I’m looking to ground roughly 50 dupont wires ?
Like a "Ground Shield" with 50-60 points?
LarryD
4
You can make something like this with an IDC connector.
And is that just one wire weaved through the idc connector?
LarryD
9
Correct.
A bench vice is used to close the connector.
LarryD
11
Yes, make Y cables and/or solder wires to a PCB strip board.
I've thought of laying one out in 'Eagle' (because absurdities appeal to me).
dougp
13
Or something like this:
Connect all the pins to ground on the underside of the board and clamp the duPont pins into the block's pockets
I buy them by the dozen. the fact that they are marked for VCC and I2C does not compel you to use them for VCC and I2C
same thing different way: the black and red lines are all tied together
