Hello !
I have a problem using this code that i have found on Seeedstudio itself . The basic principle of this circuit is simple. It is to turn on the LED light after it detects the receiver and emitter when it is within range. I need a solution of what code is needed to be added so that it can fucntion properly. as I cannot find a way to output the LED light.
(Infrared receiver's code)
#include <IRSendRev.h>
//#include <IRSendRevInt.h>
int led = 2 ;
pinMode(led, OUTPUT);
IR.Init(A3);
unsigned char dta[20];
if(IR.IsDta())
// IR.Recv(dta);
int length= IR.Recv(dta);
for (int i =0;i<length;i++)
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
(Infrared Emitter's code)
enableIROut(38);
//unsigned char d[] = {9, 90, 91, 11, 31, 4, 1, 2, 3, 4};
unsigned char d[] = {15, 70, 70, 20, 60, 10, 1, 2, 3, 4,5,6,7,8,9,10};
//Very Important:
//the first parameter(15): the data that needs to be sent;
//the next 2 parameter(70,70): the logic high and low duration of "Start";
//the next 2 parameter(20,60): the logic "short" and "long"duration in the communication
// that to say: if "0", the high duration is 20ms and low is 20 ms; while logic "1",
// the high duration is 20 ms and low is 60 ms;
//the next 2 parameter(10): number of data you will sent;
//the next parameter(1, 2, 3, 4,5,6,7,8,9,10): data you will sent ;
IR.Send(d, 38);//sent the data via 38Kz IR
