++) {
      selectChannel(channel);
      sensorADC[channel] = analogRead(SIG_PIN);
    u8g.setFont(u8g_font_profont12);  // Set the font
    u8g.firstPage();
    do {
      u8g.print(sensorADC[0]);
      u8g.print(sensorADC[1]);
      u8g.setPrintPos(20, 30);
      u8g.print(sensorADC[2]);
      u8g.setPrintPos(35, 15);
      u8g.print(sensorADC[3]);
      u8g.setPrintPos(65, 15);
      u8g.print(sensorADC[4]);
      u8g.setPrintPos(80, 30);
      u8g.print(sensorADC[5]);
    while (button(BUTTON_DOWN_PIN) == 1) return;
//function for displaying digital value
void digital_value() {
  while (1) {
    String inverseState;
    read_black_line();
    if (bitSensor == 39 || bitSensor == 51 || bitSensor == 55|| bitSensor == 51 || bitSensor == 59 || bitSensor == 57) {
    (inverseON) ? inverseState = "Inv: ON" : inverseState = "Inv: OFF";
    u8g.firstPage();
    do {
      u8g.setPrintPos(50, 15);
      u8g.print(inverseState);
      u8g.drawStr(45, 50, "BitSensor");
      u8g.setPrintPos(60, 60);
      u8g.print(bitSensor);
Correction in the wrong direction. Check the wiring or change the sign.
If the robot goes in the wrong direction, the correction is wrong, or inconsistent with the motor wiring.
Put in Serial.print statements to see the values produced by the program when you hold the robot over the line, shifting it right and left. Compare those values with what you would expect.
For debugging, pare the code down to the minimum required to determine the line sensor reading, correction calculation and proper behavior, which is about 10% of what you posted. All the ug8 display stuff can go.
"signs" ARE logic.
You have many choices:
  1. Correct motors logic
  1. Correct motor pins
//motorpins
  1. Correct left/right interpretation
  1. Correct argument order for motors:
And many more places... Which is your choice?
[edit]
You can save memory by drawing lines rather than rendering graphics of lines.
What multiplexer are you using to read the six sensors?
Here is the code in wokwi..
code for Nano R3 in Wokwi
// https://forum.arduino.cc/t/line-follower-robot-not-tracking-line/1440378/5
#include "U8glib.h"
// GND > GND
// VCC > 3.3V
// SCL > A5
// SDA > A4
#include <EEPROM.h>
//motorpins
//MUX PIN
#define S0 11
#define S1 10
#define S2 8
#define S3 7
#define SIG_PIN A7
//Sensor Variables
int sumOnSensor;
int sensorWeight;
int bitSensor;
//PID Variables
float error;
int kp = 12;
int kd = 100;
//turns variable
//timers
//inverse parameter
//led
#define led 13
  { "Line Follow" },
  { "Calibration" },
  { "Analog Value" },
  { "Motor Test" },
  // Serial.begin(9600);
  pinMode(S0, OUTPUT); // multiplexer pins
  //front page
  while (1) {
    read_black_line();
    u8g.firstPage();
    do {
  while (1) {
    read_black_line();
      error = 0;
          //right turn logic
          //left turn logic
    } else if (bitSensor == 39 || bitSensor == 51 || bitSensor == 55 || bitSensor == 51 || bitSensor == 59 || bitSensor == 57) {
      Bit_Sensor_Show();
      continue;
  u8g.firstPage();
  do {
    delay(5);
    delay(5);
  show_calibration();
void LoadCalibration() {// Load calibration data from EEPROM
  Serial.print("|  S0  |  S1  |  S2  |  S3  |  S4  |  S5  |\n| ");
    Serial.print(String(Reference_ADC[i]) + " | ");  // Print loaded reference value
  while (1) {
    // Set the font
    u8g.firstPage();
    do {
      //title print
