GSM module and solar power for Arduino Uno. (Asking for help)
Hi guys were asking some advise here. Thanks.
It's my first time working with Arduino because of our capstone project. Our project is about greenhouse monitoring using an Arduino Uno as the microcontroller. We are using a DHT11 sensor and a soil moisture sensor, and the project was supposed to be working well. However, our adviser wants to add a feature to notify the user, so we are using the GSM SIM800L V2 module for SMS notifications and solar power (12V) with a battery as the energy source.
We are having a hard time designing the circuit and finding the right materials. Our main problem is powering the Arduino and getting the GSM module to work because the SIM800L only blinks every second, and our solar circuit is not providing power.
How can we power both the Arduino and the GSM module using solar energy? What materials do we need to achieve this result? We have done our research, but we can't find the specific answer we need. We really need help, and we are looking for a cost-effective yet reliable solution. Thank you in advance!
And what are the results of your research? How much voltage, how much amperage, how many watt-hours are needed? Are you powering the system 24/7 or just when the sun is shinning? No one can help until you tell us what you have done.
Yes powering the adruino for 24 hours. Its said adruino needed a 7 to 12v as a stable power supply plug in through the DC jack. So we're searching for a circuit that cater the Arduino and GSM at the same time without the possibility of Arduino board to explode because we cant afford that loss Arduino is quite expensive for us. Thanks.
No, nothing is said about a stable power supply. The Uno has a it's own regulator to produce a stable 5 volt power from an unstable 7-12 volts. What does your GSM require?
Is this relevant, because I don't know what it is?
So you have a setup, did you do any calculations before getting the hardware? How much sunlight is there per day, does it vary depending upon the seasons. How much does the Arduino and the module draw, that decides how big / effective the PV panel must be, and how to size the charger and the battery.
How much does a Uno cost where you live?
Capstone is a subject required to graduate a thesis in the other course. We did not do any calculation we just bought it its the less expensive and supposedly easy to use according to the video in youtube. Sun is not a problem because we're in tropical country. And lastly adruino worth is my 7 days allowance. Thanks
GSM said to be 5v required.
And the current requirements needed for all the components, so you can get the right size for the solar and storage?
Yes exactly. Thanks
So pick something to get started with, like that SIM800L. The sensors next, they are not hard to interface with the Arduino. Last and hardest part I'd say is the PV, charger and battery. Something crucial is that the charger must cut-off when battery is full. When all that is under control you can focus on details, like putting the Arduino, the module and the sensors to sleep etc.
Yes that exactly. At first we just want to use a 7-12 voltage adaptor but our adviser want to use the solar as power supply, we don't have choice but to obliged. Thank you
Solar power ALWAYS requires a regulator of some type. Are you going to store the solar power for later use, or only rely on clear, daylight operation?
Daily use actually.
By the way Chat gpt give me this diagram for solar circuit to Arduino.
      [ Solar Panel (12V) ]
  [ Charge Controller ]
[ Battery (12V, 40Ah) ]
[ DC-DC Step-Down (12V → 9V) ]
(+9V) ▼
[ Arduino Uno (DC Jack) ]
[DHT11] [ Soil Moisture ]
[ Arduino 5V & GND ]
(+5V) ▼
[ GSM SIM800L V2 ]
[ Arduino TX/RX ]
Is this a good circuit?
Thank you.
Where did you get that? The first spec I found says 3.4 to 4.4V.
The red one also the smallest only required 3.7-4.4 v but v2 EVB it's color blue and a little bigger than red required 5v for stable power to work
Whattsigonnabe? :grinning_face_with_smiling_eyes:
If you're giving the Chat GPT juggle here, I'll leave. Good luck with the Capstone :+1:
It's okay. Thanks anyway. I just use chat gpt sometimes as guide but we never actually put it in our capstone. Thank you for your time
How I did that:
Power them from a 12v lead-acid battery. Use solar power to charge your battery. You'll need:
  1. A solar panel, 18-22v
  2. Buck converter to convert your solar panel voltage to 14.3v
  3. Lead-Acid battery charge controller, which connects solar panel & the buck converter to the battery when battery voltage drops below 11v and disconnects once battery reaches 14v
  4. An "ideal diode" module to protect your buck converter from being "charged" by your battery.
  5. Two stepdown converters, 5v, one of them - high current. Power your Arduino from low power converter, power your SIM800 from second converter
  6. Lead-Acid battery (from a motorbike)
All abovementioned components (except for the battery) are available from aliexpress (or lazada) at 1-2-3 dollars per module.
Thank you :blush:. We're going to try this.
Do you a circuit for this???
This circuit we'll be plugged in the DC jack of Arduino right or the other pin?
Thanks.
Actually the starting shows NO CIRCUIT AT ALL! And there is NO FUSE in series with the battery.