      //value print
void hard_stop() {
void stop() {
  motor(0, 0);
  uint16_t t = 0;
    delay(50);
      delay(50);
      t += 50;
  return 0;
void menu() {
  while (1) {
          item_selected = 0;
        current_screen = 1;  // menu items screen --> screenshots screen
        current_screen = 2;
      else {
        current_screen = 0;  // qr codes screen --> menu items screen
      item_sel_previous = NUM_ITEMS - 1;  // previous item would be below first = make it the last
      item_sel_next = 0;  // next item would be after last = make it the first
      current_screen = 0;
      current_screen = 0;
      calibrateSensor();
      current_screen = 0;
      analog_value();
      current_screen = 0;
      digital_value();
      current_screen = 0;
      motor_test();
    do {
        // draw upir logo
  if (LPWM > 0) {
  if (RPWM > 0) {
  //Serial.println();
void motor_test() {
  while (1) {
    u8g.firstPage();
    do {
    motor(250, 250);
    delay(3000);
    motor(0, 0);
    return;
  sumOnSensor = 0;
  sensorWeight = 0;
  bitSensor = 0;
    selectChannel(i);
    //analog to digital
  while (1) {
    read_black_line();
    selectChannel(i);
    //map analog value
    //analog to digital
  while (1) {
    u8g.firstPage();
    do {
  while (1) {
    read_black_line();
    u8g.firstPage();
    do {
diagram.json for wokwi
  "version": 1,
  "author": "foreignpigdog x",
  "editor": "wokwi",
  "parts": [
      "type": "wokwi-arduino-nano",
      "id": "nano",
      "top": 179.6,
      "left": 20.5,
      "rotate": 270,
      "attrs": {}
      "type": "board-ssd1306",
      "id": "oled1",
      "top": 329.54,
      "left": 105.83,
      "attrs": { "i2cAddress": "0x3c" }
      "type": "wokwi-led",
      "id": "led1",
      "top": 404.8,
      "left": -25,
      "rotate": 180,
      "attrs": { "color": "red", "flip": "1" }
      "id": "led2",
      "top": 274.8,
      "left": -25,
      "attrs": { "color": "white" }
      "id": "led3",
      "top": 404.8,
      "left": -53.4,
      "rotate": 180,
      "attrs": { "color": "red", "flip": "" }
      "id": "led4",
      "top": 274.8,
      "left": -53.8,
      "attrs": { "color": "white", "flip": "1" }
      "type": "wokwi-servo",
      "id": "servo1",
      "top": 37.4,
      "left": -36.6,
      "rotate": 270,
      "attrs": {}
      "id": "servo2",
      "top": 37.4,
      "left": -123,
      "rotate": 270,
      "attrs": {}
      "type": "wokwi-pushbutton",
      "id": "btn1",
      "top": 310.6,
      "left": 221,
      "rotate": 180,
      "attrs": { "color": "green", "xray": "1" }
      "id": "btn2",
      "top": 358.6,
      "left": 221,
      "rotate": 180,
      "id": "btn3",
      "top": 406.6,
      "left": 221,
      "rotate": 180,
      "type": "wokwi-text",
      "id": "text1",
      "top": 326.4,
      "left": 316.8,
      "attrs": { "text": "UP (A0)" }
      "id": "text2",
      "top": 374.4,
      "left": 316.8,
      "attrs": { "text": "SEL (12)" }
      "id": "text3",
      "top": 422.4,
      "left": 316.8,
      "attrs": { "text": "DOWN (A1)" }
    { "type": "wokwi-text", "id": "text4", "top": 288, "left": -67.2, "attrs": { "text": "LF" } },
    { "type": "wokwi-text", "id": "text5", "top": 288, "left": 9.6, "attrs": { "text": "RF" } },
      "id": "text6",
      "top": 422.4,
      "left": -67.2,
      "attrs": { "text": "LR" }
    { "type": "wokwi-text", "id": "text7", "top": 422.4, "left": 9.6, "attrs": { "text": "RR" } },
      "id": "text8",
      "top": 153.6,
      "left": -144,
      "rotate": 90,
      "attrs": { "text": "LEFT MOTOR PWM" }
      "id": "text9",
      "top": 163.2,
      "left": -57.6,
      "rotate": 90,
      "attrs": { "text": "RIGHT MOTOR PWM" }
      "id": "text10",
      "top": 460.8,
      "left": 96,
      "attrs": { "text": "UNTIL LED_BUILTIN LIGHTS " }
      "id": "text11",
      "top": 355.2,
      "left": -96,
      "rotate": 270,
      "attrs": { "text": "MOTORS" }
      "id": "text12",
      "top": 412.8,
      "left": 96,
      "attrs": { "text": "MENU/ESCAPE:\nPRESS \"DOWN\" " }
  "connections": [
    [ "nano:9", "servo2:PWM", "green", [ "h-182.6" ] ],
    [ "oled1:GND", "nano:GND.1", "black", [ "v0" ] ],
    [ "oled1:VCC", "nano:5V", "red", [ "v0" ] ],
    [ "oled1:SCL", "nano:A5", "green", [ "v0" ] ],
    [ "oled1:SDA", "nano:A4", "green", [ "v0" ] ],
    [ "btn3:1.l", "nano:A1", "green", [ "h28.8", "v-201.6" ] ],
    [ "btn2:1.l", "nano:12", "green", [ "h19.2", "v-86.4", "h-240", "v-28.8" ] ],
    [ "btn1:1.l", "nano:A0", "green", [ "h9.6", "v-96" ] ],
    [ "nano:GND.3", "led2:C", "black", [ "h0", "v220.8", "h-153.6" ] ],
    [ "led2:C", "led1:C", "black", [ "v0" ] ],
    [ "led1:C", "led3:C", "black", [ "v-48", "h-47.6" ] ],
    [ "led3:C", "led4:C", "black", [ "v0" ] ],
    [ "servo2:GND", "servo1:GND", "black", [ "v19.2", "h38.4" ] ],
    [ "servo2:V+", "servo1:V+", "red", [ "v9.6", "h57.7" ] ],
    [ "nano:A2", "led2:A", "green", [ "h48", "v86.4", "h-172.8" ] ],
    [ "nano:4", "led1:A", "green", [ "h-28.8", "v172.8", "h-28.8" ] ],
    [ "nano:5", "led4:A", "green", [ "h-38.4", "v144", "h-77.2" ] ],
    [ "nano:6", "led3:A", "green", [ "h-19.2", "v163.2", "h-96" ] ],
    [ "nano:3", "servo1:PWM", "green", [ "h-48" ] ],
    [ "nano:GND.3", "btn1:2.r", "black", [ "h0", "v172.8" ] ],
    [ "btn1:2.r", "btn2:2.r", "black", [ "h-9.8", "v48" ] ],
    [ "btn2:2.r", "btn3:2.r", "black", [ "h-9.8", "v28.6" ] ]
  "dependencies": {}
And... some screen-shots...
Startup (note: long-press DOWN for MENU)
Calibration - tests motors (leaves REVERSE ON)
Analog value (reading the sensors)
Digital value - reading the line
Motors - Servos are PWM, LEDs are motor drivers
Line Follower - PWM, motors, line sensors
After simulating, I would say; verify your power supply is sufficient (too high a demand has unpredictable result, too low a supply could cause reboot), and also check your wiring.
Hi, @ghost721998
Welcome to the forum.
When did you find this out, after you made your complete code?
Did you write your code in stages and get each stage working before coding the next.
If so then;
You should have code that JUST reads your sensors.
You should have code that JUST controls your motors.
If both are working correctly then you should have code that JUST interacts between sensors and motors.
Did it work at that point, before all the display and other stuff?
I see a lot of code there that assumes a mass code writing effort without checking the individual events separately.
Please post your code cut down to just sensors and motor that exhibits the problem.
Thanks... Tom.... :smiley: :+1: :coffee: :australia:
@ghost721998 - Here is an example of writing code in stages to build a specific kit-car, but the idea of "stages" is for every project...
